Question about Audiovox 150W DVD Home Theater System - STS93 System
Audiovox DVD Home Theatre system - STS93
The dvd tray will not open
I use a pocket knife to help mine open and then push it close. As far as i can tell the tray for this model was ill designed coupled with a crappy motor that may go out with out reason or warning...
Posted on Nov 07, 2008
Audiovox DVD Home Theatre System Sound Issues
check the audio settings make sure they match where you plugged the source. and if all of your sources run into the tv first you will need to have an audio out to the reciver
Apr 25, 2010 | Audiovox 150W DVD Home Theater System -...
Corrupted Firmware on Philips HTS3555 Home Theatre System
Only posibility is finding a service shop that services Philips....
Mar 23, 2010 | Philips HTS3544/37 Theater System
No surround sound coming from tv. surround sound
It all depends on the TV transmission. If it is stereo, you will get the surround sound. If it is not then you have to listen to ordinary sound.
Dec 20, 2009 | Audiovox 150W DVD Home Theater System -...
Keep getting invalid disk error atho have tried 4 different movies and all are good disks
You can try lense cleaner, and if that do not work, it requires repair in which the laser assembly needs replacing cuz they do go out often. Laser diodes are easy to go bad because of current surge.
Nov 28, 2009 | Audiovox 150W DVD Home Theater System -...
Some dvd's load and others don't....what is the issue? I use the cleaning dvd to make sure that isn't the problem but it still tends to not load many of my dvd's.
make sure that they are all from the same region. Also check to see if they are NTSC or PAL...based on your DVD player.
PLEASE VOTE IF THIS WAS HELPFUL..THANKS AND GOOD LUCK.
Nov 22, 2009 | Audiovox 150W DVD Home Theater System -...
I don't have the code to the remote
www.rockabilly.net/files/manuals/URC-3220.pdf
Nov 17, 2008 | Audiovox 150W DVD Home Theater System -...
I need a philips cl034 universal remote code for memorex dvd play
I have similar problem with a Philips CL034 Universal Remote and a Memorex MVD2047. The Philips/Magnavox codes listed at this link did NOT resolve the problem. I tried all Memorex codes and tried the "all coded step-through" method. http://www.universal-remote.net/philipsmagnavox.html The above is NOT a solution, rather a note on a time consuming attempt to a solution.
Nov 12, 2008 | Audiovox 150W DVD Home Theater System -...
Need universal remote codes'
I need the codes for a Phillips Magnavox Universal Remote for a Samsung tv.
Thanks,
Nita
Jul 03, 2008 | Audiovox 150W DVD Home Theater System -...
297 people viewed this question
Top Audiovox Audio Players & Recorders Experts
John
John
Chinmay Joshi
Chinmay Joshi
Computer Links
Are you an Audiovox Audio Player and Recorder Expert? Answer questions, earn points and help others
