Question about Lexmark T640 Laser Printer
Paper jam check drawer two t640 printer
Help how to fix
    Problem Solver:
  • 14 Answers
Hello there,
If you are getting "Paper Jam check drawer two message" I would suggest you to check for any paper stuck inside the paper drawer two. If you don't see any paper jammed inside drawer two, you might also want to check out if its is stuck anywhere in the paper path. Removing the paper jam should fix the issue. Try cleaning the pick rollers (the rollers which pick the paper) in drawer two. This should help fixing this issue.
Merry Christmas!
Posted on Dec 20, 2008
Printer is saying paper jam in second drawer code 24210 but there is no jam
Looks like worn picktires. You'll have to replace them. Partnumber: 40X0070
Feb 27, 2011 | Lexmark T640 Laser Printer
Hi, my lexmark T640 is saying 202.06 paper jam, check rear door. i have opened it and there is no jam, there is no paper anywhere and have pulled all the trays out and there is no jam. what do you suggest?
This jam is refering to back door, jam in fuser (hot bit) Double check no paper is wraped around fuser rollers.
These machines have a fuser at rear if you look at he fuser from the back, on it you will see, two thick fuser rollers (ones rubber), paper runs threw these then it hits a little black switch (your machine thinks this switch is activated) and then a series(3,4) of small rubber exit rollers, this switch (between middle and left) can get damaged it also likely that a piece of paper is concertinaed in fuser.
Oct 20, 2010 | Lexmark T640 Laser Printer
Is there a way to take off the back of the printer where the paper comes out. Paper is jammed in the rollers and can't get to it.
Here's an article on A 202.xx (x = any number) Paper Jam Message Is Appearing on a Lexmark T640, T642, or T644 Printer. This might help you remove the paper jam in your printer. Just click on this link: http://bit.ly/9LXkka. Hope this helps.
Jul 03, 2010 | Lexmark T640 Laser Printer
Error message 241.10 but there is no paper jam. Is there a way to override or fix this error message?
This is what I think is the solution. Uninstall your printer driver and then restart your computer. Then install it again.
Apr 03, 2010 | Lexmark T640 Laser Printer
How do I clear a paper jam in the duplexer of Lesmark T640
Hello. There is an article in the Lexmark website about how to remove jammed paper in the duplexor in Lexmark T640. Included are graphics for you to easily follow the instructions. Just click on this link: http://bit.ly/caGZto . Hope this resolves your problem. Good luck!
Mar 17, 2010 | Lexmark T640 Laser Printer
KEEPS SAYING PAPER JAM AND THERE ISNT ONE. DOESNT SEEM TO WANT OT PICK UP PAPER
ok im going to guess here that you are getting a 201 paper jam error with no paper in the printer. this would indicate a bad main motor drive replace it.
if its a 202 error check the 2 sensors on the fuser for stuck flags
if its a 241 error clean the pick wheels with aresol elctronic contact cleaner to remove the glue build up from them. or replace them
Dec 04, 2009 | Lexmark T640 Laser Printer
T640 gives 242.10 error no paper jam found does not happen all the time I open tray 2 , close and hit check works will happen from tray 2 only
Hi, most possible cause are worn rubbers tires in the papertray. You'll have to replace them. Partnumber is 40X0070. For now you can try to take the off and mount them inside out.
Good luck, Gerrit Jan
Jul 17, 2009 | Lexmark T640 Laser Printer
Lexmark T640 won't print on label sheet a SECOND time...
try changing feed rollers. For a quick fix, remove the rubber rollers and flip them inside out. It should work
Jan 28, 2009 | Lexmark T640 Laser Printer
Lexmark t640: paper jam in the back door. I can see the edge of the paper. How do I release the tension on the rollers so I can slide it out? Now it is in there tight and to grab it just tears off a piece...
Hope this helps....
Explanation of the paper jam message
A 241.09 Paper Jam message indicates that the printer thinks a sheet of paper has jammed at the front of the printer. The jammed sheet of paper is most likely to be found in one of the paper trays or under the toner cartridge.
NOTE: If you select Show areas on the operator panel, you can view one or more images to help you locate and clear the jam.
Clearing the jam
To resolve the paper jam message, you must first clear the entire paper path. To access the jam area, you will need to open one or more of the paper trays. Follow the steps in the table below to help you locate and clear the jam.
Step Action Image 1 Open the printer paper tray (tray 1), and remove any jammed media you find there. pattlnk_10222007_1922-enus28872_24109paperjam1_t64x_en_us.gif 2 Open the front cover and remove the toner cartridge. Examine the area inside the printer and remove any jammed media you find there. pattlnk_10242007_159-enus28872_24109paperjam5_t64x_en_us.gif 3 If you have a duplex option installed, also remove the duplex access tray and remove any jammed media you find there. pattlnk_10302007_1559-enus28860_24x17paperjamduplex_t64x_en_us.gif 4 If you were printing from an optional paper tray, such as tray 2 or tray 3, open any optional trays, starting at the top, and remove any jammed media. Pull the print media either up or down. If it does not pull easily one way, try the other way pattlnk_10222007_1957-enus28872_24109paperjam3_t64x_en_us.gif 5 If you are printing from an optional 2000-sheet feeder, open the front door. Press the elevator button (A) to lower the tray. Remove any partially fed media from the feeder.
NOTE: Make sure the stack of print media is straight and pushed all of the way into the feeder. Incorrectly loaded paper is the most common cause of paper jams from a 2000-sheet feeder option.
For a larger image, click here. 6 Finally, reinstall all of the paper trays and press the pattlnk_10222007_2117-select_button.jpg button to try printing again.
NOTE: You may receive a different paper jam message informing you that another sheet of paper is jammed elsewhere in the printer. If this occurs, the error code will indicate the location. Click here for a diagram showing the error code locations. The paper path will vary, depending on the paper source and number of paper feed options installed.
Remove any jammed sheets of paper you find and try printing again.
Dec 12, 2008 | Lexmark T640 Laser Printer
Paper jam
Call me at 336-516-5070 I had the same problem its a very simple fix. I cant explain it in words.
Jul 13, 2008 | Lexmark T640 Laser Printer
Lexmark T640 Laser Printer Logo
1,050 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
