Question about Dryers
My dryer does not start when i push the button it does nothing, but when I turn the knob to off it does click help please
  • jeffswifel Aug 21, 2008
    My dryer worked one minute, then the next load....nothing. As though it were unplugged...except, you could hear the ticking of the timer. Testing the power, there is power. So what could it be? I find NO re-set switch either.
  • 770 Answers
There is a thermal fuse on the exh. duct it is white remove the back panel unplug jumper it plug back in and test it
Posted on Aug 21, 2008
The dryer heats up and spins without issues. The problem seems to be in the dry cycle selection knob, it used to be a bit stiff when turning it to different cycles. Now, it seems very loose and it only...
Try pulling out the knob and turning the post wth your fingers. You will have to caibrate it yourself. If this does not work, You will have to rplace the control board behind the knob.
Sep 19, 2013 | Dryers
105I have a samsung dryer dv409AER/XAA. Currently, I turn the power on and select a cycle and push the start button. When I push the start button - nothing happens. This occurs for any cycle. There is...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 27, 2011 | Dryers
When I push the "push to start" button (knob) on
heatman101
Mar 14, 2011 | Kenmore Dryers
My dryer is getting electrical power. But when I turn the power knob onto ON, nothing happens.
it may be the door switch, but if you hear a click when you push the start button then the motor reset button tripped. You should be able to set the dryer on its front side and see the motor reset buttons as there are two one trips one resets, push the reset in it should click and then plug it in and see if that helped. Hope this helps if not feel free to ask more info as I am more then willing to help Tim
Oct 16, 2010 | Hotpoint NWSR483EBWW Electric Dryer
Whirlpool dryer will not start, used to start if I turned timer
whirlpool electric dryer will not start when you push start button. Model No. LER5634AW0. There is power to the dryer. The door switch appears to be working,(didn't check it with a meter). I push the start button, run it through all the cycles and still nothing. Are there any resets or circuit breakers that I could check? Where do I go from here?
Mar 06, 2010 | Dryers
GE Spacemaker Washer/Dryer wont start only washer or only dryer
Did you figure out a solution to this problem? I just bought a brand new Frigidaire and it is doing the exact same thing, except it never worked properly. I thought it was the unit and had HH Greg bring another out but the 2nd one did the same as the first.
Feb 09, 2010 | GE WSM2700W Unitized Spacemaker Washer and...
I have a Maytag PYE2300AYW. Push button but nothing happens. Had breakers to house checked and all good.
Dryer suddenly stop working when pushing start button (knob will make a humming or ticking kind of noise but won't turn on. I cleaned and check the outside exhaust and lint screen passage. Nothing is helping. help
Jan 08, 2010 | Maytag PYE2300AY Electric Dryer
Dryer just stopped working. Turned knob to desired time and pushed start, nothing happens. When knob is on OFF position and I push the start button, it makes the regular BUZZ sound - times up, clothes...
Remove and inspect the timer knob for a crack or missing tension clamp.
Carefully place it back on the timer shaft while paying attention to the (D) shape in the knob and the shaft.
If they are aligned correctly notice where the position arrow is pointing, ie; off---run--etc.
You may well need a new knob.
Feb 21, 2009 | Dryers
Batch complete sounds when start button is pushed
door switch or timmer or the knob on the timer may not be turning the timer
Nov 27, 2008 | Maytag PYE2300AY Electric Dryer
Dryers Logo
94 people viewed this question
Top Dryers Experts
