Question about Brother MFC-8840DN (Bundle) All-In-One Laser Printer
Brother 8840dn Front auxillary tray and assembly hinge cracked and I am in need of a new or replacement part. This is the part that lowers down from the front and holds and feeds the additional paper and envelopes etc. Any place special I should look for this part/ Would appreciate any help here. Thanks, Mike Z
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 56 Answers
The door or the cover part numbers:
LJ7587001 MP TRAY ASSY
LM2313001 MP FRONT COVER ASSY
Hope this helps. Email me if you need a price on this part jtuminaro@officetechservice.com
Posted on Jan 15, 2009
How to change printer cartridge on Brother Intellifax 1270e
After raising the rear cover (hinged at the back), lift up on two matching plastic levers, one at each side. Raise the print assembly, also hinged at the back. Lift out the print cartridge. Note the arrow molded into the top to show which way the new cartridge should be inserted.
The complete print cartridge is a PC201, and you can buy it from www.brothermall.com if you can't find it locally. They also sell boxes of two or four rolls (PC202RF, PC204RF), if you want to save a buck by refilling your existing cartridge.
If the fax is printing fine on one side, but fades to blank on the other, the problem is not your printing cartridge, but one of the latching levers you lifted to access it. Sometimes one cracks at the hook at the bottom. It still holds the print assembly down, but not tightly enough to print on that side. The crack is invisible until you pry at the hook with a fingernail.
Oct 06, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
Printer repair brother mfc 8840dn
To Clear the error follow the procedure
1:) Turn Off the printer
2:) Hold down the menu option on the front panel and turn on the power while the menu button is still pressed
3:) Release button after 5 seconds (after the Please Wait message)
4:) If error still occurs Press 91
5:) If it still ocurs press 99
This should clear the error.
May 07, 2010 | Office Equipment & Supplies
Faceplate of door by lower L/H hinge cracked. How do I remove the door to replace the Faceplate?
Front doors are attached inside the microwave at the top and bottom of the oven cavity. Top case has to come off using, likely, security torx screw drivers.
Remove the top hinge.
Remove the bottom hinge.
Door falls off.
Replace the front panel of the door.
Reinsert the lower hinge with the door, close and latch the door.
Holding the door firmly to the microwave, tighten the door hinge. Replace the top hinge.
(On some units, both hinges need to be installed at the same time. Use masking tape to hold the lower hinge - makes it easier.)
Apr 19, 2010 | Sharp R-1490 Microwave Oven
Brother MFC8440 - Left Hinge Assembly broken
Brother will not sell to end users, contact a Brother Dealer in your area.
Jul 26, 2009 | Brother MFC-8440 All-In-One Laser Printer
How to replace Hinge assembly of Automatic Document Feeder
You can try to get a hinge @ a local authorized brother dealer. I just got mine for 20 bucks, I think that the guy ripped me off, but I needed. Once you get it, it is very easy to replace. 1St, replace the old one by removing the screw in the back of the hinge (back of printer). then pretend that you are lifting the whole automatic feeder up. At this point you will see the right hinge looks likeit it coming out. Don't pull it out completely. Just pull it enough that you can flip the feeder enought so you can uncrew the 3 screw attached to the feeder. Once you remove the broken part, install the new hinge. make sure that you screw hinge first before you slip it down to the bottom hole then screw the hinge to prevent it from moving.
PS: try not to flip the feeder too far back
good luck
Mar 23, 2009 | Brother MFC-8440 All-In-One Laser Printer
Brother Fax Machine MFC8840Dn broken hinge
you can actually by the hinge itself for only 27$
the website is here: http://www.precisionroller.com/search.php?q=brother+mfc+8440+hinge&x=0&y=0
Mar 19, 2008 | Brother MFC-8840DN (Bundle) All-In-One...
Brother MFC 7820N
just order a new hinge and replace it yourself! why buy the entire lid/cover?
Aug 17, 2007 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-8840DN (Bundle) All-In-One Laser Printer Logo
66 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
