Question about Danby (DAR604BLS) Refrigerator
Ge refrigerator model gss22wgph bb
Side by side frige is only 2 years old but the freezer side is cold...the refrige side is not cooling. I checked the freezer vent that cools the frige side and it's not obstructed. I noticed a thin layer of ice on the back panel inside the freezer and that the bottom of the freezer is cold than the top part where the vent that cools the frige is located. What should I do?
  • 1 more comment
  • branberry123 Sep 15, 2008
    same exact problem. I feel no air flow in the refrigerator
  • Anonymous Mar 25, 2014
    Its an Ice Craft bar freezer, model nr G.85-3/W serial nr B47882. Its a very old freezer, on the lable it says ( a product of autocraft ) It been working for ever and I let it stand for about 2 weeks and now its not working anymore, the pyps at the back is still heating up so it sugests that there is something going on, but its is not cooling on the inside. As I said, its very old and been in the family for more then 25 Years. Pleas help me to repair my old friend.
  • Anonymous Mar 26, 2014
    Freezer is cold but not refrigerator side vent is clogged up with ice controls set on cold max
Carben,
I have the same problem and I am able to resolve it by defrosting the element which is behind the inside rear panel of the freezer. I use a hair dryer to melt the ice build up. It happbed a couple of times so I know that there is a cause for this which may be the defrost heater but I am not sure how to confirm this. Let me know if you have any ideas.
Posted on Sep 16, 2008
  • 400 Answers
If you remove the rear panel or cover in the freezer compartment and expose the evaporator fins, you will notice an element attached to the bottom of the fins, the wires go out the back. This is a metal tube about the thickness of a thin pencil. It needs changing.
Posted on Mar 05, 2009
  • 770 Answers
Again check the air flow but this time do it like this open the refrig door keep freezer door closed put your hand by the vent where the air is coming in from the freezer see if you feel a good air flow?? while keeping your hand there just crack open the freezer door did the air flow change?? let me know
Posted on Aug 20, 2008
It is not cooling as well as it does usually. The freezer is cooling at frige temperture and the frige side is hardly cooling.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 31, 2011 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Hotpoint G/E Side by side refrigerator Model
I have seen this issues with GE and HotPoints. I recorded video for You. Hope this will help. I replace usually both : main board and evaporator fan motor.
Nov 24, 2010 | Hotpoint HSM25GFRSA
My side by side Model GSH22KGRE BB freezer is
there is one of 2 possibilities,either the damper door between the refrige and freezer compartments is frozen shut due to ice build up and needs thaw out,the cold control that controls this door is bad or the mother board on the lower rear apron behind a cover panel is defective,if you have had light bulbs go out in the refrige compartment and now the refrige part does not cool and the temp light readout is dark this is a good indication its the motherboard,also if the lights are strobing and you can hear a relay clicking
Jan 17, 2010 | Refrigerators
Freezer is 0 degrees frige side only 40 degrees
that would be a valid check
but with this model i would look more twords you thermister in the refer, if its maintiaing a constant temp, but just outta temp, its more than likely you thermistor is going bad
Oct 14, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Frige not cooling
The GE Profile is a complex but efficient refrigerator. We will need to check a few things like the evaporator, defrost element, defrost thermostat and the mother board. Let me know if you want me to go through this with you, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
http://appliancepartsandtechnicalservices.blogspot.com/
Jun 16, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
May 30, 2009 | Refrigerators
GE Profile refrig side by side Model GSS 20iEMCC, not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
df
Dec 26, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerator not cooling
If it has a filter on the bottom, make sure that is clean.
Dec 21, 2017 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSS22sgrf ss - Side-by-side refrigerator
I need to make sure that your refrigerator model and make numbers are listed correctly. Im having trouble with the information listed above your comments. I have GE data base and want you to look at the hyper link listed below.  and let me know if this or I can help lead you in the correct direction, Thanks, Sea Breeze
http://www.appliance-parts-warehouse.com/general-electric-parts/General-Electric-Refrigerator-Parts-Page-6901.cfm
Oct 25, 2007 | GE GSS22JFMWW Side by Side Refrigerator
Danby (DAR604BLS) Refrigerator Logo
906 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
