Question about Compaq Evo N610C Notebook
My n610c won't light off
The three green lights by blue turn on button light and orange power light flashs but nothing else occurs. It does it fully loaded, without battery, without ram.
I looked at my ac adapter which is:
input 110-240~ 1.5A 50-60hz
output 18.5V-----4.9A
90w
It came with the computer, the computer has run flawlessly for over 4 years. I purchased a new computer and haven't used the n610 for months and when I turned it on I get the above. Any help will be most appreciated.
Thanks,
    Genius:
  • Compaq Master
  • 1,252 Answers
It seems that your battery has become deep dischare to charge it leave it power on for atleast 12 hours
Posted on Sep 29, 2008
SOURCE:
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
After pressing the on button it turns green for 5 seconds then it flashes yellow/orange for a second then it flashes red.
Yellow Light of DeathThe "Yellow Light of Death" or YLOD is the common phrase people use to describe the following sequence when they try to turn on their PS3:
  • Press Power Button
  • Red Light Flashes Three Times
  • Yellow Light Flashes
  • Green Light Flashes
  • Beeps Three Times
  • Red Light Flashes
The sequence above may vary a bit but you do see the flashing yellow light (sometimes shows up as orange) that normally you would not see when operating your PS3. The YLOD is a general hardware fault that can mean a lot of things. However, one of the problems is cracked solder that leads the PS3 to think one of its internal chips is not connected or is broken somehow. Cracked solder can happen when the chips get too hot (RSX most likely) and leads the motherboard to start bending, which may crack the solder. Changing the power supply (lower the average wattage going to the chips to lower the heat) and better thermal compound (heat dissipates faster to the heatsink) may prevent this error from occurring. However, if your PS3 has already had the YLOD, then you can reflow your motherboard every few months to keep it working (but it is not a permanent fix as the YLOD usually comes back).
Oct 09, 2010 | Sony Playstation 3 (PS3) Console
Waste inki absober is full. The indicator orange
You can remove the top of the printer to remove and clean the pad or reset the printer and continue without cleaning.
These are the instructions which worked for me on my Canon pixma ip470 and has work on many other Canon models:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Feb 15, 2010 | Canon PIXMA iP90 Mobile Printer
I have a Dell Inspiron 1525 that won't start. The battery light would flash orange 4 times then blue once, and then start over with the same sequence. Pulled the power board and fixed the solder joints on...
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
Dec 27, 2009 | Dell Inspiron 1525 Notebook
Cannon pixma ip1700 not printing
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal.
Feb 13, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Problem on a canon 3100
The Power Light Flashes Orange - Error Codes When an error occurs, the power light flashes orange. The number of orange flashes followed by a long green flash indicates the cause of the problem.
Two orange flashes: Out of paper, paper jam, or paper feed error
If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing.
Three orange flashes: Paper jam
If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing.
Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink
Replace the empty BJ tank and press the Resume button to continue printing.
Five orange flashes: BJ cartridge is not installed properly
Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely.
Six orange flashes: BJ cartridge (printhead) is not installed
Seven orange flashes: BJ cartridge (printhead) is defective
Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge.
Eight orange flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing.
The POWER light flashes orange and green alternately: Service error
A service error means the printer requires the attention of a qualified technician. Count the number of flashes. (You may be asked this information.)
Feb 02, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Evo n610c
The computer's power light may blink to indicate that there's a problem with the power from the AC adapter.
Mar 25, 2008 | HP Compaq Evo n610c Notebook
Printer ripair
The BJC 3000 will flash two different colored lights in a pattern to signal several different errors. From the documentation I have the two colors are orange and green, could those be the colors you see? At any rate here is the code: Two orange flashes: Out of paper, paper jam, or paper feed error. If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing. Three orange flashes: Paper jam. If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing. Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink. Replace the empty BJ tank and press the Resume button to continue printing. Five orange flashes: BJ cartridge is not installed properly. Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely. Six orange flashes: BJ cartridge (printhead) is not installed. Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely. Seven orange flashes: BJ cartridge (printhead) is defective. Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge. Eight orange flashes: Waste ink absorber almost full. The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing. The POWER light flashes orange and green alternately: Service error. A service error means the printer requires the attention of a qualified technician. If you have any more questions let us know otherwise please don't forget to rate this post.
Feb 20, 2007 | Canon BJC 3000 InkJet Printer
Compaq Evo N610C Notebook Logo
128 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
