Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
My tv my 37in tv wont stay powered up
  • ralph jones Aug 21, 2008
    it stays on for a secnd
  • 138 Answers
How mant times the the led on the front of the set blinks? And how long do it stay on before it goes out?
Posted on Aug 21, 2008
  • Anonymous Aug 21, 2008
    The set has a bad board in it but to determine which board is bad has to troubleshooted by taking voltages on the set. You may need a tech to look at it, or are you able to do it?
6ya staff
SOURCE:
Bought a new power supply since the previous power supply looked burned and short circuited. Installed the new power supply and sparks flew inside the Tv right when I plugged it in.
If you look around at where the sparks came from or for evidence of burnt parts inside the TV - not in the power supply - then you will find the fault that probably caused you bad looking power supply in the first place!
Oct 20, 2015 | Samsung UN37EH5000FXZA 37in Led 1080p 60hz...
I have a Emersom EWL3706 37in led tv. You have to turn it on 3 or 4 times before it stays on. After about 10mins it shuts it's self off. Turn it right back on and it stays on for about 1min and shuts it's...
Start voltage problem. In some cases, it can be repaired. In most cases not. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Nov 02, 2014 | Televison & Video
I have a olevia 37in model 437-s11.the power light is on but no pictures
I just bought one used and I plugged it in.. blue light on.. why iss it not working ? blue light off when tv on.. this work for this caveman.
Jan 23, 2011 | Olevia Televison & Video
I have an element 37in. flx-3710 tv. lately whwn i turn it on the screen stays blacks and flickers for a few minutes untileventually the picture appears.however the picture is either washed out or so dark,...
ldq781, I think you or electronics technician should investigate the units internal "switch-mode-power-supply/cold cathode-fluorescent lamp electronic ballast circuit(inverter) for "failed" "swollen" electrolytic filter capacitors and or "poor quality" soldering of the electronic components to the copper foil traces of the printed circuit board(power supply board) The first thing to do is visit YOUTUBE for video clips of lcd monitors being repaired for these typical types of "failures" which are most common to both types (monitors and lcd tv's) After you do your research then return here and leave additional reply if you still need help. 12fixlouie
Sep 24, 2010 | Element Electronics FLX3210 32 in. LCD TV
Ok.... I got a new power supply board and the tv is still doing the same thing. (Sharp Aquos 37in LC-40C37U) So if it is not the power board then what could be wrong with it. I'm getting no power and only...
The pattern of the blinking is a code. If the power light is blinking by itself once per second or thereabouts it could be loose connection to Inverters, reload firmware, Inverter Unit or LCD Panel.
May 06, 2010 | Sharp AQUOS LC-40C32U 32 in. LCD TV
Have a broksonic 37in flat screen tv. There is
i have bought 2 differnet ATT remotes but they onlu work if I/m an inch from the box..I have a Tosiba flat screen. tech said the infrared remote was getting inteference he sai try an RF remote i did same problem,,help
Dec 17, 2009 | Televison & Video
37in model 37pf7320a/37 , wont stay off settings mode
I fixed a Phillips 37" TV that was doing this by re-soldering the wire/pin joints on the button board (side of TV). You have to take the TV apart and have a soldering iron to do this, of course. But it's really not that hard to do.
I'm a caveman, and I did it!
Dec 05, 2009 | Televison & Video
Soyo Televisions
no!!!!!!!!!!!!!!!!!!!! power supply craps out and there is no support.
Apr 20, 2008 | Soyo DYLT032D 32 in. LCD Television
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
78 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
