Question about Maytag MGR5750 Gas Kitchen Range
No Gas Top burners have gas oven doesn't seem to have lighter is lighting but no gas coming through the little holes I did wire brush the holes and vacuum but still no gas
  • 639 Answers
Hi, I'm Neil
It is a fire hazard! Be Careful!
This time you will have to call the the manufacturer for service!
If it's under a year old ,your under warranty and it will not cost you anything!
Not worth the risk!
Please give me a solution rating here!
Thank You
Neil
Posted on Aug 24, 2008
Burner on the top of the stove does not light,doesn't seem to have gas flow
i have the same problem with mine but i was cleaning mine with mr muscle which got in the holes where the gass comes out. i havent found a fix yet. im just hoping it will dry out n start working again
Jul 05, 2012 | DCS RGS-486GL Stainless Steel Gas Kitchen...
Broiler burns but the bottom burner on the stove will not come on the glow igniter turns orange but the burner doesn't light also one eye doesn't light, the striker sparks but the burner...
FOR THE OVEN NOT HEATING
The problem beleive it or not is that the bake igniter is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake igniter(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of igniter make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake igniter. I know it seems improbable that if the igniter comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the igniter comes on yet the oven won't heat that a weak igniter is the cause 100% of the time
FOR THE SURFACE BURNER NOT LIGHTING The holes on the burner espically those around where the electrode are dirty/clogged. By using a paper clip/safety pin to push in and clear the holes then clean the burner up with some steel wool the burner should light. GENE
Aug 29, 2011 | Maytag PGR5710 Performa Gas Kitchen Range
I have a magic chef oven model # 61S04PAW. the
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 07, 2010 | Magic Chef 31000 Gas Kitchen Range
The burners are not lighting Frigidaire Gas Range only 8 months
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good "blue" arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
May 16, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
My grill is not working. What could be the
The first thing you will need to do is try lighting the burner manually with a match or bbq lighter. Bring the flame next to the burner then turn on the griddle knob. It should light up. If it does then it is either a weak spark on the ignition system due to debris on the electrode or there is blockage in the burner eyes at the electrode. Try poking out the eyes of the burner with a safety pin or sewing needle. And try using a wire brush to lightly clean the electrode head(where the spark comes from). If your tried lighting the burner with a match or bbq lighter and it did not light or a very small flame came out then there is a restriction in either the burner eyes, venturri, or burner orfice. Frist inspect the burner eyes for any blockage(grease or particles of food) and then use the sewing needle or safety pin to clean out all the burner eyes. If the burner is easily removed then go ahead and remove it and check the venturri(burner pipe) for any debris inside it. A small bottle brush can be used to clear the venturri. And finally with the burner removed you should be able to see the burner orfice. It will look like a small nut(usually brass) with a very small hole in it. This is where the gas comes out and if this hole becomes plugged then the burner will not work. The best way to clear this hole is to use a very small wire like the wire on a sandwich bag tie strap. Burn the plastic off of the tie strap to expose the thin metal wire and then use the wire to clear out the hole. DO NOT USE ANYTHING LARGE to try and clear out this hole. It is tiny for a reason and the soft brass can be opened up easily while try to clear the orfice hole causing a huge increase in gas pressure. If you clear the orfice hole and still do not get any gas pressure then the next step would be to remove the orfice(this requires a orfice wrench) and verify that you get gas coming from the burner tube with the orfice removed. If you do not get any gas after removing the orfice the more than likely the problem lies with the burner valve restricted internally and will need to be re-built or replaced.
Apr 24, 2010 | Rangemaster 110 (Dual Fuel) Dual Fuel...
On my gas stove, 3 out of 4 burners light correctly. The 4th however will not light- doesn't show a spark. Though you can use a match to light the burner and it works fine. what gives? Can I do the repair?
Feb 10, 2010 | Frigidaire FGF326AS Gas Kitchen Range
Lower oven burner will not light.
Hi I have a older GE that the oven won't light. It is a gas range that is electric ignited. The top burners do work but the oven will not light. Is it pricey to have this fixed?
May 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Tappan oven not gas flow or ignition
Right rear burner will not ignite without assistance (a match or lighter). What is the problem?
Feb 13, 2009 | Tappan TGF303BW Gas Range
Tappan TGFS26C, Oven igniter not even
Lets take the oven problem first. Sounds like you have a Hot Surface Ignitor problem. This is the device that glows and lights the burner. You can buy a universal ignitor at most appliance or heating and air conditioning supply houses. Note carefully how the old one is mounted. You may have to make some adjustments to mount the new ignitor, but it MUST be close to the gas burner like the old one! You don't smell gas because the gas valve will not open until the ignitor is hot. All ignitors work with the same voltage, so simply connect the new wires to the old ones.
I'm not certain if you have a standing pilot for the stove top burners or electronic ignition. Remove the top panel to check. If you have a gas pilot, relight it. If electronic ignition, clean the ignitors. If that does not solve the problem you may have to call a technician, as these systems can be complex.
Hope this helps.
Ray
Nov 20, 2008 | Tappan TGF363 Gas Kitchen Range
Maytag MGR5750 Gas Kitchen Range Logo
51 people viewed this question
Top Maytag Kitchen Ranges Experts
gbob59
freddyfox
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
