Question about Canon PIXMA MP160 All-In-One InkJet Printer
E22 error code
I just wanna know how to fix it, I had a E5 in the beginning but finally solved it, now E22 error code displays. We do appreciate your help. Thank You all you guys!
  • JoeCubafan Aug 24, 2008
    Thank You Geemarie! Look, I did all these test and they were pretty helpful to find solutions, Thanks from heart! I wish I could help you one day too! Bye
  • 876 Answers
E 22 is a carriage error, which means there is still something wrong in the cartridge area.
Please do as follows:
Turn off the printer and unplug it.
Remove the cartridges. Check them for leaking or damage.
Look carefully inside the cartridge slots. Look for dried ink or blobs of ink (they can be cleaned away with a tiny bit of alcohol on a qtip. Look for bent or broken cartridge wire holders? Does everything look okay?
Leave the cartridges out. Plug the printer back in and turn it on.
Does the carriage move?
Reinstall the cartridges and make sure they are properly seated.
Close the lid. Turn off the printer
Restart your computer.
Turn the printer back on.
Tell me what is happening now. unless everything is okay!
Posted on Aug 24, 2008
  • Gayle Ashbach
    Gayle Ashbach Aug 24, 2008
    You are very welcome and Thank you for the great rating. Have a nice day!
Thanks Geemarie,
I just noticed that the tape covering the ink nozzels was still on.
Stupid service guys.
Posted on Nov 01, 2008
I did wat u said but iit didn't work!!D=
Posted on Sep 28, 2008
What does error code e22 mean
e22--will not finalize DVD-R disk (due to dirty lens, I think)
*unplug unit and replug after 20 minutes
*restore settings if needed, and reset clock
*insert & run/play a DVD lens cleaner disk
*dub video from the HD to a NEW BLANK DVD
*finalize after dubbing is finished
THIS WORKED ON MY MAGNAVOX MDR 533H/F7
PS: make sure that the new blank DVD disk is from the same pile of disks that you were able to finalize before.
Feb 08, 2016 | Magnavox ZV427MG9 DVD Recorder/ VCR
E22 errors
Good morning Diane Snow, thank you for your inquiry!
I see that your Frigidaire washer is displaying "E22" error code. Typically an "E22" error code means water is not pumping out fast enough. I would suggest checking the hoses for any restrictions.
If the hoses are not restricted it could be an issue with the drain pump or control board. I would recommend having a professional come out and properly diagnosis your washer. I hope this information has been helpful. -Matt
Oct 06, 2014 | Frigidaire Washing Machines
Error code e5
Hi friend, I appreciate your post!
I understand that your Electrolux refrigerator is showing an "E5" error code and not cooling. "E5" typically stands for Showroom mode, you can press and hold the "Up" and "Down" keys simultaneously and that should restart your refrigerator back to normal operation. Could you reply back if that corrected the issue? Thank you. -Matt
Jul 27, 2014 | Electrolux Refrigerators
E5 error code on a YorkFitness Inspiration treadmill, anyone know what i should do?
key permanently stuck, remove the keypad connector cable. Restart the power up sequence, if the error disapear the keypad is the cause.
otherwise the PCA is the cause. the chip PCA must be changed.
God bless you
Jun 17, 2012 | Exercise & Fitness
E5 error code on sportcraft tx400 treadmill
E5 erorr code for my gait keeper treadmill ,it starts up after few seconds ,it stops
and error code appear.Can you tell me what this means? How to solve this problems?
Nov 24, 2011 | Exercise & Fitness
My canon mp198 displays an E5 error, how can I fix
E5 is the cartridge error code. Either using the wrong cartridges, faulty cartridges, refilled cartridges or non-genuine cartridges
May 20, 2010 | Epson Printer
I have problem error code e23 for my canon printer pixma mp150 what can i do for solve this problem pls help me tq
Hi raj2006678,
The code e23 indicates a paper feed error. Check to be sure that your paper is loaded correctly and that the rollers are functioning properly.
Here is the complete list of error codes for the MP150:
E2 No paper (ASF)
E3 Paper jam
E4 No ink
E5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed
E16 Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
I hope this helps - please let me know if I can be of any further assistance.
Kind regards,
H2H
Dec 16, 2008 | Canon PIXMA MP150 All-In-One InkJet...
E5 and 2,114,0 errors on Canon MP160
Empty cartridges may cause this error. Here is the error code list for your printer
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 13, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
5,205 people viewed this question
old marine
old marine
