Question about SanDisk Sansa e250 MP3 Player
Corrupt Music Folder
I had a problem with my e250 Sansa player which seems to trace directly to the default music folder during which files would not play. I tried to delete the files manually & I get a message stating that the player is either disconnected or has stopped responding. I have also tried deleting the folder manually as well as through Windows Explorer, Rhapsody & Windows Media Player none of which was successful. Finally I reformatted the player & reinstalled the firmware (1.022.24A). Initially the music folder was gone, but re-appeared with the same spurious files that I was seeing before I re-formatted. Any other ideas?
  • paulplatt Aug 21, 2008
    i am trying to put mp3's on my sansa player manually, not through a media player (rhapsody etc...) and i get the same error. even though the copy progress bar comes up. whats up with that? PLEASE help me, i am at my wits end.... my email is paulplatt@centurytel.net thank you so much for your time....
  • Pepster453 Aug 21, 2008
    The problem is still not fixed per say. I came up with a work around by re-naming the original music folder (I called it Broken Music Folder) & then creating another Music folder. The Player won't even let me drag & drop to the original music folder. I re-formated one more time, but re-formating still didn't eliminate the broken folder.
    Sergeant:
  • 359 Answers
When i plug my sansa e250 the music file is not there
just go to the top and type music
eg: ur port:\music
Sep 13, 2009 | SanDisk Sansa e250 MP3 Player
It doesn´t recognized the music files
is the music files in the music folder? (its a hidden folder stupidly enough so is hidden files turned on in your operating system?)
are they mp3 or wav files? If the answers are no - now you know why.
Jan 28, 2009 | SanDisk Sansa e250 MP3 Player
Cant find music folder
Change USB mode to auto -IF it is avaialble in the settings menu - see manual for details.
Sep 06, 2008 | SanDisk Sansa e250 MP3 Player
Icant find music on player
The reason you can't see it, is that, for some unknown reason, the music folder is hidden by default. When viewing the Sansa in Windows Explorer you need to enable "view all folders". Click on the TOOLS menu at the top of the window, then folder options, click on the VIEW tab, and choose "Show hidden files and folders". Click APPLY and OK to come out.
You should now see the music folder and be able to drag and drop files to it. Don't forget to go back into Folder Options and hide the hidden folders again when you're finished, as leaving it in this setting can leave critical system files exposed, that could be accidentally deleted.
All this was for Windows XP, but other versions are similar, it was on the VIEW menu in Win 98 if I remember correctly. Hope that helps.
May 28, 2008 | SanDisk Sansa e250 MP3 Player
How to remove songs....i dont get it still
hello!
here's how you will delete songs off your Sansa e250
step 1: Go to"MY COMPUTER
Step 2: Find and open the sansa drive
Step 3: Look for the music folder.
NOTE:
If you dont see a music folder you will need to go to the top where it says tools>then >folder options>then click on show hidden files>
Step 4: You should now see the music file. Go into it and simply delete any songs you don't want.
May 08, 2008 | SanDisk Sansa e250 MP3 Player
Missing MUSIC folder...
  1. hhuhihhygdydcxdsdfgyffxdfgtbgnhucdhyfgufrvcftygfcrvf
May 04, 2008 | SanDisk Sansa e250 MP3 Player
Deleting music off of my sansa E250r!!HLP ME
If you originally used rhapsody (or began in Rhapsody mode) , you have to use rhapsody to remove the songs. If that doesn't work, you can manually open the music folder by enabling "hidden folders" under "tools" -> "folder options..." -> click the "view" tab -> scroll and check "show hidden files and folders". Then go to My Computer -> Sansa e250 -> "system" -> "music" -> then delete the songs. I don't know the effects of using this method, so use it at your own risk.
Btw, Real Player should do fine as well.
Dec 22, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250
You need to enable Hidden Files and Folders on your PC to see the MUSIC folder as it is hidden.
Best of Luck.
Nov 17, 2007 | SanDisk Sansa e250 MP3 Player
Empty folder
There may be possible reasons why your Sansa E250 would display an message on the LCD even when you've downloaded files to it: (1) The music file type is not supported by the player. Sansa players support only MP3 and WMA files. To determine what file type your have, right click on the file type and it should display the "properties" dialog box. Check if it is MP3 or WMA. For example, iTunes music files will not work with the player, nor will WAV or MIDI files. (2) Your music files are supported but the bit rate is not within the range that the player supports. Sansa players support MP3 files up to 128 KBPS and WMA files up to 64 KBPS. You may need to use a 3rd party music file editor to convert the files to a supported bit rate (3) You may have saved your music files in a folder and copied the folder to the player. Your Sansa E250 will not recognize folders. Either save them in the root directory or inside the "Music" folder -- your player's default folder for music files. Hope this info helps :)
Apr 12, 2007 | SanDisk Sansa e250 MP3 Player
Deleting songs
Chances are that you are using windows xp. open up your sansa folder to where it says pictuer, movies, ect. look at the picture to see what to do. In your player folder click tools --> folder options --> View. Under hidden files and folders click 'show hidden files and folders, click ok. The music folder would now show up where the videos and pictures are. Simply open the music folder and delete the ones you do not want. By default the songs are sorted by artist --> album --> song.
Mar 16, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
50 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
