Question about Acer Aspire 3000 Notebook
Power Supply problems
I thought that my Acer Aspire 3000's power cord had gone bad, but I just bought a new power cord for it, and for some reason, it still won't work, I plug it in and it won't even come on.
  • SaphireAngel Aug 21, 2008
    I've never taken a laptop apart before, about how much will it cost to take it to FireDog, or Geek Squad and have the problem fixed?
  • 25 Answers
I'm having the same problem here... I just ordered a new DC Jack I'll keep you guys posted if that was the fix or not.
Posted on Aug 21, 2008
  • 55 Answers
Hello :
Sir u are facing a probleme with your ac adaptor jack in your laptop maybe yo need to change it .
changing of a ac adaptor jack its not an easy task you will need a soldring kit & a new propre jack for u laptop
dont forget rating this post if this is not helping u tell me so i can help u further .
Posted on Aug 20, 2008
Acer 5050 laptop no power
I have the same thought.
But please check the new power adaptor has the same output voltage as the old one.
If same the power supply unit needs to be changed on the laptop.
All the best!
Sep 02, 2009 | Acer Aspire 5050-3242 Notebook
Acer aspire 3000 battery problem
I think due to Battery your laptop should not be slow . But as per the RAM in your laptop you need to add some more RAM with WinXP and SP3 with the type of Configuration it will be slow with or without power.
Mar 12, 2009 | Acer Aspire 3000 Notebook
Computer shuts off
Maybe it's your power supply, I suggest you get a voltmeter and check the voltage on the power supply.
Good luck
Nov 07, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 5000 Laptop
Have you tried changing the power settings,in control panel go to power options and change the time settings for when the laptop is plugged in and running on batteries.
Also change the power scheme to Portable/Laptop.
I hope this helps,please let me know WF
Aug 20, 2008 | Acer Aspire 3000 Notebook
Auto hibernated, will not power back up
It's possible that the laptop is stuck thinking it should be resuming from standby but cannot find the data in memory. Remove the battery, unplug the power cord, and hold down the power button for at least 10 seconds. Then plug JUST the power cord back in and try to boot the system. If you still get no response then it's possible that one of your RAM sticks is going bad. With the battery and power cord removed try removing both sticks of RAM. Then try to boot the system again with only the power cord in use and no RAM installed. See if you get some sort of response from the BIOS. Hold down the power button to turn the computer off again, remove the power cord, and then try booting the system with just one of the memory sticks installed. If you can isolate one of the sticks as causing the failed boot, then that stick is most likely faulty.
May 13, 2008 | Acer Aspire 3000 Notebook
Ac adapter for laptop
is that the cord, on which side of the adapter?
check out www.laptopparts.com
Feb 21, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 3000 Power Issues
In this case myself assume that your acer do a problem in the memory, try remove and clean the memory.
1. boot your acer without the memory. hear beep? if yes,
Only memory has a problem, if no, then;
examine the mainboard of your acer.
If you can hear a beep then fix back the memory and start the system.
if this not solve the problem, replace the memory.
In case that it hard for you to open the laptop let the repairman do it for you so that all your problem will be examine.
Jan 22, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 3680 Laptop Can't Power Up
acer aspire 3680 no power on, found 2 short circuited surface mount capacitors on motherboard replaced lapton power on works fine. Edward
Jan 19, 2008 | Acer Aspire 3680 Laptop
Acer aspire 3500 wont hold charge or turn on
remove the battery and see it the power comes on, if so bad battery, check the connector where the power plugs into the laptop, sometime this breaks or has a cold solder joint, you can test this by wiggling and looking to see if the power lights up. last and worst case is a bad main board.
Jan 07, 2008 | Acer Aspire 3100-1405 Notebook
Acer Aspire 3000 Notebook Logo
103 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
