Question about Compaq Evo N1000C Notebook
Ive used a generic dc adapter and it was charging
Went to the bathroom and my aunt said that the laptop started to spark and she pulled the plug out i then went to power it on and now it just flicker when i press the power button the light that represent the battery function flickers no dc power at all have i fried the mother board
  • 79 Answers
Possibly. You should always use the correct DC adapter. Try switching the adapter and then the battery if that does not help.
Posted on Aug 20, 2008
Plugged in not charging
If the laptop shows it's on AC when plugged into your card adapter, then it's the charging circuit on your laptop. But if the laptop shows that it's running on battery when plugged in, then the problem is with the car adapter.
If you happen to have a voltmeter/DMM, check the adapter to see what voltage is coming out of the barrel connector.
The Computer Cat Corner
Jan 21, 2014 | Amstron Toshiba Satellite P305-S8823...
Fault finding
What! !O_O!
For a statement, such as, "Motherboard not on", you would be stating the motherboard either does not receive power, or the motherboard does not use the received power.
Primer:
You press the Power On button. The first chipset to receive power is the BIOS chipset. The Basic Input/Output System program is initialized.
BIOS looks to see what devices are connected, does a Ram Memory count, turns the Processor (CPU) on; and hands the computer over to the Operating System. (In this case a version of Microsoft Windows)
If the statement is the motherboard is not turning on, you are in effect stating the BIOS chipset is Not receiving power.
Diagnoses must start from the AC adapter (Charger) You need to know if the AC adapter is putting out the correct Voltage. Also while testing have an assistant, gently wiggle the cable FROM AC adapter TO laptop; and power cord TO AC adapter. Any fluctuation in the reading, means a broken wire.
AC adapter proves to be good, the diagnoses goes to the DC Power Jack. The DC Power Jack is the jack on the laptop, that the AC adapter plugs into. (DC_IN)
AC adapter removed, Battery removed; a small instrument is used to see if you can gently move the DC Power Jack. ANY perceptible movement means a bad DC Power Jack -> Replace.
DC Power Jack checks out OK, then the problem will most likely be the Power MOSFET's on the motherboard. They determine if the Battery is to receive a trickle charge, or full charge. Also determines if the laptop is to run off of the Battery, or just the AC adapter.
Using the HP Pavilion dv6000 series, and Pavilion dv9000 series of Notebook PC's; as an example,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
I can give a lot more, than the generic information above, if I had the Model Number of the Acer laptop. This is on the Bottom of the laptop. Post back in a Comment.
Regards,
joecoolvette
Apr 23, 2013 | Acer Computers & Internet
Plugged in and not charging
1) Use a multimeter, check the AC adapter (Charger) for power.
Make sure it is putting out the required voltage.
Have an assistant gently wiggle the cable FROM AC adapter TO laptop. See if there is an intermittent reading on the multimeter.
Have an assistant gently wiggle the power cord.
An intermittent reading on the multimeter indicates a broken wire.
Power cord is bad? Replace cord.
Cable from AC adapter to laptop is bad? Replace AC adapter.
If you have posted the laptop manufacturer NAME and MODEL NUMBER, I could have given you more than generic information.
Model Number is in the Bottom of the laptop. Post back in a Comment.
AC adapter works OK?
Check the DC Power Jack.
DC Power Jack checks OK, this is your problem,
Regards,
joecoolvette
Jan 31, 2013 | Computers & Internet
Gateway kav60 not charging. i have to wiggle the cord and sometimes it refuses to charge.
I guess you've got a broken laptop power dc jack or power cable.
Symptoms of a broken Laptop DC power jack:
- The laptop only operates when you hold the DC power plug in a certain direction (DC jack is broken or loose).
- The laptop only runs on battery power (no power is getting through the DC jack).
- The laptop gets no power at all.
- The laptop will not charge the battery.
- The laptop switches from AC power to battery power intermittently due to a loose or broken power jack.
- The laptop suddenly shuts off.
- The DC jack may feel loose.
- Sparks come out of the back of the laptop when you insert the power plug into the DC jack.
Apr 21, 2011 | Lifetime Gateway KAV60 Replacement Laptop...
2 months ago ive bought new charger...cause there was a fault with my previous one. It might also be a socket on laptop, so ive fixed both of it!but in the recent time,something went wrong...my charger...
Turn everything off. Take off the battery. Connect the ac adapter and turn on your computer. If it works with the ac adapter connected and your battery off then you have a defective battery.
If it does not work then it's either your ac adapter or your dc jack inside your computer. Try a different ac adapter at the store you bought the battery and you'll know if your adapter is bad. If it works with another adapter then exchange the adapter again (I know, I know, I've been there). If it does not work with another adapter then you're back to the dc jack but at least you'll know for sure.
Make sure that whoever is replacing the dc jack is good at soldering and replaces it not just solders the same one back on. Don't forget the shield to the dc jack. Good luck!
