Question about Canon MV700i Mini DV Digital Camcorder
Screen disply issue
The screen and the viewfinder are not showing any image whether in standby or recording yet the menu, startup screen & play back work fine, and ideas and has this been commented on before??
You need to contact your nearest Cannon Repair Centre. I had a similar problem and it was fixed for free as it is a known issue.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Canon Case Id: 37383
It has been found, that in rare case, some of the CCDs, used in Canon digital camera and digital video cameras, have a problem that causes abnormal image output.
Free repairs will be made for affected products in cases where it has been confirmed that the internal CCD wiring has come off.
Posted on Oct 13, 2008
My canon gl2 lcd screen and viewfinder black
Same thing happened to me. No display, no menu, no S-video output while in camera mode, but in VCR mode all was OK. Turning power off and on did not help until I also disconnected the AC power adapter. BTW, Mr. Riggins did not read the question before he answered.
Nov 25, 2012 | Canon GL2 Mini DV Digital Camcorder
Sony DCR-TRV250E.
was the problem the lense cap, or you do still need assistance?
Mar 28, 2008 | Sony Handycam DCR-TRV19 Mini DV Digital...
Christmas URGENCY: monitor/viewfinder: blue screen, lines of white dashes
remove the tape and just test that whether its recording or not and try to change the tape and then try
Dec 23, 2007 | Panasonic Palmcorder PV-GS70 Mini DV...
My handycam screen is blank and doesn't show anything
Follow this procedure to troubleshoot if there is no picture or a black screen appears in the viewfinder or LCD when attempting to record.
NOTES:
* Because each of these steps represents a possible solution to this issue, check the viewfinder or LCD status after completing each step.
* It may be necessary to refer to the operating instructions provided with the camcorder for information on how to perform a task on your specific model.
1. Ensure the lens cap on the front of the camcorder has been removed.
2. Ensure a fully-charged battery is inserted in the camcorder.
3. Ensure the STANDBY/LOCK switch is set to the STANDBY position.
4. Turn on the camcorder and set it to the CAMERA mode.
5. Look to see if an image can be seen in the viewfinder or LCD.
IMPORTANT: Some camcorders have both a viewfinder and LCD. To conserve power, the viewfinder and LCD will not display at the same time. To use the viewfinder, the LCD must be closed.
6. If the issue is not resolved, reset the camcorder to factory specifications.
NOTE: If the issue is still unresolved after completing the troubleshooting steps, service may be required .
Dec 23, 2010 | Sony Handycam DCR-HC40E Mini DV Digital...
When I turn on the camera, nothing happens and the screen/view finder is blank. i checked the standby switch its off. when i press record it will record but on the tape it is just a black screen? any ideas...
i know exactly whats wrong! the same thing happend to me.
1. turn off the gl1 2.look at the record button with the lock and standby switch 3.flip the switch all the way to standby because it might be stuck in the middle 4. turn on your camera
Dec 03, 2009 | Canon GL1 Mini DV Digital Camcorder
JVC Camcorder- Recording Problems
i have a jvc GR.D20EK and am having problems when recording, it plays back but i cannot record it will play recorded tapes can anyone help me. Thanx
Apr 07, 2009 | JVC Video Cameras
Recording problem
Knowledge Article C116445
There is no picture or a black screen appears in the viewfinder or LCD when attempting to record. Follow this procedure to troubleshoot if there is no picture or a black screen appears in the viewfinder or LCD when attempting to record. NOTES:
  • Because each of these steps represents a possible solution to this issue, check the viewfinder or LCD status after completing each step.
  • It may be necessary to refer to the operating instructions provided with the camcorder for information on how to perform a task on your specific model.
  6. IMPORTANT: Some camcorders have both a viewfinder and LCD. To conserve power, the viewfinder and LCD will not display at the same time. To use the viewfinder, the LCD must be closed.
  7. If the issue is not resolved, reset the camcorder to factory specifications.
Nov 30, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Won't record/No picture thru the LCD screen or viewfinder in Record or Standby Mode
it is a common problem with them. sony has a recall on ccd imager for this model. call sony and they will fix it for free
May 29, 2007 | Sony Handycam DCR-TRV22 Mini DV Digital...
Viewfinder screwing up play back
Is it only in the Viewfinder, or also on the LCD, or also transfers to the recording?
Jun 22, 2006 | Sony Handycam DCR-TRV740 Digital Camcorder
Sony F55 Recorded Display
The filename (e.g. DSC0012.jpg) shows the image number, the filespec shows the date and time recorded. Most software will give you document info about resolution of the image. I wouldn't worry about what the battery status was when the shot was taken or how many other images were on the Mstick. I guess I'm not sure what you need.
Sep 11, 2005 | Sony Cyber-Shot DSC-F55 Digital Camera
Canon MV700i Mini DV Digital Camcorder Logo
236 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
