Question about Kodak EasyShare Z740 Digital Camera
Camera will not turn on at all
I've tried multiple new batteries, even the pencil eraser trick but no use.
ideas?
  • 2,335 Answers
I may be able to help with your Kodak EasyShare Z740 that turns itself off.
Try these steps to fix your camera.
I hope that helps.
_____________________________________________
Kodak EasyShare Z740 Turns Off Fix
Kodak EasyShare Z740 Manual Download
Posted on May 01, 2010
Why does my camera keep saying battery exhausted even when I change the batteries?
If batteries leaked in the camera the connections IN the camera may be dirty. Putting in a new battery takes care of the battery connection but not the camera connections. This is why it is very important to take out batteries when you are done taking photos. When you want to shoot again you put the batteries back in and set the time and date. You MAY be able to clean the connections with a pencil eraser. If you use a pencil eraser please blow out the dust from the eraser. If you are positive the camera then I cannot help you here.
Jul 20, 2014 | Nikon COOLPIX Cameras
Nikon L22 camera will not power with new batteries
Clean the battery contacts and the contacts inside the camera with a rubber pencil eraser. Bub them until shiny. That may do the trick.
Nov 28, 2012 | Nikon Coolpix L22 Digital Camera
When i was using the rechargeable batteries my camera worked fine but i lost them so i reverted to use duracell aa batteries and now my camera only turns on for me to see all the pictures stored on it.. i...
Greetings - You're absolutely right - Your camera should work with any rechargeable or alkaline AA batteries.
Have you tried using a second set of batteries besides the first and are they new batteries or batteries that have been lying around in a drawer?
If they're new you might want to try an old trick that might help and get a regular pencil with an eraser and use the eraser to clean the contacts on both ends of the battery compartment. When you're done make sure you blow out any bits of eraser that might have crumbled off.
If the batteries are new and the contacts are clean your camera has some kind of problem and I suggest you visit Fuji Films tech support website HERE.
Good Luck,
Mikeywaf
May 26, 2011 | Fuji FinePix A820 Digital Camera
My camera was working fine one day and would not come on the next time I tried to use. I've put new battery in and this is not the problem. Can you help?
Do you hear anything when the camera is turned on? Perhaps you're just not seeing the display on the View Panel? When you flip a tiny switch, which I've done accidentally, it turns off the panel display so that you can only look through the view finder. Each camera is different, so be sure to check your manual to locate this switch.
After you turn the camera OFF. You may also want to check your battery placement. One incorrect placement will cause the camera to be "dead". Also look into the battery compartment to make sure a battery has not leaked on the leads. If you can't see the metal on any of them you may want to carefully clean it using a small Q-Tip or a pencil eraser. If you use an eraser be sure you get all the left over residue out of the chamber afterwards.
You've probably already tried these things, but hopefully it will help to get your camera working again.
--Sandy
Apr 22, 2011 | Fuji FinePix S3000 Digital Camera
When you turn it on it turn off even with new batteries
Check the battery contacts in the camera. If you have let batteries become totally discharged while being stored, they would have caused corrosion on the contacts.
Clean with a pencil eraser and then with alcohol on a Q-Tip.
Feb 16, 2011 | Samsung Digimax S500 Digital Camera
Camera won't turn on? i even installed new batteries.
Hi. Remove those new batteries and use the eraser end of a common pencil to clean the battery contacts within the camera itself. Then reinstall the batteries. If it still will not start have the "new" batteries tested at a radio shack store, they do this for free. Joe
4 thumbs up please. ty.
Nov 03, 2010 | DXG Technology DXG-503 Digital Camera
CAnon indicates low batery even it is full
Clean the battery holder with a pencil eraser, otherwise go for good brand rechargeable battery AA 2700 mAh try it.
Aug 25, 2009 | Canon PowerShot A590 IS Digital Camera
Leapster won't turn on
Had the same problem. I could randomly make it turn on by some bazzarre combination of pushing buttons. Now won't do anything. Call Leapster 800 #, and thought I was getting a bunch of b.s. from a "tech" person, however IT IMMEDIATELY RESOLVED THIS PROBLEM. Remove the battery pack and batteries. Take a pencil eraser and rub/clean the contact point where each battery goes in on the tray (except the coil sides). Reinstall the batt's back in the trey. Use the eraser to do the same thing to the outside contact points on the outside edge of the tray as well as on the Leapster itself where the tray goes. Finally reinstall the the battery tray, and BINGO ! Crazy....I would have lost a bet on this "fix".
Nov 20, 2008 | LeapFrog Leapster Electronic Book:...
Kodak Easyshare
Remove the batterty andclean the internal battery contact with an
eraser on the end of a pencil- take a flash light to look inside the compartment to enfure they are bright and clean.
Make sure the battery door and contact srip are a good tight fit
Hold the door down with a finger whilst switching on
Other than that there is little moreyou can do
Jun 28, 2008 | Kodak EasyShare Z740 Digital Camera
Camera won't come on
Open the camera and remove the batteries. Use the eraser on the end of a pencil to reach up inside the camera and gently clean the battery contacts. Be careful not to bend the contacts. Don't use a lot of pressure or a lot of scrubbing, just let the slight abrasiveness of the pencil eraser do the cleaning. Use a pencil with a good clean eraser, not one with a dried out, hard, old eraser. Hold the camera in the normal upright position and reach in from the bottom with the pencil, so all of the eraser bits and dirt fall out of the camera. Check that there are no dirt or eraser bits left inside after you are done cleaning.
Clean the contacts on the battery compartment door the same way.
Hope this helps. It fixed my vivitar 5385 that would not turn on, and had the light blinking.
Jan 16, 2008 | Vivitar ViviCam 5385 Digital Camera
Kodak EasyShare Z740 Digital Camera Logo
154 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
