Question about Kenmore Elite 45986 Front Load Washer
Should I see water in my machine when it is washing?
I can not see water in my front loading machine (HE3) when it is washing. Should I see some?
    Genius:
  • 1,028 Answers
May see some but not much..front loads only use 4-6 gallons and is adj as water is absorbed by clothes ..a typical top load will use 25 gallons or more per fill thats 50-55 gallons per wash verses 25-30 for front loads also you should see very few suds ..be sure to use HE detergents to prevent oversudsing
Posted on Aug 21, 2008
Need to download manual for HE3 front load washing machine
go to appliancerepairplanet.vstore.ca and they will help u in this matter i hope this will help u
Dec 01, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I have a Kenmore Elite Quiet Pack 2, HE3, model number 110.45872 400 front loading washing machine. When I start a cycle it stops and letters H and F alternately show on the screen. What does this mean?
i just had this problem... i did the following (should only take 30 minutes) take the panel off, that is located below the front door,, there are 3 small srews located at the bottom that hold this... then you will see the water pump, the water pump has a access srew plug, when you unscrew this, its like a filter, you may see stuff, like coins, socks, etc, remove and clean it, then put everything back... this should fix the issue.
Oct 11, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washer fills with water after the cycle is over
check the pressure senser ,if this ok check the pcb assy
Jun 20, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Front Load Washing Machine Filling On It's Own
the inlet valves are shot. what happens the coils in the inlet vales can no longer hold the water from going into the unit, causing water to run into unit when not in use. replace the inlet valves and you should be good to go. the inlet valves can be removed by, removing top panel(3screws in back), disconnecting hoses, taking the small clamp on the small hose connected to the dispenser. theirs a small screw holding the inlet valves from back pane, remove old inlet valves and replace and you should be all set. hope it helps.
Apr 02, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore HE3 washer
The water valve is not closing fully. You will need to replace the water valve.
Mar 31, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore HE3 will not hold water leaks into the pedestal
run you fingers into the door boot and inspect for holes ,, that probably what it is ,,,,,,big tear
Dec 30, 2008 | Kenmore Elite 45986 Front Load Washer
Leaking Kenmore elite he3 washing machine
removethe lower acess panel 3 screws across the bottom , run the cycle and watch to see where exctly the leak is coming from it should be quite apparent
Mar 09, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
85 people viewed this question
Sal De
fordexpert
Robert Rankin
