Turn the unit on and open a browser window on your computer. Be sure that you've selected the Name of the router, default is linksys, as the network that your computer is connected to. Browse to the Admin page of the router by typing in its IP address, default is 192.168.1.1. You should see a logon screen. The unit should ship with a default password, which is admin. That is, you leave the username field blank and type the word 'admin' (no quotes) into the password field. (Once you are logged in, you can change the password for logging into the router thru Administration --> Management. You should see a two boxes to verify the new password that you would like to create.) For creating a password for the secure Wireless connection, go to Wireless --> Wireless Security. To set up the Wireless security, tho, I think you'll have to connect with an ethernet cable. You can then walk thru the setup. Use WPA2 as the security, if possible.
SOURCE: setting passwords on dell truemobile wireless router
Hello, The default address for the dell truemobile 1184 is 192.168.2.1 If you have changed it and forgot, unplug the router (elec) for 5 seconds. This will reset it to default. The default SSID is "wireless". If a user ID and/or password is asked for enter "admin". Here you can change settings, enable broadcast, change SSID, enable WEP or WPA. Hope this helps.
