Question about Philips 50PFP5332D 50 in. Plasma Television
42PF5321D/37 Hi, thanks for posting answer to my Q. Here is my current update of what I have checked per you advice: OK, when I am watching the boards in the back, I plug in the unit to power. All the leds come on, ie..the power board, the logic board (with the 1 solid and 1 blinking led next to each other, top right of board), and the 1 (lower) led on the SSB. 10 seconds later all the leds shut off (Relays click) then 2 leds instead of 1 on the SSB lights up and stays on. Does this still sound like the SSB to you Lawrence1974?, (When i plug in the set, VS reads on a DCV scale of 20 volts - .11 then goes up to .18 , then (about 10 seconds later) the relays click and drops to zero) and BTW Thanks for posting your help! Oh, just so I am looking at the right board, the SSB is the board that has the silver phillips tuner box on it, where you plug in the coax cable line right?
  • Me Ow
    Me Ow Aug 21, 2008
    It doesn't blink anymore. solid green, until the relay kicks in and turn the unit off, and I bought it brand new in the box 2 years ago from a rent to own place, finished paying it off and 2 months later it did this, the rent place said they wouldn't fix it, so I doubt it is still under warranty, so I have no choice but to fix it myself.Unless you know something I don't. What really chaps me is that I recommended this unit to all my friend and half of them bought the same unit, Of course, theres still work great.
  • 138 Answers
That is correct about the SSB. Now before we go any futher is this set still under warranty? If so or if it is just a little out like a couple of months contact Philips @1-888-744-5477. PS. on the front of the set where the power button is how mant times do that led blinks.
Posted on Aug 21, 2008
42pf5321d/37 wont find cable channels
Check and replace its tuner. If you wish to get some details; check the site linked here. Pull up older posts.
Jul 17, 2016 | Philips Televison & Video
I have a phillips 42PF5321D/37. All of a sudden it started flashing 6 times when I tried to turn it on. I unplugged it downloaded software update and updated the tv with the instructions provided and tv...
if the tv is only working when it's being updated then there is either a problem with the update firmware or the tvs memory chip. the chip is on the main av board and its best not to touch it if you don't know what you are doing, replacing the board may only be your option.
Jun 06, 2017 | Televison & Video
I have philips 42 lnch flat screen model number
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts. .In most cases, the main board might have to be replaced.If so, a software [firmware] update too might be necessary.
Sep 23, 2014 | Televison & Video
42" Plasma 42PF5321D/37 will not power on. I replaced the fuse on the power supply board with a 3 amp (that's what it looked like, but I'm not sure it was the right size because it was burned
Always replace fuse with fuse value required If fuse value is less it will burn out . If you replace with fuse that is required and it burns out then you have bad short in power supply circuit In that case check bridge rectifier
Dec 07, 2012 | Philips 42PF9630A 42 in. Plasma Television
I have a Philips 42pf5321d/37 that won't turn on.
send me a email and I can assist you with troubleshooting it to determine whats happening with the set.
Aug 07, 2012 | Televison & Video
How to trouble shoot a Philips HDtv model 42PF5321D/37
Hi, you can try the troubleshoot procedure in your owner's manual to correct the current problem with your TV, if this does not fix it, then you will need to have the TV checked out by certified electronics tech. If you have some electronics training you might be able to do the troubleshooting your self, but you will need to sign in to our tech support services where you will be assigned an expert that will give you tech advice on what to look for, where to get replacement parts(if needed) and trouble shooting ideas. You will need some information needed, like..a good description of the problem.
Oct 24, 2010 | Philips Televison & Video
Phillips model#42PF5321D/37 black screen and red light flashes.unable to turn on. sonia
Power supply board is dead.Tries websites like, to buy a refurbish power supply board for the replacement.
Apr 21, 2010 | Philips 42PF9431D/37 TV
Plasma tv in protect mode
One of the PCB's inside has an incorrect voltage/short or dry joint, all TV now days have a diagnostic startup mode which checks all the boards, one of yours threw up a problem so the TV put itself into Protect Mode so that it doesn't do anymore damage.
Get it checked out by an engineer.
Oct 01, 2009 | Televison & Video
Philips 42PF5321D/37 Error Codes
replacing ssb for 4 blink error was correct as error is communication failure specific to micro processor on ssb. getting an alternate error after replacing ssb would suggest either wrong ssb or defective ssb. verify vendor number on ssb tuner on original and new ssb and if same reorder that board and if not order per original board
Jun 30, 2008 | Philips 42PF9630A 42 in. Plasma Television
Philips 50PFP5332D 50 in. Plasma Television Logo
327 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
