My sister was stumped because her window unit a/c keeps leaking water inside her house.She even had her husband drill a small hole in the housing of the a/c, so that it would drain excess water more efficiently, but it still drains inside the house,they also tried to tilt the unit more, but no luck.Do you have any suggestions?
    Problem Solver:
  • 9 Answers
If you remove the lower casing of the unit, you will find that it was design in such a way the water followed a certain track. Your problem should be fixed if you align that track with the opening to coils so water should drain in the proper track.
Posted on Aug 21, 2008
Water leaking beside thermostat houseing
Replace the corroded housing and you will have to replace the rusted welsh plug in the rear of the engine . If it is from inside the bell housing it means gear box out and fly wheel / flex plate off
Jan 25, 2014 | 2002 Dodge Stratus
Where is the drain hole on goldstar window ac my ac keeps dripping water inside the house
Hello, make sure the unit is tilted toward the outside a bit, if it is level the condensate will collect in the front and start dripping inside the house. Also, if the unit has a drain make sure it is clean so the water can drain out properly.
Jun 07, 2011 | Goldstar KG6000R Window Air Conditioner
Drainage occurs near the front of the unit, resulting in pools of water leaking onto my window sill. Unit is installed properly, there is no drain hole to direct water away from the insides of the walls...
The A/C unit should be tilted slightly to the rear and this will allow the water to leak to the outside of the window, you may have to drill a small hole in the case to drain if there is no pre-existing hole.
Aug 15, 2010 | Frigidaire FAC126P1 wall/window Air...
There is no drain hole for water to drip outside.
These are designed to retain some water in the pan. This is for the slinger fan to throw water through the condensing coil. This helps the refrigerant cool and is important to the efficiency of the unit. I would certainly not recommend drilling a hole in the bottom. The hole may cause the water to roll somewhere where damage could occur. Try instead tipping the unit Backwards before bringing it in the house.
Jul 14, 2010 | Frigidaire FAC126P1 wall/window Air...
Leaking inside house , condensation or something causing liquid to leak inside house and i have to use towels to catch fluid
Should have a drain hole on back to drain outside it maybe pluged or unit is not leveled to outside has to have a slight tilt for water to drain out not in.
Jul 11, 2010 | Sunbeam SAW10CR1FHU Thru-Wall/Window Air...
Water leak
Make sure the unit is tipped to the rear slightly. Do not drill holes in the base!
Aug 21, 2009 | Maytag NMPEB08F2A Air Conditioner
Condensation leaks out front of unit into the house.
Hi, no don't drill holes in bottom tray, to make drain, that's design, you need to keep water there, the fan usually pick up water(moisture) and add to your air inside your home, otherwise the air in your home will become to dry, dry air will create static electricity all over your home, from your carpet to your clothes, you need to level your unit horizontally, put a spirit level, and you should have a slight pitch, from front to back, good luck.
Aug 03, 2009 | Maytag M6Q10F2A Air Conditioner
Water on the floor
I've ran into this problem before with another jeep. What happens is the condensation drain line from the evaporator housing gets plugged with the material that insulates the housing and the water can't drain and seeps through the seems and drips on the passenger side floor. Chrysler did at one time sale a plug kit for this. What you would do is drill a 1/4" hole in the side of the housing on the left hand side near the bottom and put a stiff piece of wire in it to unplug the drain line and then plug the hole with the plug kit from chrysler. just when your drilling the hole make sure you don't drill into the evaporator core or your freeon will leak out as well. I'm not exactly sure how far from the bottom to drill the hole if I remember right it is 2 inches just about center. Chrysler did have a service bulletin on this you may want to ask them when you see bout the plug kit.
Jul 27, 2009 | 1998 Jeep Grand Cherokee
Samsung ac model aw25ecb7
hi! bill,
water drip it should be outsidethe house,beside there is a spout on the basin of your ac unit and hose to drip off outside the house,all you gonna do insert a piece of wood or metal on front side of basin, in between basin and the wall,just small piece object to elevate the basin to outside wall,the water will not stored in the basin.or make a spout, drill a hole 1/4" size at the corner at the backside of basin out side your house,be carefull not to drill condenser tube or the fan blade,insert a plastic hose 3/16" and weld it by glue gun.and end of hose put it an empty bottle so that the water drip will not scattered outside your house.regards and don't forget to rate me,thank's a lot
Apr 29, 2009 | Samsung AW0503B Air Conditioner
Heating & Cooling Logo
223 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
