Replacement Blower Motor
I can not seem to find a cross reference for a GE motor Part # 5KCP39GGD197AS. Can anyone give me advice?
    Problem Solver:
  • 9 Answers
Refer to model number of unit.
Posted on Aug 21, 2008
Where is fan blower motor on 2003 olds alero
It's under the right side of the instrument panel .
Remove the right side instrument panel I/Pinsulator. Refer to Instrument Panel Insulator Panel Replacement - Right Side in Instrument Panel, Gages, and Console.
Reposition the BCM aside. Refer to Body Control Module Replacement in Body Control System.
Disconnect the blower motor electrical connector.
Jan 10, 2018 | Cars & Trucks
2008 dts caddy blower motor resister location
Your not going to like to hear this , but you'll need to take the dash apart !
Blower Motor Resistor Replacement
Preliminary Procedure
  1. Remove the HVAC module. Refer to HVAC Module Assembly Replacement .
  1. Drain the cooling system. Refer to Cooling System Draining and Filling .
  2. Recover the refrigerant. Refer to Refrigerant Recovery and Recharging .
  3. Remove the evaporator tube from the thermal expansion valve. Refer to Air Conditioning Evaporator Hose Assembly Replacement .
  4. Remove the heater hoses from the heater core. Refer to Heater Hoses Replacement .
  5. Remove the brake pedal bracket assembly. Refer to Brake Pedal Assembly Replacement .
  6. Pull back and reposition the carpet.
  7. Remove the lower instrument panel (I/P) support brace. Refer to Instrument Panel Center Support Bracket Replacement .
  8. Reposition the auxiliary air distribution duct. Refer to Auxiliary Air Distributor Duct Replacement .
  9. Remove the instrument panel carrier. Refer to Instrument Panel Carrier Replacement .
  10. Disconnect the HVAC module assembly electrical connectors.
HVAC Module Assembly Nut (Qty: 5)
Tip
Tighten the nuts in sequence.
Tighten
9 N?·m (80 lb in)
HVAC Assembly Module
Disconnect the blower motor resistor electrical connector.
Jul 28, 2016 | 2008 Cadillac Dts
A/c blower motor works if I pull power and plug back in until I cut engine off. Then I have to repeat process
Daryl, You may want to check the blower relay/ just switch with one of same type and try and if OK, problem could be the blower motor, wires/plug loose,damaged,burnt or a faulty blower motor resistor. Second link has some trouble shooting of a overheating wire problem, that is to be common in these trucks. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
DIY 2003 Silverado Blower Motor Resistor
Sparkys Answers Chevrolet Silverado Blower Does Not Work On Any Speed
03 Silverado heater fan problem ChevyTalk FREE Restoration and Repair Help...
Jul 19, 2016 | 2003 Chevrolet Silverado 1500
I need to find replacement parts for a Magic Chef propane furnace model EG6E80. How can I cross reference them with other brands?
good luck, what parts do u need, most of them can be re placed with other furnace name brands, like ignitor, blower motor, gas valve, pressure switch, ignitor board, transformer, ventor motor, they have replacement for all those parts, remember most companies use the same parts
Dec 16, 2015 | Heating & Cooling
Why does blower on A/C sometimes work and sometimes don't on my Saturn 2007 aura
Blower motor control processor would be a good guess but I'm not in the guessing business , you need to test power an grounds for lose connections or corrosion , check for DTC'S in the HVAC control panel an if none , there are three different diagnostic flow charts from Saturn service info .
Blower Motor Always On Blower Motor Inoperative Blower Motor Malfunction
Myself I'd say Blower motor malfunction flow chart !
Did you perform the Diagnostic System Check - Vehicle?
Go to Step 2
Go to Diagnostic System Check - Vehicle
Place the blower motor switch in each speed position.
Does the blower motor operate at the desired speeds?
yes / no
Go to Testing for Intermittent Conditions and Poor Connections
Go to Step 3
  1. Disconnect the harness connector of the blower motor control processor.
  2. Measure the voltage between the battery positive voltage circuit and the ground circuit of the blower motor control processor.
Does the voltage measure within the specified range?
10-14 V yes / no
Go to Step 4
Go to Step 6
  1. Connect the blower motor control processor.
  2. Disconnect the harness connector of the HVAC control module.
  3. Measure the voltage on the blower motor speed control circuit.
4.5-5.5 V
Go to Step 7
Go to Step 5
5
Test the control circuit of the blower motor control processor for a high resistance. Refer to Circuit Testing and Wiring Repairs .
Did you find and correct the condition?
Go to Step 12
Go to Step 7
6
Test the battery positive voltage circuit of the blower motor control processor for a high resistance. Refer to Circuit Testing and Wiring Repairs .
