Question about Canon PIXMA iP1600 Printer
Both lights on printer flashing
Error 6000 after installing new ink cartridge
I have installed a new black ink cartridge (PG-40 Black) in the B slot in my father's Pixma ip 1600 and it will not accept the cartridge. I've set it to grayscale printing, turned on Black printing only and still it says it's the wrong cartridge. It is a Canon cartridge that has been recycled. There is no color cartridge in the printer as my Dad doesn't use it. There's no reason it shouldn't work.
  • Canon Master
  • 6,487 Answers
Cancel all pending print jobs, then turn off the printer , remove all the ink then put them in , turn printer back on and check if you still have the same error.. If yes this can be a faulty printer already...
Good luck........
Posted on Aug 20, 2008
    President:
  • 2,961 Answers
I would buy a genuine new canon cartridge as it sounds as though the chip is faulty and stopping the printer from recognising it as a new cartridge.
  • Canon Master
  • 19,396 Answers
If you set to black and wite it should also print pictures by the way, it does not accept grayscale because it won't be able to print in grayscale photo quality.
  • Ginko
    Ginko Aug 20, 2008
    If your Pixma does not accept the cartridge at all instead try the following:
    Remove cartridge
    Unplug printer USB
    Unplug printer power cable
    Wait ten minutes
    Plug back printer
    Install cartridge
    If it still returns error with lights flashing the cartridge is faulty.
    Not accepting grayscale with only black cartridge may be normal, in black only mode it should still normally print pictures.
  • Ginko
    Ginko Aug 20, 2008
    Pixma cartridge also have a chip with print counter, if the cartridge is refilled chip must be reset. Some non original cartridge can give you troubles sometimes.
How do I fix e07
I assume you have a Canon copier based on the E007 error code. The Fuser fixing film is torn and the Fixing film assembly or the entire fuser should be replaced. Very common issue.......You cannot reset that code without first replacing the part causing the code.
Dec 03, 2014 | Office Equipment & Supplies
Does the canon pixma ip1200 need both the black and the colour cartridges in to print ?
You need both cartridges. It is a paradox that you need both cartridges to even scan on the mfp,s
May 10, 2014 | Canon PIXMA iP1200 Photo Printer
I am refilling the black ink of my canon printer using continuous ink container but the black color doesn't flow into the end of the hose and it didn't print at all, please help
  • Check the printer's power/alarm light. If it is flashing orange, count the number of flashes. Look up the flash code in your printer's user manual to diagnose the problem.
  • 2 Remove and reinstall the ink cartridges if the power/alarm light flashes 5, 7 or 15 times consecutively. This indicates that the issue is a cartridge error, an incorrectly installed cartridge, or an unrecognized cartridge. These errors can be fixed by reinstalling the ink cartridges. Make sure that you are using the correct ink cartridges for your Canon printer.
  • Turn on the printer and open the front cover. The ink cartridge holder should move to the replacement position.
  • 4 Verify that the colored ink cartridge is inserted in the slot on the right and the black ink cartridge is inserted in the slot on the left. Swap the cartridges and reinstall them in the correct slots if necessary.
  • 5 Check to see that both ink cartridges are level with one other and parallel to the top of the ink cartridge holder. If either cartridge is wedged at an angle, gently apply pressure to the cartridge until it clicks into the correct position.
  • 6 Close the front cover of your Canon printer and wait while the printer initializes the newly installed cartridges. This can take a minute or two.
  • Jun 12, 2011 | Office Equipment & Supplies
    Instructions on how to install the printers ink
    Solution: Replace ink cartridge(s) MP210
    Replacing An Ink Cartridge Use the following procedure to replace empty ink cartridges or when an ink cartridge error appears.
    1. After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.
      Note: After confirming that the scanning unit support is fixed into position, release your hands.
      *MP470 shown
    2. Press down on the semi-circular tab (circled area in , above) to release the cartridge and then remove it.
      Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
      *Optional cartridges PG-40 and CL-41 shown in examples
    3. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
    4. Take out a new cartridge from its casing and gently remove the orange protective tape in the direction of the arrow.
      Note: - Do not attempt to reattach the protective tape once you have removed it.
      - Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.
    5. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot*
      *One black cartridge and one color cartridge must be installed in the machine in order for the printer to operate. It does not matter if the capacities (Standard or High) do not match.
    6. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)
    7. Confirm that the ink cartridges are installed properly.
      The ink cartridge is not installed properly.
      The ink cartridge is installed properly.
    8. Fold the scanning unit support and close the scanning unit (printer cover).
    9. Wait until the preparatory operation is complete; it takes about one to two minutes.
    Mar 31, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
    How do I take out the ink cartridge?
      *MP470 shown
    Dec 09, 2010 | Canon PIXMA MP210 InkJet Printer
    I just inserted a black PG 40 ink cart and theres an error coed 5 indicating that i need to insert a color cart. i set my ink stat to black only and gray scale and it still wont pint
    I think you need to have both cartridges in your printer in order to print. If you have put the PG-40 only, the printer can't connect the electric circuit and won't work. Canon's manual explains the error code: the ink cartridges are not installed, or a non supported ink cartridge is installed or the ink cartridges are not installed properly.
    So, my guess is either to pop in a Cl-41 and print or, if both cartridges are in, remove them from the printer and gently clean the electric circuit on them with a dry cloth. You can also clean the cartridge carrier. Put the cartridges back in and try printing. If that doesn't work, try holding the "resume" button (triangle in circle) for about 10 sec for each cartridge, that should reset them.
    Hope that will help solve your problem!
    Apr 16, 2010 | Canon PIXMA MP150 All-In-One InkJet...
    I CAN NOT INSTALL THE INK TO MY CANON PRINTER. WHAT DO I DO FIRST. IT IS A CANON PRINTER MP210
      *MP470 shown
    2. Press down on the semi-circular tab (circled area in <1>, above) to release the cartridge and then remove it.
      <1> The ink cartridge is not installed properly.
      <2> The ink cartridge is installed properly.
    Oct 11, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
    Price of catridge of cannon ip1300
    these are the cartridges used in 1300
    CL-41 FINE Colour Cartridge
    PG-40 FINE Black Cartridge
    click here for cl 41 prices
    http://www.google.com/products?q=cl-41
    Click here for pg-40 prices
    http://www.google.com/products?q=pg-40
    Let me know if you need anything else.
    Thanks,
    Ekse
    Mar 05, 2009 | Canon PIXMA iP1300 Printer
    Ink cartage
    This printer will take either the PG-30 or PG-40 (larger size) cartridges for black ink, and either the CL-31 or CL-41 (larger size) cartridges for color ink.
    Jul 26, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
    Scanner
    Solution: Replace ink cartridge(s) MX310.
    1. Confirm that the printer is powered on
    2. Lift the Scanning Unit (Printer Cover) with both hands, and pull the Scanning Unit Support down into place (A).
    3. Press down on the semi-circular tab located on the top of the cartridge to release the cartridge and then remove it.
    4. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
    5. Take out a new cartridge from its casing and gently remove the orange protective tape in the direction of the arrow.
    6. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot*
    7. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)
    8. Confirm that the ink cartridges are installed properly.
    9. Fold the scanning unit support and close the scanning unit (printer cover).
    10. Wait until the preparatory operation is complete; it takes about one to two minutes.
    Feb 08, 2008 | Canon MX300 Office All-In-One Printer
    Canon PIXMA iP1600 Printer Logo
    126 people viewed this question
    old marine
    old marine
    Corne Viljoen
