Question about Bosch 24 in. SHU43 Built-in Dishwasher
Bosch aquasensor I have just had a plumber install a second hand dishwasher as above, he left after he heard the water coming in, two mins after it stopped and nothing else happened bar the time still going, he has plumbed it into the cold water, is this correct or am I doing something wrong. Please help, thanks
  • 725 Answers
No it should be plumbed into the hot side... it will not wash untill the water is hot enough ...
Posted on Aug 21, 2008
Does anyone have installation instructions fo a Bosch free standing dishwasher smu50E65au? Thanks. Julie
Hi Julie.
A dishwasher needs access to water numerous times during it's cycle. You'll have to have the hose on the tap with water pressure on while the machine is in operation. You could exchange your tap for one with thread or install a second one behind the current one.
(Slightly agricultural repair)
When installing a dishwasher the drain hose outlet MUST be above the water level in the machine or the water will run out as soon as it is put in...They usually connect to the S bend under the sink.
It would probably be best to have a handyman/plumber attend to the job.
Good luck
Nomess
Jan 31, 2015 | Bosch Washing Machines
Hi, my aquasensor is not getting water?? What could it be?? Thanks
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Aug 28, 2010 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Bosch dishwasher: won't fill with water
The flood switch is tripped. This is located under the unit. Unplug or flip the breaker to the dishwasher, take off the black kick plate under the door, 2 screws, and you will see the white plastic "pan". The flood switch is located where you can't really see it but it is on the left hand side wall and is made of styrofoam. The best thing to do is to put some rags in the pan, this is not easy because there is little room to put them, and soak-up the water that has filled the pan. Eventually you will get enough water out that the float will deactivate the switch. What you hear "running" when you turn it on is actually the drain pump, it get activated when the flood switch is tripped.
Jul 21, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Just purchased a miele g1142sc dishwasher had a mate over who is a plumber and installed it. No water is coming into the dishwasher is there any safety seals on the water hose, put water into dishwasher...
Hi eaglesblue,
I'm Harvey the Master Plumber.
Your problem is: Just purchased a miele g1142sc dishwasher had a mate over who is a plumber and installed it. No water is coming into the dishwasher is there any safety seals on the water hose, put water into dishwasher pump is working fine.
Please take no offense but a plumber is not the same as an experieced appliance installer. Any way, your mate may have done just fine but the water line is clogged or he failed to flush the line before hooking it up and you may now have a clogged solanoid valve. Did you run the d/w a couple of times before he left? Did you confirm it working then and now it's not?
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 10, 2008 | Miele Dishwashers
Bosch Dishwasher
the circut board is very costly stay away from that one
Mar 28, 2008 | Dishwashers
Bosch aquasensor diswahing machine
To reset the board so as the times will go back to factory settings.
Turn appliance on press both buttons that have the two dots under, the display will then go back to zero. Shut the door and allow appliance to reset itself. This normally takes about a minute, whilst it's doing this the pump will be running.
Hope this helps
Deep Diver
Dec 31, 2007 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Bosch Aquasensor Detergent Dispenser door wont open during cycle
Behind the dispensor door there is a small selanoid you will need to replace this, test to see if its open circuit, alternatively you can just place the detergent in side the machine before you put it on a wash cycle is this would have the same effect. the only cycle you can not do this on is the one with the prewash, I think its number 1.
Nov 17, 2007 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
295 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
