Question about Veo Stingray
Program wont interface with vista windows
How do i get it to interface with vista windows?
  • 5 Answers
Download the driver for veo at:
http://www.softsci.com/veodrivers.htm
when download is complete, click (open folder)
select the file (veo_330V_v002.exe) right click it
select properties
select compatabilty
put a check in box (run this program in compatabilty mode for)
choose (Windows xp (service pack2)
then apply
the double left click the file
and Bingo Vista will install it
I am using mine on yahoo messenger as I type now!
Have Fun
Hope this helped!
Posted on Oct 16, 2008
Tengo una PC con ordenador vista y no me hacepta el softwear para la veo stingray,que puedo hacer
Posted on Oct 11, 2008
6ya staff
SOURCE:
Windows take a long time to shut down
Uninstall unused programs. Get an up-to-date Antivirus program and scan your computer. Also get Malwarebytes to look for any Trojans. Windows Vista is notorious for taking a long time to boot or shutdown after a few years. Time to move to Windows 7 if you can, it has tighter code. Windows 8.1 is even better, but some hate the interface.
I’m happy to assist further over the phone at https://www.6ya.com/expert/kevin_c38b47f462e94458
Aug 16, 2014 | Microsoft Windows Vista Home Premium with...
I have sony handycam DCR-DVD755E , and im trying to downlaod the picture package program on my windows vista ,but it wont work.. where can i get a picture package that matchs windows vista? please help..
i have sony handycam DCR-DVD755E , and im trying to downlaod the picture package program on my windows vista ,but it wont work.. where can i get a picture package that matchs windows vista?
Sep 24, 2010 | Sony DCR-DVD803E Pal DVD Camcorder
This product doesn't work with the Windows Vista version. They're is a ddriver problem . No version of the drivers for vista turn on my pc!!
In windows you can find the program you want to run and then tell windows to emulate a previous version. If you are working within VISTA then you right click the actual program ICON (NOt a shortcut on desktop) and choose properties you wll see a tab called COMPATIBILITY. In the top you will RUN THIS PROGRAM IN COMPATIBILITY MODE FOR ######## here you can choose a previous version of Windows such as XP or earlier to use. Try having the program run in compatibility mode to determine if it can find the Sound Card. Its possible a driver update or other Windows update in VISTA is incompatible with the device.
Jun 13, 2010 | Behringer FCA202 - FireWire Audio...
I power on my hp pavilion laptop and its in korean how do i change it
You are going to have to flash the bios to the english version and/or reinstall windoze to reset the language.
pls rate 4 stars
Nov 29, 2009 | HP Pavilion dv6000z Notebook
THEME IS NOT SUPPORTED...
If you have not worked with themes in Vista, or if you you have yet this si the first time you have run up on this problem, there are different themes created by and for various 3rd party programs, not just ones created only for Vista. A great site to visit is: CrystalXP.net - Graphics & Windows Customization this site can teach you about many different types of customizations for Vista, and also has programs that can help you customize just about any aspect of your user interface. Hope this helps.
Jun 21, 2009 | Microsoft Windows Vista Ultimate Edition
Job Status Window Interface has stopped working.
The issue usually occurs if you are using windows xp drivers on a vista machine. It's strange that the error does not come up when printing from internet explorer 7.0.
There is a file on support.dell.com that you can run to remove any xp drivers and then run the vista installation file. that should take care of these error messages from the operating system.
you can copy and paste the following links to download and run the files :
Patch file to remove xp drivers:
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=224499
Driver for vista
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=203951
Feb 17, 2009 | Dell A960 All-In-One InkJet Printer
Application Error
better uninstall the program and reinstall it..
Minimum System Requirements
Software
The 32-bit version of Autodesk 3ds Max 2009 is supported on any of the following operating systems:
* Microsoft® Windows Vista® operating system
* Microsoft® Windows® XP Professional (SP2 or higher) operating system
The 64-bit version of 3ds Max 2009 is supported on any of the following operating systems:
* Microsoft Windows Vista
* Microsoft Windows XP Professional x64
3ds Max 2009 30-day trial version requires the following browser:
* Microsoft® Internet Explorer® 6 or higher internet browser
3ds Max 2009 30-day trial version requires the following supplemental software:
* DirectX® 9.0c application programming interface (required)
* Some features of 3ds Max 2009 software are only enabled when used with graphics hardware that supports Shader Model 3.0 (Pixel Shader and Vertex Shader 3.0). Check with your manufacturer to determine if your hardware supports Shader Model 3.0.
