Question about Linksys Wireless-G Broadband Router
Computer setting for network do not match the req's of the network
I cannot get on the internet because of the above - Subject
  • 60 Answers
I belive you are running windows vista. All you need to do is go to network and sharing center, go to manage wireless networks and remove the name of your network there. Then click add and enter your network key and you will be all set.
Posted on Aug 24, 2008
What does error 1106 indicate?
First please find your PC network settings: Step 1/ : How to check your PC network settings: Using the PC that is already networked to the same network router, please carry out the following procedure. On the PC desktop click Start then click Run now type in cmd and click OK (with Vista/ Windows 7, type Run in the search field located at the bottom left of the desktop and then open Run and type cmd) At the command prompt type ipconfig then press enter/return on the keyboard. The computer will now display setting figures which will look like but not the same as the following examples below. IP Address: 192.168.01 Subnet Mask: 255.255.255.0 Internet Gateway: 192.168.11 Now that the PC network setting figures have been located, the Sony networked product must also be checked to see if the setting figures are the same as those found on your PC. Step 2/ : How to check the Sony product network settings: Using the Remote control press Home/Menu Go to Settings Go to Network press OK Go to Network Set-up press OK Go to View Network Status press OK All the figures shown on the Sony product should match with those on your PC apart from the last 3x figures of the IP Address. The last 3x figures of the IP address sequentially differ due to each networked product having a slightly different IP address, this is normal. Depending on the outcome please see either A/ or B/ below. A/ DO MATCH : PC and Sony product setting figures DO MATCH If the PC and Sony networked product setting figures match but there are still networking issues please do not go to STEP 3 but contact Sony support. Details are listed below and titled Sony Support. B/ DO NOT MATCH : PC and Sony product setting figures DO NOT MATCH If any of the setting figures differ (apart from the IP address as explained above) then that would indicate that there was a problem during the network set up. To resolve this, both the Sony product and router will need to be Reset and the Network set up process started again. Please continue to STEP 3. Step 3/ : How to reset the Sony product and router: Reset the Sony product Using the Remote control press Home/Menu Go to Settings Go to System Settings and press OK Go to General Set-up and press OK Go to Factory Settings and press OK Restore Factory Settings and press YES Once this has been completed turn the TV off at the mains and then switch back on again. Reset the router Usually, press any reset button on the router, or switch off and on at the mains and wait for the lights on the router to settle and become constant. If it is un-clear on how to reset the router, please contact your Internet provider or router manufacturer. Once both products have been reset try the network set up again. Sony Support If there are still networking problems after checking through the procedure above, please contact Sony support with all of the information required as listed below, please call 0844 8466 555 Mon-Fri (9am to 5pm) Sony support will require the following information to help identify any problems that you may have with your network connection. · A full description of the networking problem · IP Address, Subnet Mask, Default Gateway (completed using Auto configure only) · Router make and model · Type of security used WEP or WPA · Wired (cable or Home Plug) or Wireless connection. · What actions have been carried out to help resolve the issue already
Read more: How do u fix error 1106 connecting broadband to sony bravia kdl 32ex520 (no router)? - I have a broadband that i use for my laptop. when i connect to my sony bravia i shows error 1106 and i dont use router to set up anything with router. I connected as a wired connection and cable and ip address is ok but internet connect failed and shows error 1106. Can you please help me out on this :: Ask Me Fast at http://www.askmefast.com/How_do_u_fix_error_1106_connecting_broadband_to_sony_bravia_kdl_32ex520_no_router-qna1013157.html
Oct 31, 2015 | Office Equipment & Supplies
Can't connect with the internet. Message is "settings saved do not match the requirements of the network."
okay what you do is go to start documents and copy this to the address bar "Control Panel\Network and Internet\Network and Sharing Center" after you do that click on manage wireless networks on the side now click on your internet profile and hit delete after its deleted search and find you internet and set it up again
Apr 05, 2011 | IBM Lenovo ThinkPad T400 7417 Notebook
Our laptop won't connect to our network set up on our desktop home computer. The desktop is running Windows XP Home Edition V2002, and the laptop is running Windows Vista Home Premium V2006. When we try to...
In your laptop Open Control Panel > Network internet > Network and Sharing Center > Set up new connection or network > match with setting in your PC > Finish. Try to reconnect.
Feb 02, 2011 | Acer Computers & Internet
The settings saved on this computer for the network do not match,
You need to remove the wireless network from your preferred networks list and reconnect to it.
1. Right click on the wireless icon (picture of a computer) on your system tray.
2. Click on Network and Sharing Center.
3. On the upper left hand side of the page , click on Manage Wireless Networks
4. Right click on you network name and click Remove/delete
5. Now reconnect to your network.
Jun 09, 2010 | Belkin Wireless-N Wireless Router with...
My question is ''thes settings saved on this computer for the network do not match the requirements of the network'' how to connect the wireless internet on my computer now? PLEASE see
See there are some old settings saved on your computer for the same wireless network name.
I believe the operating system on your computer is windows VISTA / 7 .
Now you will need to remove the network from the preferred network list. then add the new network on your computer and you will be able to connect to the network. Make sure that you have all the wireless settings of your network. If you are not sure about the wireless settings of your network then you will need to check the wireless settings of the network.
Apr 08, 2010 | WiFlyer - Portable, shareable WiFi base...
No internet connection Message Wireless
You need to connect your computer directly to your router through an ethernet cable. Then, you need to log into your router's configuration settings page (the webpage used to initially set up the router). Once you log onto it, go under the wireless security section, and there you should find the network key (might be know as passkey).
Mar 05, 2010 | Belkin (F5D7230-4) Router (587009)
Wireless network settings do not match the settings on the router or access point. how do I fix this ? unable to connect to the internet
In your laptop computer do the following steps,
1.Click on Start--->Control--->Network and internet--->Network and sharing center
2.in the right hand side,click on Manage wireless network
3.you will be able to see the network name,remove all the network and then try to scan for wireless network and then connect to it.
you will be able to go online
Regards,
Ayyasam
Dec 29, 2009 | Belkin Computers & Internet
Can not connect to the internet via router
use the network set up wizard, new connection.
Oct 01, 2009 | Computers & Internet
Internet connection, lost wireless connection. Tested all hardware, all working. Wireless network shows "disconnected" or "unplugged". Cannot "ping 192.168.1.1. Have Broadcom 440 10/100 integrated...
Try and connect the router directly to a pc with a cat 5 cable, then try and load the settings page. Make sure that you do not have you SSID hidden, this is the name of your device that is broadcast. if it is hidden you have to have everything set up on the computer exactly the same (case sensative) or it is difficult to connect, you can hide it again after you establish a good connection. You may try pressing the reset button on the back. I hope this helps, good luck.
Sep 22, 2009 | Linksys Wireless-G Broadband Router
Wireless network
go to control panel and click on network connection and find the wireless connection and right click it select properties and make sure that the settings match you network example--ad-hoc or access point and make sure it is set to the right channel
Jul 02, 2008 | Computers & Internet
Linksys Wireless-G Broadband Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
