Question about Cameras
My binoculars are not working properly. I dropped them and now I get a double image
  • 112 Answers
Sounds like the optics have shifted and they have to be recollimated. its not the type of thing that you should try yourself as when they are open dust can get inside and remain on the optics, causing black specks in field of view when using...www.reichinstruments.com
Posted on Dec 10, 2008
One image is slightly above the other at all distances. After using the binoculars for even a couple of moments, my eyes are strained. The problem was present when the binoculars were purchased, however...
The oculars are not aligned properly causing double vision. Check on the binoculars to see if there is a place to adjust the alignment of either of the oculars. Look for any loose screws that may cause the two oculars to be out of alignment.
If this is not the case try adding some torque to the binoculars to see if the will adjust to where they will both point in the same direction. The eyes can fuse disparate images slightly but there is a very small range that they can handle. If the two images are separated by more than this small amount it will cause eye strain and double vision.
Feb 13, 2011 | Minolta 10x25 Activa D WP XL Pocket...
Accidentally dropped Bushnell Legacy WP 10 X 50 binoculars. Now they have a double image. Is this something that will need professional repair?
Yes, and unfortunately it will cost more than these binoculars are worth. What has happened is that one or more of the prisms inside the binoculars has shifted, putting them out of "collimation", or alignment.
You could have a go at this yourself, as a proper repair is not economic, but treat it as a learning experience.
Feb 06, 2011 | Bushnell Optics
I dropped my Nikon Action Lookout III binoculars, ...
The same happened to my Mizar 10X25 I tried things like moving the front lenses but then I discovered that most probably the binoculars fell on one of the four corners, this caused the tubes' direction to be twisted. It could be that the left is pointing slightly down or the right is pointing slightly up, which is essentially the same, and which is what happened to mine. You can discover this miss-alignment by watching using both eyes and then close and open one of them the phantom image will appear and disappear. What you have to do is apply a force with your hands twisting the binoculars one tube up and the other down and hold where you can see clear, I just discovered this and it works, I think I should be able to re-align them again, but I haven't faund how to do so. If you find a different solution please let me know here: gregsoli@yahoo.com
May 15, 2010 | Optics
Double image occured after the omega 40 X 70 binoculars were dropped
There are a series of lenses and prisms inside the binoculars. When the unit was dropped one of more of those elements have been dislodged and that is what is causing the double image. You can check with the retailer to see if there is a repair center in your area. The way these units are put together they are difficult to take apart, repair, and put back together. Depending on the cost of the unit you might be better off replacing them. Check with the retailer to see what they say.
Mar 17, 2010 | Omega ATN 7x50 Daytime Binoculars with...
I dropped them and they are seeing double now they are the xtra-wide bushnell ,how do i get them back in focus
Try grabbing the binoculars in both hands and twisting the body in the opposite direction of the double vision until the images coincide.
Sep 25, 2009 | Bushnell Xtra-Wide (4x30) Binocular
My Nikon binoculars show two images
must have been dropped ...have to be realigned if you want i can supply estimate 15088331232 ...larry
Aug 08, 2009 | Nikon Optics
See two images at higher power.
Your binoculars are out of collimation. That means that the optical path needs to be aligned. Binoculars are designed so that the focus point of each barrel is the same over long and as short as possible distances. Binoculars that are properly aligned will still show a double image if you attempt to focus at something close that is too close for the models design. However this is not the same for long distances. The image at a long distance must not be doubled.
If they are under warranty and you haven't damaged them by dropping etc send them for repair to the manufacturer or ask the retailer where to send them.
If you are going to pay to have them fixed get a quote first. Binoculars that are of the zoom variety are not well thought of among binocular officionados as the quality of image degrades at higher magnification. For the price of repair you may be able to source a higher quality non zoom binocular.
Jul 20, 2009 | Sharper Image Spion (AR001)
Image appears double and slighly off when viewing
I was having a double vision problem with my Barska 10-30X50 zoom, 195FT/100YDS binoculars. One image was always higher than the other. This was tolerable at low zoom, but was further aggravated the more I zoomed in. I found that I could grasp both barrels and twist them in opposite directions (one side up, the other side down) and force the two images to merge--but that was a strain and an unpleasant viewing experience. As an experiment, while looking through the binoculars, I grasped the far end of the right barrel and twisted it on its axis. Nothing happened at first, but after a certain amount of resistance it began to rotate independently of the body. Lo and behold, this shifted the barrel's axis, and the image for that eye moved vertically! I turned it until the two images merged, and now I'm thrilled to say that the problem is solved! I don't have a clue if this would work on any other brand or model, but it's worth a try!
Apr 06, 2009 | Tasco Sonoma 16-840WA-1 (8x40MM) Binocular
Binoculars may have been dropped ???
have been repairing these for years, they have to be recollimated..........good luck...reich instruments
Feb 23, 2009 | Optics
Double Vision
Your glasses have had a hard drop or jar- they are out of colluminatiom send them to Deusch Optics in Nevada
Jul 31, 2008 | Oberwerk (OBERWERK1030X60ZOOM) Binocular
Cameras Logo
67 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