Hardware
At a minimum, 3ds Max 2009 32-bit requires a system with:
* Intel® Pentium® 4 or AMD Athlon™ XP or higher processor
* 512 MB RAM (1 GB recommended)
* 500 MB swap space (2 GB recommended)
* Hardware-accelerated OpenGL® application programming interface and Direct3D® application programming interface supported
* Microsoft Windows – compliant pointing device (optimized for Microsoft IntelliMouse)
* DVD-ROM drive
Note: Apple® computers based on Intel processors and running Microsoft operating systems are not currently supported.
At a minimum, 3ds Max 2009 64-bit requires a system with:
* Intel EM64T, AMD Athlon 64 or higher, AMD Opteron™ processor
* 1 GB RAM (4 GB recommended)
* Hardware-accelerated OpenGL and Direct3D supported
* Microsoft Windows – compliant pointing device (optimized IntelliMouse)
* DVD-ROM drive
Nov 03, 2008 | Computers & Internet
Windows vista
Windows Vista is the new operative system distributed from Microsoft, following the previous release of Windows XP.
An operative system is the interface between the user (you ) and the computer, that allows you to manage computer hardware resources and peripheral, and manage processes (software) running on your computer.
From the user point of view The operative syste is the environment where you run applications, manage connected devices, storing files and starting and stopping programs.
Vista is the latest OS released from Microsoft. It has a powerful interface, but it can be slow running on old computers. On vista you can also have some compatibility problem when you try to install old devices built for XP, such as printers, scanners etc.
See here
Windows Vista home page
Sep 11, 2008 | Microsoft Windows Vista Ultimate Edition
Genius and Vista
There are two common ways to software-connect scanners
to windows:
1) The TWAIN driver interface
2) The WIA (Windows image acquisition) driver interface
WIA is a driver interface native to Windows:
http://en.wikipedia.org/wiki/Windows_Image_Acquisition
TWAIN is a driver interface specific to each scanner
Most new scanners should support both driver interfaces !
TWAIN is preferable, if you can find it, because it is tightly
coupled to the scanner's hardware design, and therefore offers
more functionality, which is hardware specific.
WIA, on the other hand, is more generic.
It will work with many different scanners, but with reduced
functionality, especially in the tools and setting available within
the scanner control window that pops up every time you try to
scan a document from within an application.
If you cannot find TWAIN, you may have to settle for WIA.
(if it will run with your hardware)
This biggest problem, of course, is VISTA itself, and it comes
in two flavors, depending on your computer CPU:
64-bit and 32 bit.
64-Bit Vista drivers are the hardest to find.
32-Bit Vista is a DOG, because the software is too bloated
to run on a 32 bit machine.
Fancy colors and GUI not withstanding, 100% of the added
"new functionality" within Vista is for the benefit of Microsoft
and the scumbags running Hollywood. Vista hi-jacks your
expensive hardware resources and slows down "YOUR"
machine at "YOUR" expense to promote Microsoft's
insestuous relationship with the Sony movie studios and
the RIAA.
I strongly recommend to all my clients to stick with XP for
now, and avoid Vista like the plague.
I do !
Martin
Jul 12, 2008 | Genius ColorPage Vivid Pro II Film Flatbed...
Vista windows style
Windows Vista had a new interface dubbed Aero. Vista will automatically detect if your pc hardware is up to task for using the Aero interface and - if not - will disable it. Your friends are likely using the Aero interface, which has neat transparency effects and the aforementioned fancy window launching/minimizing animations.
Feb 17, 2008 | Microsoft Windows Vista Ultimate Edition
Veo Stingray Logo
181 people viewed this question
Top Veo Computers & Internet Experts
Thomas F. Schneider
meli novacole
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Veo Computer and Internet Expert? Answer questions, earn points and help others
