Question about BenQ FP71E 17" LCD Monitor
BenQ FP71E 17 - how to open
Hi, how do I open my Benq fp71e+
I have taken off the screws and can see small openings int the bottom that come out, but the sides and top and stuck firm...how do I pop them out so I can pull the back off???
cheers
dion
  • 3 more comments
  • dionhewson Aug 21, 2008
    ignore this one...I got it open...how do you figure out the cs5707 transistors where dud? they look fine...its like black magic...
  • Anonymous Sep 17, 2008
    how did you open yours?
  • ltnavman Jan 07, 2009
    I have a BENQ TFT monitor T905 from a few years.Yesterday I turn on the monitor but It does't work. When I turn on themonitor the LED is green for a while (but doesn't appear the welcomemessage), after some seconds the LED turns yellow. If I turn on the PCthe LED turns green again and maintain this state.
    First of all I need help to open the monitor.
    Thankyou in advance
  • ltnavman May 11, 2010
    Thankyou in advance
    How can I open the monitor?
    Champion:
  • 220 Answers
There are 4 pieces 2 each around yellow invertor transformers.
Check visually for darkened back of the transistor.For reliable testing you need to desolder and test with an ohmmeter.Also check the FET Fu9024 or D10Pf for similiar problems.
What is your actual symptom?
Samir
Posted on Aug 22, 2008
Have connectd benq fp71e moniter it works good but no sound from moniter speakers
Try on putting a headphone jack similar to the the image:
Put it on back of your monitor's audio slot. It is usually colored green and then put the other end to your computer audio slot. Thank you
Sep 16, 2011 | BenQ FP71E
How to get sound working on a Benq 17" FP71E?
is on the back audio input connector, and you can set audio levels on the monitor menu items.
Nov 06, 2010 | BenQ FP71E 17" LCD Monitor
When I try to turn the BenQ FP71E 17" LCD monitor on, the on/off button glows blue for around 1 second, the monitor screen comes on for around half a second and then they both turn off simultaneousely. Any...
Since Dell monitors are made by BenQ, please look at Dell photo albums.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 19, 2010 | BenQ FP71E 17" LCD Monitor
Logo appears then a blank screen
You need to open it up and inspect the PCB for bad solder connection or over heated components. BenQ made monitors for Dell, so look at some pictures of failed Dell monitors here to get some ideas what could have gone wrong with your monitors, post back what you see so we can guide you further: http://s807.photobucket.com/home/budm/allalbums
Mar 22, 2010 | BenQ FP71E 17" LCD Monitor
Benq FP71E, No Image Displayed
Try checking the settings in properties for this device to make sure they are as you left them. YOu can also uninstall the drivers for the card and reinstall them to see if that takes care of the issue.
Jan 05, 2009 | BenQ FP71E 17" LCD Monitor
BenQ FP71E 17 goes black during post
Hi...there,
With AC adapter it's to your left, a rectangle piece. Without, it's under you power supply w/ built-in inverter... the capacitors look like a tiny battery on the side it have voltages size ( example like 1000uf 16v ) Good lucks, have a nice day!
Aug 20, 2008 | BenQ FP71E 17" LCD Monitor
BeNQ FP71E Monitor won't display desktop
The problem seems to be with the monitor.When there is no Display,if you power-off and on again do you get a Benq Startup screen?If not the problem should be dry solder on the Invertor board.Try tapping screen lightly,if it comes on the problem is dry solder on Invertor board.
Provide feedbacj and rate this solution.
Samir
Jul 28, 2008 | BenQ FP71E 17" LCD Monitor
Mail me what you need samir @viziks.com.
Samir
Jul 27, 2008 | BenQ FP71E 17" LCD Monitor
My benq lcd fp71e 17"
ive solved this by taking out my vga cable and plug in my dvi cable and ive done some settings on my ati control center i have x1300 512 mb all you need is change your settings that this lcd dont support plus this monitor is huge!!!!!!!!! thank you for your support lol
Mar 29, 2008 | BenQ FP71E 17" LCD Monitor
Monitor menu opens up on its own
Front panel switches are defective.
Contact BenQ,Normally company offers 3 year warranty.
Samir
Dec 26, 2006 | BenQ FP71E 17" LCD Monitor
BenQ FP71E 17" LCD Monitor Logo
533 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
