Question about Honeywell HT-800 Table Fan
Hello,help please our honeywell electric fan is broken,we really really need it,because my kids cannot sleep without the sound of it.were using it for about 2 years now.for the last two weeks theres something wrong about it already.it takes a few minutes before it works.last night its not working anymore,i wonder why my 2 daughters is crying,and then i found out that the fan is not workin anymore.please help us out.im a mother who needs your help.what should i do?help please.
My fan is doing teh same thing. I have been taking the cover off and spinning the fan blade manually. It takes about 1 minute of constant manual vigorus spinning but as soon as its warmed up the fan blade spins easy and just takes off and starts working. Im sure its not the safest thing to do but it does get the fan running for the rest of the night. Once the fan has been turned off for a while the blade is hard to spin again and I have to start over with teh manual process. I am thinking its the motor being I can manually get it started by spinning the fan blade and think I will check on the cost for a new motor
Posted on Jan 04, 2009
You just open it up and then take off the two screws that hold it to the base then take off the piece that's held on with bolts, take out the rod and oil the two bearings on the top and bottom of the motor.
Posted on Jul 02, 2009
Can you use sleep medication for babies? My 6 month old has terrible sleeping patterns and we are exhausted. A family friend suggested we use a sedative. Is that ok?
You should never give babies any drugs unsupervised. It can be really dangerous. I know it's really hard to be sleep deprived when you have young kids but medicating them isn't the answer. You can get advice and support for the sleep issues and definitely speak to your doctor about it, but don't ever give medication without medical supervision.
Feb 20, 2013 | Health & Beauty
Just bought it. quiet for 2 hrs then an inconsistent scratching, buzzing scraping kind of sound that we CAN't sleep through. compressor is working fine and so is fan. HELP??!!
Might have something loose or broken and is hitting the fan inside. If it is a slushing sound, that is the water being slung back up unto the fan blade and condensor coil to cool the inside of the unit.
Jul 17, 2012 | Frigidaire Compact Air Conditioner
RTH230B display just went blank won't come on even with new batteries. The fan comes on when put to the ON position. what to do.Please help if you can, 2 cold kids and a sick mom.. :)
Sounds like a fuse. You will need to look inside the heating unit on the circuit board for a glass fuse or an automotive style plastic fuse. Shut power off to heater prior to looking at the circuit board.
Mar 01, 2010 | Honeywell Programmable Thermostat Heater
Fan blows too strong (and loud) when heat comes on
Make sure your fan switch set to "auto". If there is a switch or jumper in the t-stat labeled "G" and "E" or "GAS" and "ELEC", it should be on "E".
Please rate my answer!
Mar 14, 2009 | Honeywell Programmable Thermostat Heater
Fan runs indefinitely after heat shuts off
yes I have replaced a couple of t-stats lately (honeywell)
Jan 05, 2009 | Honeywell Programmable Thermostat Heater
Noisy Fan on Copier CS-3035
actually fan really works even at sleep mode to exhaust heat, the problem is one of the three fan located at the left side if your facing the machine, is deffective a broken blade causes it to sound bad try to remove its connector, afer all you have two more working
Nov 01, 2008 | Copystar - CS-3035 Printer
Honeywell manual fan switch broken
The fan limit switch is basically like a thermostat. When the plenum heats up to a certain degree it turns on the fan to start heating your house, and turns off when the fan off when the plenum gets around 80-90 degrees so that you’re not pumping cold air in to house. It also acts as a safety switch if the fan does not come on the plenum will get way to hot so this fan limit will kick the furnace off before that happens. As far as that little white button it should always be on auto you can try to use needle nose pliers to get it back into the auto position, or if you have the broken piece you can try to glue it back on. The white button goes in and out it does not turn or anything just make sure you turn the power off first and if u can’t fix it replace.
Oct 13, 2008 | Honeywell L4064B2236 Fan/Limit Control...
Hi i am working as an electrical installer and would like to know where i can access all the electrical drawings for all the different heating systems Honeywell
http://www51.honeywell.com/aero/Products-Services/Avionics-Electronics/Egpws-Home3/InstallationInformation3/digs-draw-sw.html?c=21
try this.. all honewell drawings.. in it
Nov 13, 2007 | Honeywell HFS641P Stand (Pedestal) Fan
Honeywell HT-800 Table Fan Logo
914 people viewed this question
Top Honeywell Dryers Experts
Jay Finke
Jay Finke
ray gallant
Are you a Honeywell Dryer Expert? Answer questions, earn points and help others