Go to Step 12
Go to Step 9
7
Inspect for poor connections at the harness connector of the blower motor control processor. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs .
Go to Step 12
Go to Step 10
8
Inspect for poor connections at the harness connector of the HVAC control module. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs .
Go to Step 12
Go to Step 11
9
Repair a high resistance in the ground circuit of the blower motor control processor. Refer to Circuit Testing .
Did you complete the repair?
Go to Step 12
10
Replace the blower motor control processor. Refer to Blower Motor Control Processor Replacement .
Did you complete the replacement?
Go to Step 12
11
Replace the HVAC control module. Refer to Control Module References for replacement, setup, and programming.
Go to Step 12
12
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 2
Good luck , hope this helps !
Jul 11, 2015 | 2007 Saturn Aura XR Sedan
How do i replace the heater core 1997 isuzu hombre
See me at website for images can only send one through this channel. www.autorepairhelp.us
Best Regards,
Master Tech Lee
HEATER BOX SHIELD
Heater Box Heat Shield
Remove or Disconnect
1. Fasteners that retain heat shield to heater box assembly.
Image [ Heater Box Heat Shield
Install or Connect
1.Fasteners that retain heat shield to heater box assembly.
Tighten
-Bolts Screws to 2.2 N.m (25 lb in).
HEATER ASSEMBLY
Image ' Heater Hoses
Image ' A/C Evaporator Tube Assembly
Image ' Evaporator Core
Image ' Evaporator Core Assembly
Image ' Heater Assembly
1.Engine coolant. Refer to Draining and Filling Cooling System in Engine Cooling.
2.Heater hoses. Refer to Heater Hoses.
3.Instrument panel. Refer to Instrument Panel Replacement in Interior Trim.
4.Air inlet assembly. Refer to Air Inlet Assembly Replacement.
5.Vacuum lines.
Important
-Clearly label vacuum line connections.
6.Heater assembly studs inside engine bay.
7.Blower motor resistor. Refer to Blower Motor Resistor.
8.Stud inside heater core housing.
-Stud is revealed by removing the blower motor resistor.
9.Rear case screws.
10.Heater assembly.
11.Seals.
Imagt
Imagt
Imagt
Imagt
Imagt
Heater Hoses
Evaporator Core
Heater Assembly
Install or Connect
1.Seals.
2.Heater assembly.
3.Rear case screws.
4.Stud inside heater core housing.
Tighten
-Stud to 1.9 N.m (17 lb in).
5.Blower motor resistor. Refer to Blower Motor Resistor.
Tighten
-Studs to 1.9 N.m (17 lb in).
7.Vacuum lines.
8.Air inlet assembly. Refer to Air Inlet Assembly Replacement.
9.Instrument panel. Refer to Instrument Panel Replacement in Interior Trim.
10.Heater hoses. Refer to Heater Hoses.
11.Engine coolant. Refer to Draining and Filling Cooling System in Engine Cooling.
-Check the system for leaks.
Sep 06, 2014 | 1997 Isuzu Hombre
I have a emerson 1563 spa motor and need a new terminal board, anyone know where I can get one or have a cross reference number for it,
search your area for YOUR LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING .he might have one to give you .pictures are nice to have. jay
May 18, 2011 | Pool & Spa
I have a 1998 Pontiac Grand Prix. the heat and a/c won't work
needs a new blower motor which comes with a built in reostat ,expensive ,and its a job and a half to fit ,best advice ask a local mechanic to confirm ,grandad in alicante spain
Dec 12, 2009 | 1998 Pontiac Grand Prix
How do I replace blower motor for heat and air conditioning, the blower is under the dash board
Removal Procedure
  1. Remove the right side sound insulator. Refer to Instrument Panel Insulator Panel Replacement - Right Side in Instrument Panel, Gages and Console.
  3. Disconnect the electrical connector (1) from the blower motor.
  4. Disconnect the blower ventilation tube (2) from the module.
  6. Remove the blower motor screws (1).
  7. Remove the blower motor from the housing.
Installation Procedure
    Notice: Refer to Fastener Notice in the Preface section.
  1. Install the blower motor into the housing.
  3. Install the blower motor screws (1) .
  4. Tighten
    Tighten the screws to 1.7 N·m (15 lb in).
  5. Install the blower ventilation tube (2) to the module.
  6. Connect the blower motor electrical connector (1) .
  7. Install the right side sound insulator. Refer to Instrument Panel Insulator Panel Replacement - Right Side in Instrument Panel, Gages and Console.
Jul 30, 2009 | 2002 Buick LeSabre
Heating & Cooling Logo
98 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
