Question about GN Netcom GN 9120 Professional Headset
Trying to switch out my base unit on the 9120 I am trying to trouble shoot a loud screeching sound that happens when I hang the phone up cant get my head set to switch to the new base
  • 16 Answers
The loud screeching is probably due to the headset mic volume being too loud, or the campatability setting on the base station is in the wrong position for your phone.
To register a new earpiece to a base station, simply put the headpiece on the charging dock and leave it there while you disconnect the power, wait about 20 seconds and then reconnect the power. All the lights on the base should flash a couple of times and then the green charging light will start fashing as normal. The headset should then be registered.
Posted on Nov 05, 2008
Lost one of the phones and now all of the phones for shwing "line in use" cant call in or out
Try putting one of the other phones on the home base. If that doesn't work go to the manufacture's web page and look for trouble shooting and tech support.
Dec 14, 2015 | Lands Phones
Loud Screeching
Check the drive belts or serpentine if there is only one. sounds like one is slipping.
Dec 11, 2013 | Mitsubishi Cars & Trucks
My wireless phone is about seven years old. There is a loud static sound in the dial tone and a loud buzzing sound when I am talking, which can also be heard by the person I am talking to. I just put new...
Try disconnecting the cordless phone base unit from the phone jack where it's connected and plug in a basic corded phone. If you still have the noise, the trouble is in the phone line itself and you'll need to contact your telephone service provider.
If the phone line isn't at fault, the trouble is in the base unit. Most likely, the power supply filtering isn't working, and you're hearing hum in the audio as a result. If the base unit uses an external plug-in adapter (a "wall-wart") with a DC output, you can try replacing it with a new one. Radio Shack sells replacements. Just be sure to get one with the same voltage rating, the same or higher current rating, and the right polarity plug. It may be that the old adapter isn't filtering any more because of its age.
If the adapter is an AC output type, or the base has a built-in power supply with a regular AC power cord, you should probably shop for a new phone. The trouble is in the unit itself, and you'll spend more trying to have it fixed than it's worth.
Dec 26, 2010 | Uniden Lands Phones
Hi, I have the GN9120 and they are getting ve...
Hello Jennifer,
I do not own a GN9120, or anything similar (I have an old bluetooth earbud for a cellphone), but it sounds like a typical exhausted battery issue.
Batteries get old and sometimes do not charge to full capacity. According to the pdf manual from Jabra, the headset will beep every 20 seconds if the battery is low.
Another idea is maybe they are drifting off-frequency, either the adjustment got knocked off (if there is a physical adjustment inside), or the capacitor or other component values have changed to cause them to transmit off-frequency. I am surprised there is no sort of squelch on the base unit like they have in wireless microphones used on-stage.
Also check the phone cable between the base unit and any other phone cables.
My last thought is check the power supply for the base unit, sometimes they fail and output too low of a Voltage or start becoming noisy with power line noise.
I hope you figure it out! :-)
I am thankfully not near the fires here in California...
Oct 18, 2017 | GN Netcom GN 9120-28 Wireless Headset
Fridge making loud screeching sounds
Generally, in my experience, the loud screeching is caused by one of the fan motors or fan blades. There is a fan inside the cabinet (possiblle two, one on the freezer and one on the refrigerator side). Also, there is a fan underneath the unit near the compressor (probably in the back).
If the screeching is coming from underneath then pull the unit out from the wall and remove the cardboard cover at the bottom back. Now turn the unit on and check for where the screeching is coming from.
If it is the fan blade (hitting something) or the motor, you can remove these and replace them easily. UNPLUG THE REFRIGERATOR BEFORE TOUCHING ANYTHING UNDERNEATH THE BACK OF THE REFRIGERATOR.)
Good Luck!
Oct 28, 2009 | Samsung RS2630SH Side by Side Refrigerator
Loud screeching sound coming from the unit
It sounds like the fan motor needs lubricating. Do you need help with this?
May 05, 2009 | Amcor A12000E Nanomax Portable Air...
Is this just an expansion.do i need a base unit
I 'mixed' two sets by not pluggin the 2nd base unit into the phone line, thus treating it as just another remote.  Then I registered each remote into the one base unit and they all work fine.  Try re-registering the entire set of phones to one base unit.  Make sure it's a base unit that supports that many remotes.
Apr 22, 2009 | Uniden 5.8GHz Dual Cordless Phone
Loud screeching sound from window fan.
There are two bearings in most motors.  One is at the base of the fan blade where the shaft goes into the motor.  Try lubricating this with a small amount of household oil.  If your lucky, this will stop the problem.  If not, the bearings have worn and the unit will need replacing.
Nov 15, 2008 | Honeywell HW628 Window Mount Fan
Battery Light Won't Go Solid. Lot's of clicking sounds and lights flashing (GN Netcom 9120).
It sounds like it may be a defective unit in that the charging points on the base and the earpiece are making intermittant contact, hence the clicking noise you get when the unit goes into headset mode and the fact that the battery never reaches a fully charged status.
A couple of things to try:
  • Check the charging points/contacts on the base and the earpiece for damage.
  • If they look ok, gently clean them with some spirits and try again.
Nov 07, 2008 | GN Netcom GN 9120 Professional Headset
GN Netcom GN 9120 Professional Headset Logo
363 people viewed this question
Top GN Netcom Radio Communications Experts
Tom Chichester
MrFixitSTTL
techmncpa
Level 1 Expert
Are you a GN Netcom Radio Communication Expert? Answer questions, earn points and help others
