Sylvania LC370SS9 LCD TV Logo
Posted on Jun 17, 2011
How do you Wall mount a Sylvania LC370SS9 TV - Sylvania LC370SS9 LCD TV
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Jun 17, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1366
Points
15
If you have a wall mount kit, it is fairly simple. You just find the place that you want the tv to go and find a nearby stud to install the mount. After that you will want a second person to help with either holding the tv up or screwing in the tv to the mount. There are four screw holes in the back of the tv to screw through the wall mount plate into the back of the tv. Check to make sure it is stable, then you have successfully installed the tv to your wall
Lost screws for Mounting. Need to know size screws for mounting
To know more about this, you have to download the repair manual of this set. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Disassemble procedure to many popular brand TVs are given.
1helpful
I have a Sylvania lc370ss9 hdtv. When I turn the power on the set remains black, the power indicator flashes green and the power button will not shut it off.
The set has failed to come from standby to on fully---could be the power board but if it will not power off usually it is elsewhere.
Time to have a qualified shop take a look a get a estimate.
Don't know the universal remote code. Tv did not come with a remote Sylvania LC370SS9
hi! i have here a couple of codes for your tv! just try them, 1004, 1007, 1018, 1027, 1047, 1056, 1057, 1059, 1060, 1061, 1103, 1124, 1145, 1150, 1153, 1279, 1296, 1387, 1464, 1483,1046, 1465, 1150, 2092, 1464, 2408, 1465, 2260, 1027, 2064, 3105, 1124, 2078, 3088, 1296, 2213, 3147, 1145, 3095, hope this helps!!!! goodluck!!!!
WHAT IS DIRECT TV CODE FOR SYLVANIA LC370SS9
hi! i have here a couple of codes for your tv! just try them 1004, 1007, 1018, 1027, 1047, 1056, 1057, 1059, 1060, 1061, 1103, 1124, 1145, 1150, 1153, 1279, 1296, 1387, 1464, 1483,1046, 1465,1150, 2092, 1464, 2408, 1465, 2260, 1027, 2064, 3105, 1124, 2078, 3088, 1296, 2213, 3147, 1145, 3095, hope this helps!!! goodluck!!!
IR interference from LCD TV..on comcast dvr ...remote for dvr box will not work if i have the tv on..it a sylvania ......37" LCD HD TV model number LC370SS9
I have the same issue. I've tried every version of Comcast box there is available. Nothing. Next I'm trying taping off the Sylvania IR and running the volume through an old receiver I have. That is, of course, that there isn't a solution posted here first. Will report back later.
4helpful
Sylvania lc370ss9 remote problem, comcast
you have to turn off the power save setting
2helpful
3answers
Need RCR450 Code for Sylvania LC370SS9
Here's the manual =>
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr450-manual.zip&area=other
Sylvania TV codes are 1004, 1006, 1008, 1019, 1062, 1068, 1069, 1075, 1076, 1088, 1130, 1132, 1134, 1183, 1189, 1251 listed in back of the manual.
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
