Question about Compaq Armada M700 Notebook
The hard option. ..
Hello,me again. Been thinking just how user un-friendly is it?
Is there anysite u would recommend where I could get step by step instructions?
Cheers : )
  • Sarah Currie Aug 20, 2008
    It would have to be the NT install, I just cant get XP.
    If u did find anywhere I could read up on this it would be great if u let me know!
    Do you think I could read enough to be able to do it?
    I quite fancy the challenge!
    Genius:
  • 1,056 Answers
How user un-friendly is it?
Is what? NT or the XP install?
The XP install is pretty simple. My daughter did her own install the first time when she was 17 and even though she's my kid, she's not a geek by any means (if it's on MySpace she knows it inside out, but not much beyond that).
I even sent some basic instructions to my 78 yr old father, and he was able to do it.
The NT install is serious geek install. It even give me headaches.
I'll dig around and see if I can find a step by step for the XP install. I know they have some somewhere.
Posted on Aug 20, 2008
Gateway will not start
Short Answer:
Use a Windows recovery disc or installation disc to repair the system or reinstall Windows.
Long Answer:
In my experience, this means that the operating system (OS) has been somehow corrupted. There is a possibility that your hard drive has failed, but this usually is not the case. I would recommend that you first try running hard drive testing software from a bootable media, such as the ones that can be found on the Ultimate boot CD at 'HDD/Diagnostics' in order to verify that your hard drive is still working properly. The previous step can be skipped, but if your hard drive is faulty, then you will encounter the same problem again later. At this point you have a few options: first you can try to repair the OS installation with the OS installation or recovery disc. Another option is to completely reinstall the OS. The previous option usually works for me, but this will usually result in the loss of all your files; to counter this I would recommend a using a Linux live installation disc (such as Ubuntu) or Parted Magic (can be found on the Ultimate Boot CD) to recover desired files to a flash drive (Parted Magic should only be used by advanced users).
Sep 03, 2014 | Computers & Internet
Hard drive recover
Hii frnds,
Recently i too had lost some of my files from my laptop in similar circumstance, so in order to recover those files i utilised Partition Undelete software. This tool recover laptop hard drive within few minutes. You can get this tool from internet for trial usage.
Dec 11, 2012 | Western Digital Computers & Internet
My usb says WRITE PROTECTED when i try to delete something from it...can you help me out on how to remove the write protected thing?
hello satawal, there is some step to remove write protected thing: 1. go to "View" --> "Folder Option" --> click "View" tab on folder option window. 2. scroll down and find "use simple file sharing" option, uncheck the box and click OK. 3. go to My Computer window, right click your USB drive and choose "properties". 4. on properties window, click "Security" tab and click user name that u already log in. 5. on permission box check 'modify' then click OK. now your USB not write protected anymore, to make write protected again just uncheck the 'modify' and 'write' on permision box.
hope this works, regards.
Sep 14, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I blocked a certain number on my samsung wave,please tell me how to unblocked the number.
Below are the steps to block and unblock contact.
Block:
Dial a number which you want to block. Click on end call.
From the menu - tap on Logs Icon
Tap on the number which you want to block.
At the bottom - Middle of the screen, You will find three dots (...)
Tap on it.
Tap on Block contact.
A new screen will come - Block Contact.
You will have option to block - Call as well as message.
1) Call
2) Message
Put a check mark and click ok.
It will display the number, by saying it is blocked.
Unblock:
Tap on the number which you want to Un block.
Tap on it.
You will have option to un block - Call as well as message.
1) Call
2) Message
Un-check the mark and click ok.
It will display the number, by saying it is un blocked.
Apr 14, 2011 | Samsung Cell Phones
Maxtor 3200 is not getting reconized by windows 7 ... i need a new driver
Install it another computer which is running well.If your Hdd run well in that computer ,change the USB cable .If the HDD can not run in another pc you think, you have lost data.Because that Hdd cant run any more.
If the problem is same.
follow the step
R_click on my computer>Properties>Hardware>Device manager>uninstall all the usb hub ,one after one .
After UN install all the usb, restart your PC .
If the problem , is same as before ,
Insert your OS in the cd tray > press Win key + R>type sfc /scannow (please take a space between sfc and front slash)>hit enter .Again you will restart the PC.
If the problem is same please change the Hard disk.
Hope it will help you
Jan 10, 2011 | Maxtor Personal Storage 3200 (U01E200) 200...
Hard drive not detected by my pc . power lite is up while connect to pc . pc is amd athalon and usb hard drive is iomega 160gb
follow the step
R_click on my computer>Properties>Hardware>Device manager>uninstall all the usb ,one after one .
After UN install all the usbroot hub, restart your PC .
Dec 31, 2010 | Iomega Silver Series 320GB 3.5 External -...
I have a maxtor one touch mini and does not pop up on my screen, what can I do ? i need all file inside
follow the step
After UN install all the usb restart your PC .
If the problem same as before ,
Insert your OS in the cd tray > press Win key + R>type sfc /scannow(please take a space between sfc and front slash)>hit enter .Again you will restart the PC.
Hope it will help you.
Dec 27, 2010 | Maxtor OneTouch 4 Mini 160GB External USB...
System Manufacturer Gigabyte Technology Co., Ltd. System Model GA-MA790X-DS4 System Type X86-based PC Processor x86 Family 16 Model 2 Stepping 3 AuthenticAMD ~2712 Mhz Processor x86 Family 16 Model 2...
Hello my friend,this is could happen because of driver problem or and more common operating system failure.Try to reinstall the windows again but i recommend you to make a clean install (format hard drive and install the new windows)
Feb 06, 2010 | Gigabyte GA-MA790X-DS4 - Motherboard - ATX...
Need to have 3 way conversation on Panasonic KX-T7730
Steps
  1. Call your friend.
  2. Tell them that you will connect your other friend.
  3. Press talk to put your first friend on hold.
  4. Dial your second friend's number.
  5. Press talk again.
  6. Wait for them to answer.
  7. When they have answered, press talk again to bring the first friend back on the line.
  8. You made a three way call!
Option 2
  1. You can press the button that says 'flash' on the phone.
  2. Then dial the number.
  3. Press flash again.
Option 3
  1. While on the phone dial a number and press call/talk.
  2. When the dialed number answers press the options button.
  3. Select merge/join/combine calls or press call/talk again
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Mar 04, 2009 | Panasonic KX-T7730 Corded Phone
Cannot un-ignore fable 2 friend
This has never happened to me but the only thing that i can think of is, try to remove that friend and then adding them as a friend again.
Feb 28, 2009 | Microsoft Fable 2 for Xbox 360
Compaq Armada M700 Notebook Logo
43 people viewed this question
Top Compaq Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
