Question about Sony KP-51HW40 51" Rear Projection Television
Sony KP51HW40 blurry screen will not flash focus, intermittent problem, works OK then goes blurry with siluettes
  • citXdrv Sep 12, 2008
    same thing here. Ill go six month fine then six months with blue offset (and flash focus trying but not working). It seems like a bad connection somewhere and if anyone could shed some light to where I need to look inside the tv...
  • citXdrv May 11, 2010
    please help : I tried messing around with convergence settings in service mode, I have a error code if i try to flash focus (low SO ??). and if i try to adjust it manually : red and green respond fine but blue keeps this hourglass shape and do not budge... keep in mind the problem comes and goes (i was fine for a couple months at a time).
    Genius:
  • 2,920 Answers
Your convergence is trying to go out
Posted on Aug 30, 2008
VIEW SCREEN IS SO BLURRY I CAN'T TELL WHAT ITS SHOWING.
Is it the viewfinder (that you hold up to your eye) or the screen that's blurry?
If the viewfinder is blurry, there should be a diopter adjustment to fix it, probably right above the rubber eye cup.
If the screen is blurry, you should take some pictures and video and view them on a computer. I they are sharp on the computer but blurry on the camera screen, there may be a problem with the screen and you may need to take it in for repair.
If the pictures are blurry on the computer as well, the camera may not be focusing properly. If you can't focus manually, or the camera can't focus when auto focus is turned on, you have good light, and aren't too close to your subject, then it may need to be serviced.
Feb 26, 2011 | Sony Cyber-Shot DSC-F717 Digital Camera
42" sony projection with blurry picture
Remove front bottm panel and behind it should be the Focus/Screen control block replace it.
Mats 1-800-628-1118
May 09, 2010 | Sony KP-51HW40 51" Rear Projection...
Focus issue after replacing convergence IC's
pull the fron grill off the set then remove the cardboard covering the hole that is in the front of the set you will find a square box that has 6 controls on it adjust the focus for the red, blue and green crts, do not adjust the three marked screen control.
Sep 10, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Screen is flashing E:61:10 and subjects are blurry, will not operate - camera was in the sand
Hi!
The focus is stuck. The lens have to be cleaned or replaced. Contact your local Sony service center or if they ask too much, feel free to contact me at toms.safranovs@gmail.com
I work in a Sony service center.
Tom
Jul 17, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
My view screen is blurry and E:61:10 is flashing
Hi!
It's a focus error. The lens unit has to be cleaned or replaced. Contact your local Sony service center, but if they ask too much, you can contact me at toms.safranovs@gmail.com and I will give you a good price.
I work in Sony service center.
Tom
Jul 13, 2009 | Sony Cyber-shot DSC-T70 Digital Camera
View finder
Ok. On your viewfinder, there might be a round dial. Turn it to adjust focus. Otherwise, sometimes viewfinders are like that... blurry, especially electronic.
Apr 19, 2009 | Sony Cyber-shot DSC-H5 Digital Camera
Sony kp51hw40 projection tv screen turns blue
The blue CRT needs replacement. You can get a replacement CRT at the following link.
http://servicemanuals.vstore.ca/
Feb 02, 2009 | Sony KP-51HW40 51" Rear Projection...
Blurry picture
If you know where the fly back is, ok open the casing and see at the back of the fly back, there are two knobs, one for the focus and the other is for the brightness. Try twist both and see which one is for the focus. Ok, from the focus knob try adjusting until the fuzzy sight disappears. Try this, I usually do it to screens with blurry appearances.
Nov 10, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Blurry picture
1)Remove rear cover = clean RGB lens with soft cloth
2)Remove front speaker grill cover and access panel
Locate screen / focus block = adjust RGB focus controls
3)Last,if needed, unlock each focus lens cap = adjust then lock
................................................T.
Dec 01, 2007 | Sony KP-51HW40 51" Rear Projection...
Blue screen of death on a tv??
this could be three differnt things
1. the crt itself could be bad
2.the vertical ic on the crt board
3. the focus pack or focus block
Sep 19, 2007 | Sony KP-53V45 53" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
64 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
