Question about Samsung HLP5067W Television
Samsung hlp5067w will not start up
My samsung hlp5067w makes a loud humming noise when you try to turn it on and then it kicks out and tries to restart over and over,you have to unplug it to get to stop. Any ideas?
  • 1 more comment
  • Anonymous Sep 27, 2008
    Put in new lamp BP96-00826A. New lamp version with adapter. Worked fine for a day, now makes loud noise before cutting off. Both fans appear to work. ????????????????
  • kchofers Dec 24, 2008
    Mine is a HLP5063W, assuming it is the same thing. Mine will sometimes make a loud hum and then shut off. Both fans are fine as is the bulb. I disconnected all three and it still make the noise.
  • heidsms Mar 27, 2009
    When I try to turn on my samsung hlp5067w it will not turn on. I get this loud buzzing noise like a motor dieing and no picture. Not sure what to do or who to call to fix?
  • 3 Answers
In most cases its the color wheel. If you turn off the tv you will hear the noise go away before the fans stop.
Posted on Jul 31, 2009
Bp94-02084a is what you probably need.
My tech quoted me 635 to fix it.
Posted on Aug 21, 2008
How do I fix loud humming noise in my DLP HLP4663W 42 IN Samsung TV?
I would start by checking all the cooling fans to see if one is dirty or possibly failing.
Aug 30, 2015 | Samsung HLP4663W 46-Inch Widescreen DLP...
Loud humming or buzzing noise have picture but flashes all different colors resets and goes off after awhile good pic after that
The tv problems and causes are 100% is the tv colors wheel it is causes and the tv problems.The tv are having humming or loud buzzing noises sounds are the causes of the tv colors wheel going off and out control of it motor mount and spinning in at high RPM speed and different colors showing up or flahes of black and white color in the tv back ground.The tv colors wheel must have to be replace.Best hire a tv tech to do the replacement of the tv colors wheel,because have to take out many mechanicals parts before can even come to the tv colors wheel is self to replace it.
Aug 19, 2011 | Samsung HLP5067W Television
I get a loud humming noise . The dryer works good but makes a loud humming noise when it's working .
The motor is going bad and this will make that loud humming when it is running...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 25, 2010 | Maytag Dryers
My whirlpool ler4634 electric dryer has electricity running to it but when turned on, the drum does not rotate. It only makes a loud humming noise. What can be the problem?
It sounds like you have a blown motot try holding down the door switch and push start and turn drum at same time see if it kicks in
Sep 22, 2010 | Whirlpool LER4634J Electric Dryer
Loud humming noise
try using a spirit level to make sure unit is sitting square,the most common cause of noise.....(also make sure its not touching the wall....)
Apr 13, 2010 | Whirlpool ED2FHSS Side by Side...
Motor making loud humming noises and kicks out. Could this be a capacitor on the motor going bad ? This doesn"t happen all the time, but frequency is increasing.
this is the motor overheating and, the overload shutting down the motor: check to see if the motor belt is binding
Jan 23, 2010 | Washing Machines
Making a lot of noise
Sounds like a bearing in the cooling Fan
Thanks for using FIXYA
Sep 21, 2009 | Samsung DLP HL-P5663W 56" TV
No screen or sound
there are only two moving parts in your tv a fan and color wheel, that noise is classic of a color wheel, I had the same tv and problem. I replaced it myself but it is a little tricky. part is around $175.
Mar 06, 2009 | Samsung HLP5067W Television
Hlp5067w won't come on & I've replaced the bulb.
If you hear a clicking sound in your bulb area like an arcing sound it's probably your ballast trying to fire up your bulb. new ballast easy to replace and around $100.
Nov 14, 2008 | Samsung HLP5067W Television
Samsung HLP5067W Television Logo
283 people viewed this question
Henry  Thomas
Henry Thomas
