Question about Samsung PCL545R 54" Rear Projection Television
No Picture I'm getting audio but no video.
I have the same TV samr problem, so far I have dicovered a cap on the power card AA41-00342A has gone bad, c812 a 2200uf 250wv. I can't find a cap or replacement card. I'm still working on it, when i get more answers I will pass it on.
Posted on Sep 19, 2008
I hooked up my wii on av1 with a component cable with audio on audio 1 and i have sound but no picture.
If I am reading this right, you are only hooking up one cable for audio. There is another cable needed for video. This jack is normally color coded yellow and labeled video out/in. You can use your audio cable to try this and then you will picture but no audio.
Feb 16, 2014 | Yamaha RXV371
Samsung tv ps50a656 sound no picture
My guess here is that you have the audio and the video on different inputs. Check your wiring and make sure that your video and audio are on the same inputs (ex. Video 1 is matched with Audio 1). With the many inputs that TVs now have it is easy to hook up the video to video 1 and get the audio on something like Aux.
Oct 22, 2012 | Televison & Video
Whenever I try to connect dazzle it says.... failed to get video from device. It is coming from an xbox 360. and I know that xbox works with dazzle and pinnacle. I hooked it up all right.
donwload amcap
on amcap click
options
video capture filter
video image
tick the boxes
ext audio and usb audio
then go back to video capture filter
on video decoder
change the video to ntsc _433
then you will have audio and black n white picture then
change ntsc_433 to secam_B
than load pinnacle then capture/import
then you will have picture colour audio
Aug 01, 2010 | Pinnacle Video Transfer
I was given a GE 27GT616 television but can't figure out how to connect a converter box or dvd player
If your tv has video in socket (yellow color)and audio in socket(white color),you will connect the dvd player audio video output. it will give give clarity picture. your tv have not av socketyou can connect your dvd player audio video output to converter audio video input.And then connect to converter RFout to tv Rf input(antenna socket)and tune the tv you wlii get picture.
Jul 31, 2010 | GE 27GT616 27" TV
We get audio, but no picture. There is no red
If you have audio and no picture it is the scaler chip burning out you need to stop the heat build up.
Either send it in to get it repaired or fix it yourself using a proven guide
Nov 29, 2009 | Microsoft Xbox 360 Console
No picture on tv
This unit upconverts all video inputs to component output, so connect all your devices to your denon audio and video inputs and component video out of the denon to the tv component in and all should work fine
Feb 21, 2009 | Denon AVR-886 Receiver
How do i get my video to play....i am following the directions in the book....when i hit play...i get nothing....i am frustrated ....could someone let me know the step by step directions to get the video...
Make sure that you have the correct video format and compression. Video:
File Format: MOV
Video Compression: MPEG-4 ASP, MJPEG
Audio Compression: MP3, G.711, PCM, ADPCM, 8-bit linear
File Format: AVI
File Format: MPG / MPEG
Video Compression: MPEG-1
Audio Compression: MPEG audio Picture:
File Format: JPG / JPEG
Video Compression: Baseline JPEG
Music:
File Format: MP3
Video Compression: PCM, ADPCM, MPEG 1 layer 1,2,3
You will need to re-edit the video files you have for the frame to recognize it.
Feb 21, 2009 | Kodak EasyShare SV811 (8858946) Digital...
Need a visual
Hi and welcome to FixYa,
Normally, the colors should be yellow for video, white and red for audio. If you have blue instead of yellow, then pls try:
  • blue from video out of DVR to video in of TV;
  • white and red from audio out L/R to audio in of TV;
  • the S-video need not be connected;
  • select video 1 or video in in the source selection of the TV.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 22, 2008 | Emerson EWF2004 20" TV
There audio but no picture
I don't know how you connect the unit to the tv.
Let's just start on basic:
composite video/audio(yellow-video, white/red-audio) connect to TV composite video/audio input behind the TV.
If the audio works but no picture,try to use another video input behind the tv.if that still doesn't work,use a different video cable!
Jan 20, 2008 | Toshiba SD-V392 DVD Player/VCR
Samsung PCL545R 54" Rear Projection Television Logo
61 people viewed this question
Henry  Thomas
Henry Thomas
