Question about HP LaserJet 1200 Printer
Laserjet 1200 Have had the above for a few years. Today I can't print!!! I've uninstalled and reinstalled. Each time I get msg that printer isn't connected. NOT SO! Only two connects (not USB). Printer shows green light.
    Scholar:
  • 59 Answers
I would recommend that you perform a power cycle by unplugging the printer for 60 seconds then restarting your computer, logging back in....then plug your printer back into your computer, If that does not work I would also try going to www.hp.com clicking Software & Driver Downloads on your right corner of your browser of the HP website then typing in the product which is "Laserjet 1200" then choose your current operating system then download the full driver device.
Posted on Oct 26, 2008
My HP laserjet 1200 prints black instead of greyscale images from a PDF
If you are printing online then you cannot print this document. Because this document is in flash. If you wana print this document then you can use print screen option from pc then you can print exact thing that you want.
Mar 23, 2014 | HP LaserJet 1200 Printer
I downloaded the print driver however, my mac isn't recognizing the driver
Try to uninstall and then reinstall it again but make sure you get the correct printer driver based on operating system and model number of the printer. otherwise it will not work.if still not working, try to download diff driver.
May 24, 2012 | HP LaserJet 1300 Printer
I am using HP Laser Jet 1320 Printer i have a problem while printing as follows PCL XL error Sub System: Kernel Errror: Illegal Tag Operator: 0x1b Position: 6
This appears to be an issue with the driver.
Before replacing the driver though, make sure it isn't just the document itself that is the issue.
Try printing several different documents. If all other documents print, there's a problem with the document itself.
If several, or all documents from multiple sources (not all generated from the same program) then it's time to completely uninstall the driver, and then go to www.hp.com and get the driver specifically for your operating system for that printer and install it.
Remember to reboot between the uninstall and the reinstall.
If this yields the same results, then install an HP laserjet 4 driver on the same port as the currently installed driver using the add printer function in control panel/printers.
print the offending documents through this driver by selecting the HP Laserjet 4 as the printer when printing. If this solves the issue, make the laserjet4 the default driver.
Jun 04, 2011 | HP LaserJet 1320n Printer
HP Laserjet 1200 prints garbage when printing pdfs
it may be you have a virus in your computer
Mar 25, 2010 | HP LaserJet 1200 Printer
Hi - I have HP Laserjet 1200 printer -- today the printer will not print -- print que says "Ready" -- no items are in que -- I have rebooted computer as well as unplugged printer but still not printing --...
check the usb cable or its port ,or try print a test page from the printer by pressing front pannel button 5 second and release. if printng a test pasge its ok the printer
Feb 10, 2010 | HP LaserJet 1200 Printer
HP Laserjet 1100 - prints test page text & image on envelopes
try to uninstall the drivers and reinstall them it should fix it
Jul 20, 2009 | HP LaserJet 1100 Printer
Msg saying unable to start print job. is printer
Uninstall the Adobe PDF viewer and then reinstall it as the printer is respondingto other print commands,so its an issue with the s/w you are using.
Jun 11, 2009 | HP PSC 1410v All-in-One Printer
HP Laserjet 1200 will not feed paper
remove the toner cart and clean the gray roller behind it with alcohol
Jan 28, 2009 | HP LaserJet 1200 Printer
LaserJet 1200 stops working
which port r u use lpt or usb ?
if you printing from lpt port so go to cmos setup and change in
INTEGRATED PHERIPHARALS option and change parallal port mode and set that as a EPP+ECP
Feb 25, 2008 | HP LaserJet 1200 Printer
HP LaserJet 1200 Printer Logo
433 people viewed this question
Ben Johnson
