Question about Video Game Consoles & Games
360 overheating - Video Game Consoles & Games
    Sergeant:
  • 389 Answers
I CAN FIX IT! There are links that show you how to repair this issue yourself (but they are not very clear and every thing is very fragile inside the XBOX 360) or you can contact me via email at mycharminglife@gmail.com and we can discuss the issue further as I recently repaired my XBOX 360 with the same issues and it works better than when was brand new.
Posted on Nov 12, 2010
    Master:
  • 623 Answers
The red light?
happened because of playing long hours
give it some rest
turn it on if it plays
play for 3 hours on 30 mins off
if it's dead
take it to repair shop
i suggest buying th e xbox intercooler
Posted on Aug 20, 2008
Xbox overheating
Are you using an xobox original, xbox 360, xbox 360 elite, or xbox 360 slim
Aug 25, 2012 | Microsoft Xbox 360 Console
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
My xbox 360 keeps overheating
system is overheating from blocked vents and dust pileup open it up or sent it in if you open it up ther are tons of videos on youtube also voids system from being fixed by microsoft
Oct 08, 2010 | Microsoft Xbox 360 Console
How do i fix a 360 from overheating
You can either send it in and they will fix it for you or you can use a good repair guide that will tell you how to stop the overheating
Aug 18, 2010 | Microsoft Xbox 360 Console
Xbox 360
the three ring can mean av cable error nd overheating can be fixed you can buy fans for them from all good games shops there external
Dec 10, 2009 | Microsoft Xbox 360 Console
After playing a game for 10 min. or less playing on an xbox 360, the screen turns off and the xbox has 2 red lights on the ring of light the console
Hi. This two light error code is signaling that the console is overheating.
Alternatively
Overheating can be cause by the console locking up or "freezing" after a set amount of time. Lockups that occur at a specific point in a game are generally problems with the game itself and not caused by overheating.
THINGS TO TRY
1. Let the Xbox 360 console cool.
Note You may have to wait several hours for the console to cool enough. Do not turn on the console when the console is hot.
2. Verify that the console has sufficient ventilation and that the fan is operating.
PREVENTION SUGGESTIONS
To try to prevent this problem, use the following precautions:
* Do not block any ventilation openings on the Xbox 360 console.
* Do not put the Xbox 360 console on a bed, on a sofa, or on any other soft surface that may block ventilation openings.
* Do not put the Xbox 360 console in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well-ventilated.
* Do not put the Xbox 360 console near any heat source, such as a radiator, a heat register, a stove, or an amplifier.
DO NOT EVER PUT YOUR CONSOLE IN THE FREEZER OR OUT IN COLD WEATHER
Some people think that doing this might help "fix" an overheating console, in fact doing so could cause even bigger problems. Electronic devices like your console are made to function at and around room temperature, extreme cold temperatures can often cause just as many problems as extreme warm temperatures (such as overheating). Also if the console is located in a dramatically cold area while running, the difference in temperature between the hot console and cold air can create condensation which in turn will short out your console making the situation far worse. Condensation will happen more quickly if your console is overheating due to the greater difference in temperature. In short... DON'T DO IT.
A more aggressive Solution to overheating is to improve the cooling system of the console. The best solution is to replace the thermal compound. If you attempt this you do so at your own risk. If you're console is still under warranty it is recommended that you contact MS for a replacement before attempting to fix it yourself.
Nov 02, 2009 | Microsoft Xbox 360 Console
Xbox 360
It's overheating. Consider buying an external cooler at a local Target or Best Buy.
Jun 08, 2009 | Microsoft Xbox 360 Console
Xbox 360 overheating fan
http://www.youtube.com/watch?v=Uj2A7mGGjuY
That is a video that shows you how to open your xbox 360. It will void your warranty but I'm assuming its already void since you didn't send it in. If the fans running you should feel hot air coming out of the back of the xbox when its on.
Oct 06, 2008 | 2K Games Fantastic Four: Rise Of The...
Xbox 360 power off
Check the power brick. When the 360 is on, the light should be green, otherwise it is broken.
May 10, 2008 | Microsoft Xbox 360 Console
As playing Xbox 360 system shuts off two red lights occurs.
Two red lights mean your 360 is over exceeding the inside temperature. Your fan must not be working at all and your 360 is overheating tremendously. That is what I know about the 2 red lights. Im not sure what to tell you to fix this but to just call 18004myxbox.
Mar 01, 2008 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
48 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
