Question about Microwave Ovens
1100 watt diplomat microwave
I just purchased subject microwave from Home depot and there was no user manual. Cant figure out how to set a cook time. All the preprogramed button seen to work.
Trying to save myself a trip back to the store.
Hope you can Help.
Thanks
Pam
  • William Miller
    William Miller May 11, 2010
    Please reply back with your brand and model number so we can help you.
  • Microwave Ovens Master
  • 9,174 Answers
Posted on Aug 24, 2008
SOURCE:
My microwave lights up, turntable turns, timer works, everything works but it does not heat or cook anything??
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 16, 2010 | Whirlpool MT4110SKB / MT4110SKQ 1100 Watts...
Question: Can the Tastiwave oven be used?
I don't own one but per the TastiWave Quick Start Guide (which can be downloaded as a PDF document), The wattage must not exceed 1300 Watts. In the Instruction manual and quick cook recipe guide (also a downloadable PDF document) it states that:
"The recipes in this booklet have been written for an 1100 Watt microwave oven. Please adjust your “cook times” accordingly. Microwave must have a revolving turntable and the interior
must measure at least 14” wide x 14” deep x 7 3/4” high".
I hope this answers your question ;-)
Jul 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave cuts off after 3 seconds. Magnatron?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Jan 21, 2010 | GE XL1800 1100 Watts Microwave Oven
My microwave cooktop lights keep burning out. why? i've changed the 10 watt low volt bulbs 4 times in the last 6 mos. each time being careful not to touch the bulbs with my fingers. they will work for...
Are you keeping them on all the time?
Or is the the microwave subject to excessive vibration or door slamming while the lights are on?
Both these conditions are factors in premature bulb failure.
I would also avoid cheap Chinese bulbs from grocery stores and get the GE-specified bulbs either from here online or a local home center such as Lowe's or Home Depot. etc.
Dec 13, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Motor 'Dragging'
The motor run's the same speed regardless of power setting.
If 1000 wats is too much for your poor old electric service, then you better not use your A/C.
As for checking voltage, you need to measure the voltage at the plug with the microwave operating.
Jan 22, 2009 | Sharp R-306LK Microwave Oven
Power level
The numbers DO NOT equal a certain power level Erin. They equal a percentage! This is very confusing. Even the factory reps. can't explain it adequately. I recently replaced my old 600 watt oven with a GE 1100 watt model. The 600 watt unit came with a great cookbook. (I searched the internet but couldn't find one for the GE oven and the factory was no help!) A chicken recipe in the 600 cookbook said cook on high for 30 minutes. Since 600 is approx. half of 1100, I cooked on high for 15 minutes. Result: Uncooked chicken...
The next time I cooked 30 minutes on 50% power (button 5) and It came out OK. I have since used 50% power with meats in cooking bags with good results. Remember to check for correct temp. with a meat thermometer when oven stops. Trial and error is your best test at this point I'm afraid. Also you may want to type "Microwave Conversion Chart" into your browser. You will get some additional information from this. But read carefully!
Ray
Nov 16, 2008 | GE XL1800 1100 Watts Microwave Oven
Cant figure out how to stop the timer before it goes out, or runs out of time
You should be able to hit the Stop pad, but you can download GE owner's manuals and installation instructions here.
If some of the pads on the keypad are not working, you may have a failed keypad, which can be replaced.
If so, please reply back with your model number and let us know.
Sep 28, 2008 | GE XL1800 1100 Watts Microwave Oven
Power cord
If you are referring to the main power cord then you should be able to purchase one at Home Depot/Lowes of most local hardware stores... make sure you get the current rating off the tag on the appliance.. 15Amp or less can use a cord size of 14 gauge.. you should use a 12 gauge for any appliance requiring up to 20Amps ( in your case ..1100 watts minus losses within the system should allow you to use 14 gauge power cord.)
Sep 17, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Is the 1.1 cu ft 1100 Watt model: jes 1139bl sold by Home Depot the same as the 1.1 cu ft 1100 watt model sold by Lowes ? If so, what is the model number of the lowes unit ?
A quick check of the Lowe's Web site show the following GE 1.1 cubic foot microwave models:
JES1142SJ
JES1139WL
JES1139BL
JE1160WD
JE1160BD
If you still have any doubt, I'd call Lowes.
Aug 23, 2008 | GE Microwave Ovens
Microwave Ovens Logo
115 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
