Electrolux 30" Self-Cleaning Freestanding Electric Convection Range - White Logo
Posted on Jun 17, 2011
EW30EF65GS Hot warning light will not shut off for burners & oven after trying self clean cycle
2 Related Answers
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Jun 21, 2009
SOURCE: ge self cleaning oven wont shut off
replace the oven control circuit board.
Anonymous
  • Posted on Apr 19, 2013
SOURCE: Door won't open after Self Cleaning Oven
if you are facing this problem still yet, I suggest that call a service guy to fix it and turn off the power.
Oven (indicator light) clicks on and off
Start the self clean and then move the bar over so it will lock and complete the self clean cycle.
I have a whirlpool GW395 gas stove with a problem. When you first turn it on it lights, it will stay lit for about 45 seconds then the burner will go off , after you let it set for about 45 seconds it...
The usual problem with these ovens is the oven burner itself. the burner will click 3 times and usually lights but after a few minutes shuts down and will no light again until you reset the control. If this is happening then try replacing the oven burner. It comes as one unit the burner assembly and electrode. Part # 8191123. If this doesn't work then it coould be your spark module unit. This is about twice the cost or more.
Can I use the stovetop when my oven is self cleaning?
Yes you should be able to but there are a couple things to consider. When the oven is in the self-cleaning cycle the heating element reaches a very high tempature and runs for extended periods. So if you have a couple top burners going the amperage draw could possibly trip the electrical breaker. Also there is a lot of heat generated around the range during the cleaning cycle and it may be to hot to actually work around the range. There are some ranges that dis-able the top burners during the self-clean cycle. If that is the case with your range then the answer would be no. The way you would know for sure is to try them during the self-cleaning cycle or consult your owners manual.
I have model GS563LXSS...all of a sudden the oven
It is not good to do the self clean. The electronics take a beating. Probably the ignitor went out. The oven gets too hot.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1helpful
Can I clean a TruTemp oven with soap and water without ruining it?
Yes you could clean it.
Check few details :-
t the bottom of this post you will find the web address for your ranges manual and the self clean system is in side this manual.
How to self clean
If your model has a door latch, never force the latch handle. Forcing the handle will damage the door lock mechanism.
The oven door must be closed and all controls set correctly for the cycle to work properly.
Before a Clean Cycle
For the first self-clean cycle, we recommend
venting your kitchen with an open window
or using a ventilation fan or hood.
Remove any broiler pan, broiler grid, all
cookware, probe and any aluminum foil
from the oven—they cannot withstand the
high cleaning temperatures.
NOTE:
If your oven is equipped with nickel oven
shelves, remove them before you begin
If your oven is equipped with gray
porcelain-coated oven shelves, they may
be left in the oven during the self-clean
cycle.
Soil on the front frame of the range and
outside the gasket on the door will need to
be cleaned by hand. Clean these areas with
hot water, soap-filled scouring pads or
cleansers such as Soft Scrub®. Rinse well
with clean water and dry.
Do not clean the gasket. The fiberglass
material of the oven door gasket cannot
withstand abrasion. It is essential for the
gasket to remain intact. If you notice it
becoming worn or frayed, replace it.
Wipe up any heavy spillovers on the oven
bottom.
Make sure the oven light bulb cover is in
place and the oven light is off.
IMPORTANT: The health of some birds
is extremely sensitive to the fumes given
off during the self-cleaning cycle of any
range. Move birds to another well ventilated
room.
NOTE: Use caution when opening the upper
oven after the self-clean cycle has ended.
The oven may still be hot.
How to Set the Upper Oven for Cleaning
On models with Gas/Control Lockout,
touch and hold the Gas/Control Lockout
pad for 3 seconds to turn it off.
NOTE: The surface burners must be turned
off prior to the self-clean start time.
If your model has a latch, latch the door.
Touch the Self Clean pad.
Using the number pads, enter the
desired clean time, if a time other than
4 hours is needed.
