Question about Dryers
I have to change the plug on a whirpool drier as the wall plug at the rented house is different. i have bought the new cord to install and when i took the cover off the old wiring, all wires are grey and there is no indication on the back of the dryer saying which is red, green etc - the wires on the new cord are all color coded. model is WED5s.....
  • steveaa1975 Aug 21, 2008
    thanks
    found if i undid a few more screwws, i could see the colors and then did what you said
    thanks
  • 770 Answers
Ok on the terminal block looking in from the back you have 3 terminals on your new cord there is a Black a red a white and a green the Black goes to the far left terminal the white goes in the center terminal the red goes on the left terminal the green goes to gound or a green screw on the back of the unit if there is not a green screw then use the screw that holds the cover plate on
Posted on Aug 20, 2008
  • Gary Davd
    Gary Davd Aug 21, 2008
    Glad i could help
    Thx for the rating
How to get the wii to turn on
Plug it back in make sure the wall input plug is not shorted aswell as breakers in the house! You can also get a volt tester to see if its the power cord and not the wii
Jul 17, 2015 | Nintendo Wii Console
Installation diagram
240 volt electric cord, and a flexible usually 4 inch, exhaust hose.
Install cord to drier.
Install flexible hose to driver using the clamps provided.
Install plug into the 50amp drier outlet.
Install the other end of the exhaust hose to the vent going outside.
Carefully move the drier back into position almost against the wall without crushing the vent hose..
May 07, 2014 | Dryers
Got a used dryer had a 4 prong my house is 3 prong, changed the 4 prong to 3 prong plugged in and wont turn on, what do i do?
There is a difference between how a 3 prong and a 4 prong power cord is installed. Please read the following link:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
If you have the power cord installed correctly and still do not have power, please check for 220-240 VAC at the wall receptacle. If you require additional assistance, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Aug 05, 2010 | Kenmore 64902 Electric Dryer
Need to change 4 prong drier plug to fit 3 prong eletric
Purchase a 3 prong dryer cord. It is simpler and safer than changing the wall outlet.
Nov 03, 2009 | Dryers
Our Wii wont turn on at all. Tried new power cord, different outlet but nothing.Wont even eject game? Game bought new in sealed box and 6 months old
Did you remember to plug the Wii in at the wall? If not, you are mentally handicapped... TO BE CONTINUED...
Oct 17, 2009 | Nintendo Wii Console
I have a Maytag dryer (not sure the exact model #). I need to install a 4-wire power cord. There are three primary internal connections. Appears to be blue, white and black. But, 4-wire power cord has...
The laws in most states are changing to where the NEC2.gif Code requires the use of this 4 prong plug. It is quite common to see this 4 prong plug installed in new apartment buildings and rental properties because of this law requirement.
So what you have is a red, black, white and green wire on the dryer side of this wire plug.
The red and the black wires are your hots (110 volts) and shall be connected on each outside screw of the drier electrical terminal and the white wire (neutral) shall be connected to the center screw.
So now you are left with an extra green wire with no place to hook it huh?
I suggest just loosing one of the drier electrical terminal mounting screws and hooking it there. The ideal here is to ground the outside body of this machine to prevent possibility of electrical shock if water is present (like a leak somewhere nearby).
In actuality this really serves no viable purpose because the white wire does exacly the same thing, just in a different manor,,, but hey,,, our law makers are not certified electricians either. They just like new ways of stimulating sales and profits.
Note: if you are in a rental property and this 4 prong wall receptical is installed, I would not suggest you remove it or change it in any manor, as this will open yourself up to possibile legal liabilities if an incident were to occur,, like fire.
Oct 10, 2009 | Dryers
I bought a roper with a 3 prong but i need a 4 prong. i bought a 4 prong plug but I don't know where to connect the left over wire in the dryer.
The laws in most states are changing to where the NEC Code requires the use of this 4 prong plug. It is quite common to see this 4 prong plug installed in new apartment buildings and rental properties because of this law requirement.
Oct 09, 2009 | Roper REX4634KQ Electric Dryer
Too many prongs on dryer power cord???
Do not just swap out the cord on the dryer. It has 4 prongs for a reason.
You will need to call a licensed electrician to change your outlet for the different service.
Jun 17, 2009 | Whirlpool Dryers
Dryer not working
Assuming the problem is associated with you changing the cord, it sounds like you have a wire crossed on the power cord. Double check how you have the cord installed first. If that is correct check your power to the dryer. Since you changed the type of cord, I assume you have had outlet replaced or have just moved to new house. If you have a fuse box instead of a breaker box, check your fuses. It takes two fuses for the dryer. If one of them blows, the motor will run but you wont get heat. The motor runs on 120 but it needs 240 for the element. I can't count how many people have bought a new dryer just to find out they only had a house fuse blown and nothing was wrong with their old dryer. If you have had wall outlet changed there could be a wire crossed in it.
Oct 05, 2007 | Roper REX3614KW Electric Dryer
Dryers Logo
55 people viewed this question
Top Dryers Experts
