Question about Dell Dimension 3000 PC Desktop
Memory card compatibility with 4300
I'm buying more memory from Dell in the form of 2: 512MB cards. This leaves me with the cards I'm removing which are 2: 256MB cards. Can I give these to friends/family who own Dells that may not be exactly the 4300 series? -
In other words... - are there such things as card compatible cousins to the 430 series?
    Novelist:
  • 210 Answers
Are you talking about the memory sticks inside the computer?
If so, then yes. If you have DDR memory, it will work in most computers that use DDR memory. It's best not to mix memory, so you'd want your friends to completely remove their old stuff first.
When you compare your RAM to theirs, match up the length and where the notches are along the gold contacts of the memory sticks. If they match perfectly, then you're good to go!
From oldest to newest, we have these kinds of memory
EDO
SDRAM
RDRAM
DDR
DDR2
DDR3
Brand new PC's are using 2 and 3 (2 being the most common) Most PC's are just plain DDR because that used to be the most common. Other than this, there are other differences in memory, but they moreoften don't make a difference. =-]
Posted on Aug 21, 2008
I bought new 4 gb card for my coolpix 4300 and it doesnt work
Remove memory card, go in the menu and check the internal memory is wiped clean, if not! erase all pictures and restart the camera, when that is done the memory card should function once you re-install it.
Mar 17, 2012 | Nikon Coolpix 4300 Digital Camera
I have a Dell dimension 4300 running Windows XP SP3. The system has 1 Gb of RAM. I removed the AGP graphics card that came with the system and installed the VisionTek Radeon 256M X1300DMSPCI card into a...
Yes, it is compatible, just that you must first uninstall the previous video driver, then configure the BIOS to route the video signal to the PCI and not the AGP and only then install the new card. And in the end it will behave worse than the previous AGP card you got because the PCI interface is way slower than the AGP.
Just buy a good AGP card, PCI cards are made for office pc's in which the onboard one is totally obsolete.
Feb 08, 2011 | VisionTek RADEON X1300 , Graphic Card
I need to buy and install and ethernet card for my
Ok - try this site for a great card
www.tigerdirect.com
Apr 16, 2010 | Dell Dimension 4300 PC Desktop
Is acer lcd 223w compatable with dell dimension 4300?
yes. you will need to know what connection you have on your dell video card. the standard is svga. the other is dvi. you may need a convertor or adaptor.
Dec 27, 2009 | Acer 22" X223w LCD Monitor
MP3 downloads to cell phone not working
If the memory card is not detected on phone then there will certainly be problem with the memory card and not offcourse with phone.
If you wish to go for format and clean all data of Memory card and then try to use, may be an option left for you.
Also check out the format of music file you are trying to copy is in compatible form (ie mp3, wmv or mpeg)
Otherwise go to nearby mobile repair shop and get the task done.
Best Wishes Scott
Jan 04, 2009 | Cell Phones
Is it possible to give your old memory to a different series Dell computer
The easiest way to find out is use the memory confugurator at crucial.com, just run through the configurator for both machines and see if the memory cards match.
www.crucial.com
Aug 20, 2008 | Dell Dimension 4300S (Refurbished)...
N73 problem
Use only miniSD cards approved by Nokia for use with this device. Nokia utilizes the approved industry standards for memory cards but not all other brands may function correctly or be fully compatible with this device.
Use only compatible miniSD cards with this device. Other memory cards, such as Reduced Size MultiMediaCards, do not fit in the memory card slot and are not compatible with this device. Using an incompatible memory card may damage the memory card as well as the device, and data stored on the incompatible card may be corrupted.
Press menu and select Tools > Memory. You can use a compatible miniSD card as extra storage space and for backing up the information in the device memory.
To back up information from the device memory to a compatible memory card, select Options > Backup phone mem.
To restore information from the compatible memory card to the device memory, select Options > Restore from card.
To eject the memory card, press , and select Remove mem. card.
Important: Do not remove the memory card in the middle of an operation when the card is being accessed.
Removing the card in the middle of an operation may damage the memory card as well as the device, and data stored on the card may be corrupted.
"I used to be apathetic, but somehow I just lost interest..."
Apr 04, 2008 | Nokia N73 Cellular Phone
Card cannot be used
This means that the card memory can not be read, make sure the contacts are, clean. use pressurized air cans available from most places like, Wal-Mart, Best Buy, Staples, etc.
lightly blow out the memory card and the camera slot, check pin alignment, Format the memory card on your computer first and re-insert in camera. Use another card to see if error continues.
Mar 14, 2008 | Nikon Coolpix 4300 Digital Camera
Dell Dimension 4100 Mobo upgrade to a P4 based system
Well the two would not be compatible cause one is a P3 and the next is a P4 two completely different socket types so it wouldn't work but what u can do is buy a new motherboard if u want to upgrade to a P4...thats the only thing that is recommended from such a devices cause an upgrade wouldn't be possible to do .
Nov 22, 2007 | Dell (2336V) Motherboard
Dell Dimension 3000 PC Desktop Logo
52 people viewed this question
Alun Cox
