Question about Electrolux Refrigerators
We have a 3 way fridge in our camper and recently refuses to power up on gas, it works on hook up to electricity, do you know of anyone in the Leitrim area in Ireland or anyone in Ireland that we could go to to have it serviced, thank you, regards Maura Murphy
  • 51 Answers
You can go to Dometic.com or to the Norcold on the internet they will help locate some one for you.
Posted on Sep 08, 2008
2008 camper. fridge keeps switching over to gas. Turned it off & back on, it goes back to AC. The camper is plugged into a 50amp outlet & all else works fine.
Check your fuses and circuit breakers to see if any are tripped or blown. If you are handy with a test meter you can check for power at the refrigerator control panel. There will be a vented cover outside behind your fridge and there are two leads going to a heating element. You can check for power or continuity through the element.
May 12, 2015 | Dometic RM2852 Refrigerator
1992 Sierra 5th wheel fridge not working
Hi your frige works with heat applied to the coil at the rear of the unit.
the first thing to know is the when turned on at the control panel if running in gas or electric you must feel a heated area on the rear of the unit (access from the outside access panel) the vertical cylinder at the right rear (after some time a half hour or more) should be hot to touch, if not. go on line and look up-camper refrigerator troubleshooting. and follow the questions. remembering the controls need to have 12 volts to operate in any mode and 120 volts to operate in the electric mode and lp to operate in gas mode
May 23, 2014 | Cars & Trucks
Hello, my dometic camper fridge runs great on gas but just clicks when i switch it to electric...??? any advice thanks Stephanie
The mains heater has a different thermostat. Check power to the heater, and the back coil is getting warm
Apr 27, 2012 | Dometic RM2652 Refrigerator
I know this is a vague question. (trying to help out hubby) I am currently at work, however, our norcold elect/gas fridge/freezer in our mallard camper stopped working properly. the lp gas light is lit,...
Don't be despirate.
You need a little more knowledge ... I'm here to give it.
Your RV refrigerator requires 12 volts to operate; on gas or on electric ... it needs 12 volts - period.
Now then, your frig will get 12 volts from your 'power converter' AND/OR your battery. You do have a battery in your unit, correct? If not - why not? Get one. (Your power converter cannot provide all the 12 volts you potentially require in all circumstances. It is there to charge the battery, which CAN supply all the 12 volts you require. The converter can probably put out 15 amps - your battery can put out 100 amps or more (@ 12 volts DC). Relying only on the converter for your 12 volts will cause over heating and will eventually destroy the converter. Batteries are about $100.00 - converters are about $300.00.
As you know, your frig will run on gas if you are plugged in or on generator ... that allows your frig to get the 12 volts required to run the controls.
What about electric operation? If you are plugged in or on generator, you can run on electric because your Norcold has 12 volts from the converter and/or battery.
Whats going on? Your absorbtion type refrigerator requires a heat source to boil the ammonia mixture to create "heat removing" (you can't really cool anything ... only remove the heat from it!) You can heat the ammonia with a flame or with a electric CALROD. However, the control panel that drives the whole operation runs of 12 volts.
You have a battery and generator and are plugged in and it still doesn't work? You will find a fuse on the control panel in the compartment accessible from the outside of your unit. Check/replace the faulty fuse and you will be back in business.
I hope this helps you and hubby with your Norcold Frig. Thanks for your interest in FixYa.com. If you found this solution to be helpful, please vote. Thanks
Aug 02, 2010 | Refrigerators
Camper fridge does not work on gas.
right where the gas comes out there is an elect igniter do you see or here it clicking some times carbon buildup causes it to ground out inproperly sometimes the bracket gets rusty the bracket needs to be able to fire a spark directly twards the jet good luck
Apr 12, 2010 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Our Dometic RM2193 cools on gas but does not work on electric
It could be as simple as a blown fuse at the fridge. Also check to make sure you have turned on the electric switch that allows the fridge to run on AC. Note, you can only operate the fridge on EITHER gas OR electric, but not both sources at the same time, thus, you have to turn off the gas switch before you can run on electric.
When this unit is running on electricity, it has to have the thermostat set for it to run.
Here's a link to the Dometic manual for your model.
http://www.alcovr.com/DATA/MANUEL/DometicRefrigeratorModelsRM2191&RM2193.pdf
Just follow the steps for running on electric and you should be OK.
Hope this helps.
Jul 30, 2009 | Dometic RM2193 Compact Refrigerator With...
We have a 2007 Palamino Yearling Model 4101 Pop-Up Camper and recently it was vandalized and the wires from the camper to my vehicle were cut and destroyed so we have to replace the vehicle end plug to the...
Is this a six way plug (six round holes)? If there are six wires coming from the trailer, then the color code should be as follows:
White - Ground
Brown - Tail Lights
Yellow - Left Turn
Red - Stop
Green - Right Turn
Blue - Auxiliary Circuit (Battery Charge, Electric Brakes, etc...)
If you open the plug up that was cut, it is labeled as to which goes where.
TM = Tail Lights
RT = Right Turn
LT = Left Turn
S = Stop
G = Ground
Center = Auxiliary
Jun 27, 2009 | Rv Motorhome Dual Co & Lp Gas Alarm...
Dometic fridge inop on A.C. power
There is a fuse at the back of the fridge located near the compressor. You've done quite a bit of checking, so rathe than try to get into stuff, here's some quick info and a link to the manual for your fridge, which should help.
The control switches have to be set a specific way depending on what source is being used and the thermostat turned on when using AC power. Check item #3 Operating Instructions on Page 6 and the control panel switches on Page 9.
Here's the manual for your model, save a copy and print it out and take some time to review the section #3 Operating Instructions on page 6.
Possibly the installation instructions will assist in determining how it was installed in your RV, but usually the installers build around stuff, so you might have to remove some trim in order to get the fridge out, etc.
Hope you find this helpful and will you resolve your issue.
Jun 09, 2009 | Dometic RM2193 Compact Refrigerator With...
Freezer working on gas but not fridge compartment.
Check to see if you have the right gas pressure at the refer
Jan 26, 2009 | Dometic RM2652 Refrigerator
Refrigerators Logo
141 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
