Question about Compaq Computers & Internet
My USB socket in my laptop won't hold a usb connection. Now I'm unable to use it to hook up to my printer, flashdrive, etc. What should I do? Do you know of and repair shops.
    Genius:
  • 1,056 Answers
How old is the laptop?
If it's new enough, you might be able to get Compaq to repair it for you.
If not, wellllll it might be a little tough.
The only place you are going to be able to get replacement parts for it, is through Compaq / HP (they are one in the same)
It doesn't hold it on any of the USB ports?
You might want to try getting a little unpowered USB 4 port hub, and attaching it to the port, and then figure out a way to bond the hub to the port (hot glue, tape etc) just so that you don't have to plug and unplug it. It might be ugly, but it would give you 4 good new ports a lot cheaper then taking it to a shop.
Posted on Aug 20, 2008
Toshiba nb200.
You need to buy an adapter (USB to a specific printer port) if necessary (USB to Serial, USB to Parallel, etc.).
Feb 20, 2014 | SGP Toshiba NB200 Laptop Cover Skin [Cube]...
Acer Aspire 4736z always shutdown on start-up
Try to update your BIOS. Download it here : http://us.acer.com/ac/en/US/content/drivers
You must need USB Flashdrive to update it. Please make sure that your USB Flashdrive is bootable. Here's the link on how to make USB Flashdrive bootable: http://www.makeuseof.com/answers/usb-drive-bootable/
After you make your USB FLashdrive bootable, copy that BIOS update folder in your USB flashdrive. Please also rename it in simple words so that you can easily access it using command prompt. And after that make your USB flashdrive as first boot priority. Then save and exit.
When the USB flashdrive is now booting.
Type this:
cd (name of the BIOS Folder)
cd DOS
FLASH
then wait it after it finish.
NOTE: Make sure you plugged in your AC adapter.
Hope it helps
Feb 22, 2013 | Acer Aspire 4736Z 4736G 4738ZG 4733Z...
Hi, From the XBOX I can see and have connected to the router, but when testing the connection on the xbox it says it cannot get an IP address, try to input manually, got all the numbers and input...
you may have to have your wireless hooked up to your xbox while hardwired into the internet, to retrieve an update..its been a few since i did mine.
-mk3ride
Dec 28, 2010 | Microsoft Wireless Network Adapter Xbox...
What does a usb stick do and how do i use it
A usb stick or memory stick is used to store files on just as a cd-rom stores files,but it's faster and more portable.
Aug 10, 2010 | Acer Aspire 5735 Notebook
Hello-I have a 19" Philips flatscreen LCD television set model#19PFL3504D/F7. After attempting to upgrade current software via a USB flashdrive I reversed the disconnect instructions. I removed the...
connect a laptop to the set, using the usb port contact phillips on line download the old flash to the computer save the old flash download as a file and, to the usb flashdrive connected to your laptop reload the set either with the laptop or, the flashdrive unplug the set first then: remove the flash drive
Jul 17, 2010 | Philips 19PFL3504DF7 19 in. TV
Printer unable to communicate with computer.
Are you using the wireless network printer function or is the printer connected by a USB cable? If you are using the wireless network, launch the printer's Wireless Setup Utility and run through it. (Check for problems with IP, signal strength etc.)
For USB, try resetting the printer (unplug it from the wall for 10 seconds). Check that the computer is looking for the printer on the correct port. Click Start > Settings > Control Panel. Double click on the Printers folder and right click on your Lexmark printer. Choose Properties then click on the Ports tab. Check that one of the USB port options is checked. (If you have a newer OS, Start > Devices and Printers and then right click on the printer.) Also try a new USB cable and a different USB port. If you have a print server or USB hub, try a direct connection.
I hope this helps.
Apr 22, 2010 | Lexmark X3350 All-In-One InkJet Printer
USB port on laptop is not working
make sure the driver is installed
Jan 03, 2010 | Dell Inspiron 8600 Notebook
Wire connection with my laptop
Sounds like you are trying to set up a printer. If you have a USB cable, which it sounds like you do, you've put one end in the USB port in your laptop. The other end, which is square with two beveled corners, goes in the corresponding hole in the back of your printer. If the only connection you have in the printer is the older centronics connection (about 2" wide) and there is no other connection, your printer is too old to hook up this way. New printer time, as depending on the age of your laptop, it probably does not have a parallel port to hook up a printer like that.
Feb 06, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
Computers & Internet Logo
24 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
