Question about HP OfficeJet 6110 All-In-One InkJet Printer
Won't print anything
I replaced the ink on my 6110 and now nothing prints. I thought that they were maybe bad cartridges so I got 2 more and they don't work either. When I run allign it fails with only printing two grey boxes at both sides of the top of paper and a crooked line between them.
    Master:
  • 623 Answers
Go to my computer
right click properties
hardware
device manager
?printer
scan for hardware changes
then try to print
Posted on Aug 20, 2008
SOURCE:
My printer won't print? it has full ink cartridges.How do i fix it?
Maybe your cartridges are not out of ink. Try it with another game cartridge kit...
Apr 30, 2012 | Canon PIXMA MP780 All-In-One InkJet...
Will not print
 ARE YOU USING BROTHER INK??? I MEAN BROTHER OEM INK.? WHAT YOU CAN TRY IS TAKE A PAPER CLIP AND INSERT IT ABOUT 1/4 OF INCH INTO THE AIR HOLE ON THE CARTRIDGE, SOUNDS LIKE WHEN THE SEAL WAS TAKEN OFF, THE ADHESIVE FROM THE SEAL STAYED ON THE CARTRIDGE BLOCKING THE HOLDE. GOOD LUCK SR BROTHER TECH
Dec 01, 2008 | Brother MFC 7300C InkJet Printer
Continually says align print cartridges
My guess is that the color cartridge is either defective or not inserted correctly. I have a 6110 and know that inserting a print cartridge is a little tricky. If it isn't completely inserted and the top latch fastened correctly, the cartridge either won't work or produce errors.
Try reseating the color cartridge so it's inserted in exactly the same way as the black cartridge and run a print job again.
Open the following web page and go to Step three to see the instructions for cleaning the electronic contacts on the cartridge and print carriage.
Ink Cartridge Alignment Fails
Those seem the most likely causes and solutions to me. Good luck.
Oct 29, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Hp officejet 6110 not printing with black ink
Hi lilacky-
Here are some HP support links that might be helpful... and a couple questions to consider.
Q: Is your new cartridge one of these listed below?
"The HP Officejet 6100 series and HP Digital Copier Printer 410 products use the print cartridges listed below:
* HP 56 black print cartridge
* HP 57 tri-color print cartridge
* HP 58 photo cartridge (replaces the HP 56 black print cartridge for six-ink photo printing)" info from: Installing a Print Cartridge
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00004340&lc=en&dlc=en&cc=us&lang=en&rule=12548&product=79477 Is your new cartridge a refilled cartridge? Some times those have special challenges. Has your cartridge been sitting a while in the box, maybe in a warm spot? Some times even new cartridges dry out a little. Was your old cartridge low or completely gone? Just as a test, if you put it back in your printer does the old cartridge work? Any printer error messages? Can you print a test page or an alignment page for your black cartridge? These might be too many questions but here are some HP support links with some How To information for getting more answers. Please let me know if any of these are helpful. see also: Slow or No Response from Printer
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?rule=11882&lc=en&dlc=en&cc=us&lang=en&product=79477 -JW
Oct 03, 2008 | HP OfficeJet 6110 All-In-One InkJet...
CANNOT ALIGN CARTRIDGES
Press and hold the Enter button, and then press Menue.
Also visit
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=bpu00657#Bypass_Alignment
Jun 12, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Nothing there
Did you try cleaning the print cartridge nozzles.
Press Function once and up arrow 2 times
Press the right arrow once and the up arrow once
Press Start/Memory button
It will print a test parttern page
Once you insert the new cartridge did the machine recognize the new cartridge? You had to press 1 for new
When 1 is selected you will get a prompt New Cart: OK?
OK press start.
If you selected NEW the display will show the alternating messages at right. Align Cartridge----1 Print 2 Set
Press 1 to print an alignment page
Hopefully, it will printed. Let me know one way or the other.
Mar 27, 2008 | Sharp INKJET FAX UX-A1000
Replaced empt 3E cartridge. Now it won't print
Kind of an X-file situation there. You should try an other cartridge, maybe that one is defective
Feb 03, 2008 | Canon PIXMA iP4000R InkJet Printer
HP 6110 All in one
Various models do different things so you will have to checkout some stuff. 1. black is green- what it mean is if you take some black ink and wet it to dilute it will sh0w dark green then lighter etc., because black is all colours mixed. In most printers when a 'black' document is printed actually all colours are printing - take a look under a magnifying glass. Some printers however allow for 'black' only printing. But you have to set it up. So check your manual and software or what comes up on the screen. Then come come back
Sep 06, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Printing
Phisically unplug the printer and wait a minute. Plug it back in with the new cartridge installed while the printer is off.
Aug 26, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
44 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
