Question about Aurora Electronics AS1015CD Cross-Cut Shredder
Aurora AS1015CD will not run in reverse or forward/not jammed
My shredder is about a year old. I have never had any problems with it. Today I go to use it and it is dead...won't shred, and it won't reverse.
Any suggestions?
SOURCE: Fellowes P600C-2 Motor runs in reverse, but not forward
On mine a tooth broke from a drive gear. I am trying to find somewhere where I can replace this part.
Posted on Dec 07, 2007
SOURCE: Shredder suddenly runs only in reverse
I had the same thing happen to me today - I had just shredded a ton of stuff, emptied the bin 4 times - after emptying the bin the last time, all of a sudden it would only go in reverse. I pulled out my instruction manual and it says the motor might overheat and to let it cool down and try again. I let it cool down for about 1 hour, cleaned out the gears and dusted off the sensor and it started working even better than it did before.
Posted on Jan 30, 2008
SOURCE: Shredder won't shred any more.
You might have broken the actual mechanism enabling it to move forward. To be honest, your easiest solution would be to buy another shredder rather than attempt repair if this is the case, they're so cheap now.
Posted on Mar 27, 2008
SOURCE: Aurora as1015cd
Very simple. It automatic mode, a small flag sensor is lifted when it paper enters the rollers. When this happens, this will turn on the shredding rollers. When the paper passes the flag sensor, the rollers stop turning.
What's happening is that a small amount of debris is stuck at the sensor. If your model has a reverse switch, try using that. If not, try manually pulling the stuck threads from the bottom. Once you get it unclogged, that should help.
The sensor is located in the middle of the rollers.
Posted on May 12, 2008
  • 329 Answers
SOURCE: shredding
check door safty switch or is the bag or box full that has a switch also? just a suggestion.
Posted on Jun 24, 2008
Looking for troubleshooting manual for Aurora Paper Shredder AS1015CD.
There is a trouble shooting on their web site for Auror!
I was having the same problem with my shredder. I called customer service; I was informed it was the gears on the inside of my shredder. My shredder is no longer under warranty. However, she is mailing me out the part I need for a small fee. Their customer service number is 1-800-327-8508 in the USA and international only 1-310-793-5650. I do hope this help you!
May 27, 2011 | Aurora Electronics AS1015CD Cross-Cut...
Hi, my Aurora AS1002MSB is jammed and it will only go in reverse. Is there any way to fix it?
Move the power switch to AUTO (l) position and depress the manual forward button for five seconds to clear paper blockage. Make sure the paper is engaging sensor located in the center of the shredder opening.
Good luck....
Apr 08, 2011 | Aurora Electronics AS1015CD Cross-Cut...
My Aurora (AS1015CD)sounds like somethimg is caught up in the blades like a staple or something ..not sure. it will shred a little before it starts to smoke, when I run it in reverse, it will run, sounding...
Mar 16, 2011 | Aurora Electronics AS1015CD Cross-Cut...
THe shredder goes in reverse, but not forward. I can see some paper in the opening, but none in the teeth. Is there anyway to take apart the top?
I was having the same problem with my shredder. I called customer service; I was informed it was the gears on the inside of my shredder. My shredder is no longer under warranty. Don't open your shredder to repair it yourself because it will void your warranty. However, she is mailing me out the part I need for a small fee. Their customer service number is 1-800-327-8508 in the USA and international only 1-310-793-5650. I do hope this help you!
Feb 21, 2011 | Aurora Electronics AS1015CD Cross-Cut...
It just works in reverse and won't run forward lioght on but will not run...
same thing happened with ares my brother went to shove an envelope through the thing and it was too much, it stopped working but still worked in reverse. so i took it apart and the reason why it wont work is because by the arrow there is a little peg that sticks out and when paper passes through it it flips down like a light switch and turns on but if it breaks what is going to tell the thing to turn on. im sorry to inform you but when this happens it is toast.
Feb 13, 2011 | Aurora Electronics AS1015CD Cross-Cut...
How do I oil the shredder?
Place some shredder oil on paper and run the paper through the shredder. This will lubricate the cutters.
Feb 06, 2011 | Aurora Electronics AS1015CD Cross-Cut...
Our Aurora AS1712X paper shredder is jammed in a couple of places with paper so badly that we cannot free the jam and the tooth wheels cannot turn freely. Is there an easy way to clear the jam?
Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 20, 2010 | Aurora Electronics AS882C (Cross-Cut)...
Aurora Papaer Shredder circuit board problem?
It just sounds like a paper dust problem.
use canned air to completely clean all sensore.
Oct 23, 2009 | Office Equipment & Supplies
Shredding
Jun 24, 2008 | Aurora Electronics AS1015CD Cross-Cut...
Aurora ASa015CD shredder
any wierd noise when it goes in reverese?
is forward dead or intermittant?
most likely if reverse is perfect but forward is dead,, your control board has blown mosfets , power drivers for forward operation
Heres a few sites that have gears n boards another that has manuals you may have to call or email as not all parts are listed on website
http://www.compax.com/shredders/parts.html
http://wheelermachines.com/manufacturer.html
http://www.manualsonline.com/ex/thread/view/idThread/1735067
n.
new control board needed or buy a new unit depending on cost of board.
Jun 21, 2008 | Aurora Electronics AS1015CD Cross-Cut...
Aurora Electronics AS1015CD Cross-Cut Shredder Logo
91 people viewed this question
Top Aurora Electronics Office Equipment & Supplies Experts
k24674
skiffy99
skiffy99
Level 1 Expert
Dabu42
Level 1 Expert
Are you an Aurora Electronics Office Equipment and Supply Expert? Answer questions, earn points and help others
