Question about Sony TA-N9000ES 5-Channel Amplifier
AMP PROTECT I HAVE A SONY AMP AND N ALPINE HEAD UNIT IN MY BOAT. EVRYTHING WORKS FINE UNTIL I START THE ENGINE, THEN THE AMP GOES INTO PROTECT. IF I PULL THE FUSE TO RESET THE AMP IT WORKS FINE UNTIL I TRY TO START THE BOAT AGAIN.. HELP ME OUT PLEASE..
MAKE SURE THAT YOUR POLARITY IS OK FOR THE SPEAKERS.TRY TO TEST THE VOLTAGE BEFORE STARTING THE ENG THEN AFTER AND SEE IF ITS THE SAME OR MUCH MORE.
Posted on Aug 23, 2008
Amplifier causes subwoofer to emit super high pitched sound
YOU NEED NO CHACK THE GROUND CABLE SOMETIMES WITH THE SAME POWER THAT THE AMP NEED START TO BURN THE CABLES AND IF THE GAUGE OF THE CABLE IS NOT THE CORRECT CAUSES THAT PROBLEM TRY TO PUT 2 GROUND CABLES (GREY) IN DIFERENT PLACES AND IT MUST WORK!
Feb 10, 2010 | Sony XM-475GSX Car Audio Amplifier
I have an Alpine M500 mono amp that works great, until you turn up the volume. I can adjust the bass down at the head unit, but at higher bass the amp shuts off. And then comes back on after a couple...
I don't think either, I believe your running theamp load too low with too low an ohm speakers and this cases the amp to produce more power but not stable and it overheats and the thermal protection cuts the amp off when the temp gets too hot to prevent damage.. Make sure your speakers depending on how they are wired do not exceed the amps load rating
Oct 26, 2009 | Alpine MRD-M500 Car Audio Amplifier
Head unit beeps in my boat.
It is a low voltage warning beep. They will beep even with the slightest voltage dip. Very annoying. You may be able to go into the set up menu and turn it off or lower the volume of the beep.
May 01, 2017 | Rockford Fosgate Car Audio & Video
Sub cutting out
Check the 12v wire running from the battery to the amplifier. Also the sony explode is a garbage subwoofer compared to the Alpine.. sony (they say 1200w max but its more like 100w to power the thing) Amp could be going. Is the amplifier hot when running. If there is a burnt smell comming from the amp, its the amplifier
Mar 27, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
Sony Xplod 1000W workign strangely
need a bigger gauge hot wire going to your amp ,maybe a battery cap. amp isnt getting enough power to perform so it cuting out.
Mar 01, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Amp gets power but no sound
Hello, First of all with these new Alpine amps everithing adjustable just about is digital, as well as the internal workings of the amp to a point. If you bought this amp new then check your warranty or take it back where you purchased it if you can. Check that your amp is getting an input signal from your head unit. Check your head unit sub output settings, something could have gotten turned off or down. On this paticular amp if there is a problem internaly it would let you know or go into protection mode. You say your sub has ben tested and is good, check again. Hook another speaker up to the amp. Unhook that speaker and try, you never know. Like I said, if the amp is'nt going into protect mode and the digital display is'nt telling you any types of faults then it has to be the input signal. Make sure you are getting a signal. That has to be your problem otherwise amp would be in protect mode. Let me know what you find.
Feb 12, 2009 | Alpine MRD-M605 Car Audio Amplifier
Amp went into protect, but front speakers sound distorted too
If the amp still goes into protect mode, the easiest thing to do is disconnect the RCA cables from the amp and see if still goes into protect mode (after turning off/on). If it does, the issue lies in the amp or the wiring to/from the amp (most likely case). Check to make sure no speaker wires came loose and touched +12V or ground (car body). From the sound of it, my guess is something internal to the amp died and will need repair.
Mar 22, 2008 | Car Audio & Video
Amp goes to protect mode only on cd play
Do you get adequate bass on the radio, or is it a bit quiet on the low-end?
Apr 15, 2007 | Sony CDX-SW200 AM/FM Compact Disc...
Amp staying in protection mode
No, this amp is not a heavy power consumer- matter of fact it takes very little power to run.Maybe you should check the fuses on the amp to see if they are what is recommended.Also check your fuse kit to your amp- your fuse might not be big enough.If neither works take it back where u got it.
Jan 01, 2007 | Soundstream XTA880.2 Car Audio Amplifier
Sony TA-N9000ES 5-Channel Amplifier Logo
100 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
