Question about Polaroid i735 Digital Camera
Camera issues:( i have a pink polaroid camera and it fell now it wont turn on at all t hat happens is it beeps three times...help?
  • 3 more comments
  • Anonymous Aug 27, 2008
    i have the same problem.
    last time i sent it to poloaroid it took a year to get repaired!!
  • Anonymous Oct 23, 2008
    my camera is doing the exact same thing! idk what to do and i want my camera back!!! :(
  • barsuk Oct 24, 2008
    I've got the same problem. My lens is stuck halfway out. The battery posts appear to be fine.
  • jalisas Nov 24, 2008
    i have the same problem!!'
    dskjlcbdskhbcf!!!
  • Anonymous Apr 02, 2009
    same exact problem, my camera turns on fine it's just the zoom button doesn't come out..
    it's not even partially out. it's althe way closed! why won't it come back out. i never even dropped the thing!
I had the same problem, stuck lens, 3 beeps and shutdown. You must get pissed off at the camera first. Then bite the lens, clenching it like pliars (you could probably use pliars too), turn the camera on and immediately start pilling on the lens in the outward direction. The tooth grip unstuck the lens and vot it worked. you can take this solution to the bank.
Posted on Oct 24, 2008
    Genius:
  • 1,689 Answers
The beeps means that the battery is dead, but according to your description, there is a possibility that one of the battery pins where removed due to the impact.
if charging or changing the battery did not work, best move will be taking it to a local repair shop to put the part back in place.
hope this helps
Posted on Aug 20, 2008
My son dropped it now it wont open turn it on it beeps three times and shuts off
Unfortunately, with Polaroid cameras, if you hear (3) beeps and it will not power on; this means INTERNAL FAILURE and it's unable to be repaired.
Oct 05, 2009 | Polaroid i733LP Digital Camera
My polaroid i733 turns on the beeps 3 times then turns off when the sd card is in. i have tried formatting the card and camera but it still is not working any help
Had the same problem with our i733 Pink Polaroid. Beeps three times and then shuts off. The reason for this is that the lens is stuck in the partially open position. Because our camera was long past warranty and we bought it for $40 second hand I took the brute force approach. I grabbed hold of the lens and wiggled it from side to side while trying to pull it out (forcefully but being as careful as I could not to damage it) and then there was a small "pop" and the lens came out all the way and the camera was good to go again. Hope this helps.
Jul 25, 2009 | Polaroid i733LP Digital Camera
I631 camera won't turn on
Mine dose that too ugh i got new batteries but it didnt work it dose the same thing i am wondering if it is jammed or something
Jun 02, 2009 | Polaroid i631 Digital Camera
Polaroid i631 digital camera
I have the same camera and the same problem, if you use lithium batteries it keeps the charge longer because regular batteries aren't strong enough. Hope that helps you! :)
Dec 28, 2008 | Polaroid i631 Digital Camera
Pink polaroid i631 camera
Here is the solution for your problem. If you look at your camera at an angle, you will see the zoom lens2_bing.gif is little bent to the side. I want you to put pressure on the cam to snap-it into it's place. After you heard a click, then turn-on your camera. This will fix your cam.
Vicent
Jun 14, 2008 | Polaroid i631 Digital Camera
Polaroid i735 digital camera troubleshooting
the same thing happens to my camera. did u ever end up fixing it
Jun 02, 2008 | Polaroid I533P Digital Camera
Try to put the lense back in, take it to a store (like best buy, circuit city, radio shack) they might fix it for a small price
May 18, 2008 | Polaroid i735 Digital Camera
My batteries died in my pink i733 and when it shut down the "zoom lense" did not recede. i put fresh batteries in it but all that happens is that the green light flashes. it wont come on or...
This can sometimes be fixed if you remove the batteries over night and allow the camera to sit and discharge it should correct this problem. hope this helps.
Mar 28, 2008 | Polaroid i733LP Digital Camera
Polaroid i834 turns off imediately after turning turning on.
I had the same problem until just a while ago, when I realized that the lens was tweaked. It was stuck. So I turned the camera on and gave the inside part a yank before it turned off again. It took me a couple of tries but eventually the lens corrected itself and now my camera works fine. If you do it a couple of times and then start to hear three rapid beeps (sounds like 'be-du-dum') before the other three beeps (beep... beep... beep) then your getting somewhere. Hope this helps.
Mar 04, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Daughter received camera as Christmas gift. Camera beeps three times and does nothing. I guess this camera is only good until the warranty runs out, 90 days. We have tried several new batteries and the expensive rechargeable type also. VERY UNHAPPY!!!!!
Jan 31, 2008 | Cameras
Polaroid i735 Digital Camera Logo
351 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