Clean cycle time is normally 4 hours. You can
change the clean time to any time between
3 hours and 5 hours, depending on how dirty
your oven is.
Touch the Start pad.
On models without a door latch, the door
locks automatically. The display will show
the clean time remaining. It will not be
possible to open the oven door until the
temperature drops below the lock
temperature and the LOCKED DOOR
light goes off.
The oven shuts off automatically when the
clean cycle is complete.
When the LOCKED DOOR light is off,
slide the latch handle to the left as far
as it will go and open the door. If your
range does not have a latch, the door
will unlock automatically.
The words LOCK DOOR will flash and
the oven control will signal if you set
the clean cycle and forget to close the
oven door or forget to latch the door
on models with a latch.
To stop a clean cycle, touch the Clear/Off
pad. When the LOCKED DOOR light goes
off, indicating the oven has cooled below
the locking temperature, unlatch the door
(on models with a latch) and open the door
How to Delay the Start of Cleaning
Make sure the clock shows the correct time
of day.
the door.
desired clean time.
Touch the Delay Start pad. The earliest
start time you can set will appear in the
display.
Using the number pads, enter the time
of day you want the clean cycle
to start.
locks automatically. The display will show the
start time. It will not be possible to open the
oven door until the temperature drops below
the lock temperature and the LOCKED DOOR
light goes off.
The words LOCK DOOR will flash and the
oven control will signal if you set the clean
cycle and forget to close the oven door or
forget to latch the door on models with
a latch.
pad
(on models with a latch) and open the door.
After a Clean Cycle
You may notice some white ash in the oven.
Wipe it up with a damp cloth after the
oven cools.
If white spots remain, remove them with a
soap-filled scouring pad and rinse thoroughly
with a vinegar and water mixture.
These deposits are usually a salt residue
that cannot be removed by the clean cycle.
If the oven is not clean after one clean cycle,
repeat the cycle.
You cannot set the oven for cooking until
the oven is cool enough for the door to
unlock.
While the oven is self-cleaning, you can
touch the Clock pad to display the time
of day. To return to the clean countdown,
touch the Cooking Time pad.
If the shelves become hard to slide, apply a
small amount of vegetable oil or cooking oil
to a paper towel and wipe the edges of the
oven shelves with the paper towel.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
GE Profile XL44 Spectra gas oven
try to hold down the light switch on the door set it up for another cleaning hit start when oven clean door lock showes hit cancel if that doesnt work try unplugging it for three min fyi the doors can take up to an hour to un lock after cleaning its so it dont burn your face off from the intense heat after cleaning some take 2
Problem w/burners & lights after self clean
You may want to re-seat the right two cooking elements, in case there is poor electrical contact. When you have them removed, clean the contacts with denatured 91% alcohol and a Q-tip. The removal procedure follows.
First, unplug the range.
LIFT–UP PORCELAIN COOKTOP
To lift:  When cool, grasp the cooktop front
edge.  Gently lift up until the two support rods
snap into place.
To lower:  Hold the cooktop front edge and
carefully push back on each support rod to
release.  Then lower the top into place.
COIL ELEMENTS
➢When an element is on, it will cycle on
and off to maintain the heat setting.
➢Coil elements are self-cleaning. Do not
immerse in water.
To remove:  When cool, raise element.  Carefully pull out and away from receptacle.
Check them for damage. They do wear out.
To replace:  Insert element terminals into receptacle.  Guide the element into place. Press down on the outer edge of element until it sits level on drip bowl.
COIL ELEMENT SURFACE
➢ On Canadian models, the two front elements will not operate during self-clean.To prevent the risk of electric shock or fire, never line drip bowls with aluminum foil.
If that does work, you may have a faulty control panel. In that case, call Maytag at the number below.
Maytag Customer Service
533 Benson Road
Benton Harbor,MI 49022
(800)688-9900 U.S.
(800)688-2002 Canada
Top Electrolux Kitchen Ranges Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
john h
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
