Question about Panasonic UB-5315 Whiteboard Motherboard
Cannot capture info from whiteboard
When I plug in the UB-5315, I get a J on the screen (presumably where the number of copies shows). None of the buttons does anything, other than the scroll left button. There is paper and carbon in the printer. What do I ened to do (I do not have a user manual and cannot find one on line).
There was a paper jam. Everything is working fine now. Would still like to have a manual if anyone knows where I can get one on line. What Panasonic calls an 'operating manual' on their website is just a list of specs.
Posted on Aug 21, 2008
Panasonic interactive whiteboard won't project computer
If you'd like to email me at bruce.brassington@n-vest.co.uk I'll be able to help you in more detail. There's a fundamental error to the question here. That is the board in itself will not show the image - your boards is effectively a large flat mouse. A pointing device infact. The peice of equipment that "shows" your PC image is actually the projector. There could be several reasons why your projector isn't showing the image.
1 - is there either a VGA or HDMI cable connected from your laptop/PC to the projector (Sometimes via a wall plate).
2 If 1 is true and the projector is turned on does it show any sort of image? Now there are two thongs you can do from here. a) If you have a laptop check to see if your Video settings are set to clone across to a secondary monitor on most laptops you should hold down Function key and F8 this will toggle through three options Onboard screen remote screen and then both. there could be some lag between the two so hold down fucntio at the same time press F8 then wait a few seconds then go again.
Finally on you projector remote there may be an auto search buttion which will hunt for your PC image by checking each of the Projector inputs in turn. Generally speaking however you should select "Computer 1" or sometimes named as RGB 1
Hope that helps email me if your still having problems.
Aug 21, 2012 | Panasonic Panaboard Ub-T880 Interactive...
I have a smudge on my Panaboard and would like to clean it but don't know what I can use? Any suggestions?
All Panasonics can have a moist cloth or even a little metholated spirits on the screen. Occasionally a machine has a heavy bump which causes a greying effect between the two layers of the screen- you will NOT be able to remove the discolouring if that has happened. By the way- NEVER use whiteboard cleaning fluids on the screen- use water or a moist cloth for tough cleaning jobs-metho if desperate. Never use whiteboard cleaners on any whiteboard. Their job is to eat the surface so that you always need to use them.
Sep 19, 2011 | Panasonic Panaboard UB-5815
Printing Problem
Check sensor (behind panel on the left hand side of the whiteboard screen), to ensure there is nothing there blocking it eg: post-it notes, dust etc. Once cleared, turn the power off and on again and the flashing L should disappear, and you should be able to print again.
Jan 18, 2010 | Panasonic UB-5315 Whiteboard Motherboard
Ub5315 twAIN DRIVERS
you can download here: http://www.panasonic.com.au/support/downloads/more_info.cfm?objectID=162&&listQueryString=
Sep 10, 2009 | Panasonic Panaboard UB-5315
Flashing "L" on Panasonic UB-5315. Any ideas?
This indicates loss of home position reference and often can be rectifieD simply by giving the entire white board belt a thorough clean. Ensure that you clean it at both ends. You may need to move the belt by hand to do this, if so FIRST TURN OFF the POWER.
Jul 17, 2009 | Panasonic Panaboard UB-5315
Can not print "L" flaching
"L" is not one of the usual error codes for that whiteboard. you might have a sensor error behind the board. usually dirt and dust are blocking the sensors from reading the board.
Jun 23, 2009 | Panasonic UB-5315 Whiteboard Motherboard
Panaboard UB 5815 Wont Print
After looking at the troubleshooting section in the manual (what we should have done in the first place before posting this lol) we realized that we just needed to simply replace the Thermal Transfer Film.
Jul 24, 2008 | Panasonic Panaboard UB-5315
MY JVC GY-HD100 Wont capture properly in Final Cut Pro. Always shows time code breaks where there are none. Only capture a minute or two at a time. What can I Do?
Are you shooting 24p? Make sure you're using the correct capture presets. DV NTSC 48k 24Pa (presuming you're shooting 24p advanced)
if this doesn't help, close final cut and delete your com.apple.finalcutpro.plist file from library>preferences. This should solve additional cadence problems.
Apr 08, 2008 | JVC GY-HD100 Mini DV Digital Camcorder
Panasonic UB-5315 Whiteboard Motherboard Logo
108 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
