Question about Motorola Mobility PEBL U6 Cellular Phone
Dismantle the phone
Can you tell me how to dismantle the phone to replace the flexible wire between the bottom and top of the phone. I've removed the only screws visable in the top part and still can't get it to separate
    Brigadier General:
  • 7,752 Answers
graspr.com
Posted on Sep 30, 2008
SOURCE:
I have the same problem but nobody seems to have a solution. My screen cut back on for like a min after i opened it real wide.. i pulled back on it a lil and it cut on then cut off..
The Flexible cable wire on your Motorola RAZR V3 is already damages. that's the most common problems on flip type mobile phones like Motorola RAZR V3.
If it is still under warranty period, as a mobile phone technician I advice you to bring to your nearest service center for a new replacement of the ribbon wire on it.
If you want to fix it yourself you can mange to do so, just purchased and find the replacement parts on E-bay.
you may find the Dismantling guide in here. Motorola RAZR V3 Dismantle Guide
Jun 21, 2010 | Motorola Mobility RAZR V3
My son spilled water on his ds lite last night. Now it does nothing. When you try to tur it on, the bottom screen flashes very quickly and thats it. Is there any hope?
If thebottom screen flashes then thetop screen is damaged and will need replacing.
You can get a new screen at a reasonable price on ebay and i have written up guides telling you how to dismantle the DS lite and how to replace the screens.
Dismantle guide (inc. tools you will need).
Top screen replacement.
If you need any further help contact me via my profile.
Regards,
SOD69
Feb 12, 2010 | Nintendo DS Lite Console
HOW TO DISMANTLE THE PHONE?
you can only dismantle your phone as much as the manual describes if you click on this :_
http://nds1.nokia.com/phones/files/guides/Nokia_N72-5_UG_en.pdf
Hoped i`ve helped
Dec 01, 2009 | Nokia N72 Cellular Phone
How to dismantle the housing of my P910i without damaging it?
On your flip top key pad, you can remove first the middle cover, it is clip type so no need to un scew, but just be very carefull.
after removing it, you'll see to set of screw, remove it so that you can take out the flip key pad,
turn your unit back, near the camera , there are two small cover there , remove it and you will see two screw, take it out
open the battery cover, remove the battery and sim card and the memory card, inside you will see, again two set of screw, take it out,
now all the screw has been removed
on the side oy your unit where you ca find the scroll, try to plip out the cover usig a twizzer or any pointd object, just flip the cover easily until you where able to remove the topcover completely
now just support the LCD, be very carefull so that may never damaged the flex of your screen
at the back of the screen, there are again another set of screw, remove it slowly, make sure that you supported the screen properly
then you can remove the lcd after taking out the stainless cover protection
removing the board is very simple, just lift the board a little higher enough for you to see the back of the board, there is another flex wire attached to the board and the scroll switch, remove it carefully.
then thats it, you had dismantle your unit
Nov 01, 2009 | Sony Ericsson P910i Cellular Phone
DISMANTLING MY PHONE
how do i dismantle U700 ? can any body help ???
Sep 10, 2008 | Samsung SGH-U600
Ignition replacement
1)First dismantle the batteryleads to avoid electric hazard.
2)Dismantle the steering wheel by taking the centre cover of with a screwdriver carefully,and then take the wires of the centre cover to the horn, loosen the nut 24mm in the middle but dont at first take it off, then wobble,and pull the steering wheel towards your self till it loosens, then dismantle the nut and take the steering wheel off.
3)Unsrew the 2 srews in the undercover and take the upper and undercover off.
4)dismantle the 2 or 3 screws (depending on model) pointing towards you, holding the wiper and blink contacts, dismantle the electric cable connections from the contacts and then remove the contacts from the casing.
5) remove the bolt in the housing (aluminium) holding the ignitionswitch, located from down without a head, needs a hammer and a chisel, can be hard to loosen.
6) turn the key clockwise so it pulls back the slot from the steering axel.
7) remove the electrical cables from the ignition switch.
8) pull the aluminium housing toward yourself sliding it upwards
9) exchange the lock,casing and electrical bottom piece all together and insert a new bolt in the aluminium housing
10) reverse to install
Jul 20, 2008 | 1991 Volkswagen Cabriolet
Conection?
Here is a guide to dismantle an original Nintendo2.gif DS:
How to dismantle a Nintendo DS.
If yours is the NDS Lite, just find this video2.gif in youtube: "Disassembling Nintendo DS2.gif Lite"
And after opening it you can do your work. Make sure the flexible cables connecting the top screen part of your DS are well in place and not broken. Your problem may be only a loosen cable but in case the cable is broken you gonna need a replacement. Be careful not to damage the screen or other sensitive electronic parts on your device and you will be on your way.
Good Luck...
Dec 01, 2007 | Nintendo DS Lite Console
Top screen cracked
Here is a guide to dismantle an original Nintendo DS:
If yours is the NDS Lite, just find this video in youtube: "Disassembling Nintendo DS Lite"
And after opening it you can do your work replacing the top screen. Just be careful with the flexible cables, the new screen and other sensitive electronic parts on your device and you will be on your way.
Good Luck...
Dec 01, 2007 | Nintendo DS Console
Motorola Mobility PEBL U6 Cellular Phone Logo
79 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
