When my PC loads into Windows, i get a huge discolouration on my monitor. If i reduce green down to 0, i have a red tint to my display. Whats causing the discolouration and how can i fix it?
  • Phoenix101 Aug 21, 2008
    Turned out to be a broken USB port (somehow ? ?) but thanks for trying. Much appreciated.
    Genius:
  • Computers & ... Master
  • 1,056 Answers
Try downloading and reloading the video drivers for your PC.
It could be that they corrupted.
#2 If you plug a different monitor into the PC, does it do the same thing?
If yes it does the same, it's a problem with the video card.
Try the drivers, or you may need to replace the video card.
If no a different monitor doesn't have the problem, it's a problem with your original monitor, and you'll need to replace the monitor.
Posted on Aug 20, 2008
My hp pavillion dv7 1245dx screen has a red tint in the background?
Your lcd screen is bad. It's either the lcd screen or the video card inside the computer, but most likely the screen. You can isolate the problem by connecting an external monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok without the read and green tint then your video card inside the computer is good but your lcd screen is bad. If the Borrowed monitor displays the same red and green tint then the video card inside the computer is bad.
It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
Jun 05, 2012 | HP Computers & Internet
Contrast really dark but seems to improve after the tv has been on several hours
Hi:
You may have a problem with the inverters in the unit, they are responsible for lighting up the back panel. Check or have checked the power supply voltage to the inverters, should be around 18-24 volts DC. Also leaky capacitors on the power supply will cause this issue as well as leaky or puffy capacitors on the inverter.
Sep 08, 2011 | LG 32LG30 32 in. LCD HDTV
Is there a new windows 7 driver for the Samsung Syncmaster T240 monitor? The problem I'm having is green flickering, where a green tint intermittantly comes over the monitor.
try reducing the refresh rate of the screen. I Hope the Driver for the moinotor is installed !!
But if it is intermittant..
Then Monitor may be going through normal ageing.
Rate this solution, Write a comment to keep in touch.
Sep 16, 2010 | Samsung SyncMaster T240 Monitor
My screen is light green i don`t know what to do ;/ whats can by bad ? please help me :S
I am not sure if you are talking about the green power indicator light, or the screen is showing image with green tint.
Check the VGA cable first make sure there are no bent pins, tight connections. Try it on other PC also, we just need to narrow down the problem first.
http://s807.photobucket.com/home/budm/allalbums
Please Post back.
Apr 24, 2010 | Samsung SyncMaster 910MP 19" LCD Monitor
Green tint display
The monitor is faulty, not enough red. you can make changes in your display advance settings to try and reduce the yellow and blue to make the screen look a bit better. you might want to try a differant vga cable or check the pins in the plug that nun are bent
Aug 18, 2009 | Star Logic 17" LCD Monitor
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Sep 15, 2008 | LG 42LG50 42 in. LCD HDTV
1 monitor is red - 1 is green
its because when you start putting to many moniter spliters the color data gets lost in the link.
Sep 12, 2008 | Matrox 128 MB G450 Quad Graphic Card
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