Oct 16, 2010 | Computers & Internet
Dell 2650 DC wont work
make sure the charger you purchased has the correct voltage out and amperage(in millivolts) as requested by the laptop computer, if not you risk the chance of damaging your laptop. although they fit in the power plug, it does not mean theyre compatible. The specs should be located at the bottom of the laptop or inside the battery bay.
Apr 01, 2010 | Computers & Internet
Battery wont change
A problem is just like a mountain. You don't jump over the mountain, you climb it in steps, one step at a time.
1.How old is the battery? 1 to 2 years old, you can expect it to be at the end of it's Life Cycle. Batteries are rated in so many hours of usage.
Best bet is to let the battery charge 24 hours, then try it.
Would be nice if you someone else that has an Inspiron 1525, and they would try to charge your battery. If it doesn't charge up, you would know it's the battery. If it does charge up you can move on down the charging system, to try to find the problem.
2.AC adapter, (Charger) If you have a multimeter, set it to the 50 volt DC scale.
Laptop and desktop computers use DC current. (Direct Current) Your house, for example, uses AC current, (Alternating Current)
AC is converted to DC by the AC adapter, (Charger)
An example of DC current are flashlight batteries, and your laptop battery.
DC current has a Positive pole, and a Negative pole.
The center pin of the plug of your AC adapter is the Positive pole. Any of the four outside pins on the plug, are Negative.
The Red, (Positive), probe of the multimeter goes to the center pin. The Black, (Negative), probe goes to any of the outside four pins on that plug.
Example of a DC Power Jack, for the Dell Inspiron 1500 Series of laptops, 1525 and 1526, (This is the jack inside your laptop, where you plug the AC adapter into),
http://www.megaemarket.com/dc-power-jack-for-dell-inspiron-150150015011505.html
3.It may be that DC Power Jack itself is bad, or one of the solder connections is cracked. It's hard to see it clearly on the link I provided, (So I Right-clicked on it, Save Image As, and put it right in my My Pictures folder. Then I magnified it), but in the photo you will see some metal pins sticking out of the rectangular body.
The metal pins are sticking up. In reality those pins go down, when the jack is mounted on the motherboard. They go through the motherboard, via holes, and are soldered on the other side.
It is these solder joints that may crack, is what I'm referring to.
Solution to 1?
Obviously buy a new battery.
Solution to 2?
If your multimeter findings show lower voltage than needed, it's time to buy a new AC adapter. They have generic ones that can be used on a variety of laptops. The voltage will be stated on the top of the AC adapter.
Example: 19.2V-1.0A
That's 19.2 Volts at 1 AMP.
It may just be the plug end on the AC adapter itself. The plug end that goes into the DC Power Jack, on your Inspiron laptop.
Solution to 3?
Unless you are a skilled Electronics Technician, and have Excellent de-soldering/soldering skills, I advise taking it to a computer repair shop. It may not just be cracked solder joints. The DC Power Jack may need to be replaced. Maybe the motherboard is one of a bad design, and where the DC Power Jack attaches to it, has cracked.
Jul 25, 2009 | Dell Inspiron 1525 Notebook
No power at all for my Dell Latitude D505
Sounds Like From Your Description That You Need Your DC Jack Repaired/Replaced..
THe DC Jack Is the Port where Your AC Adapter Plug Plugs into on the laptop.... THis can be proprietary or non proprietary.... But Either way, the Old Faulty Jack Needs To Be Desoldered and Removed, THe Board Cleaned and a New DC Jack Soldered On.. You Will Then Be able To Power On Laptop With AC Charger and Will again Be Able To CHarge The Battery..
Nov 19, 2008 | Dell Latitude D505 Notebook
[[ACER WONT TURN ON]]
You might of fried the whole motherboard when it sparked. Check if there is a fuse. Bridge the gap, and it should turn on. If not PULL THE PLUG.its something else that went wrong.If you don't, it smells really bad. Ive learn't from experience...
Jul 28, 2008 | Acer TravelMate 2300 Notebook
Compaq Presario 1200 won't charge battery
dear N9YK
you can follow this
If you have a loose connection where you plug in the power on your laptop, or it works intermittently, you could have a bad dc jack. Symptoms
  • Move the power plug and the laptop loses connection
  • Broken or cracked dc jack
  • Laptop won't charge but worked on battery
  • Power LED and battery LED flicker when the adapter tip is moved
  • Battery won't charge
  • Sparks come out the back of the laptop
Why does this happen?
  • Flaw in manufacturer designs
  • Use of universal or non-original ac adapter
  • Lots of plugging and unplugging of the ac adapter
  • Tripping on or pulling the ac adapter cord
or you can check your dc amper in your adaptor
oke
thx
cropp
Mar 16, 2008 | Compaq Presario 1200 Notebook
Compaq Evo N1000C Notebook Logo
82 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
