Question about Canon PowerShot S410 / IXUS 430 Digital Camera
Canon powershot s410 problem
On vacation I turned on my camera to take a picture and the lens opened normally, but then all of the sudden it closed made a strange beeping sound. Now it will not open and just makes the beeping sound when I try to turn it on. It also says E18 on the viewfinder. Can you help me?
    President:
  • 1,566 Answers
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
Posted on Apr 06, 2010
Canon Powershot A495 Wont power on using the ON/OFF button
The problem is short on playback button due to humidity (see differences between the buttons on foto no.1), wich can be removed mechanically using a pin and making two holes(inlet/outlet) at the side of the button where no wiring running(!) and with a hypo carefully shooting air beetween the foils. It is useful to lift up little bit the spring button from the bottom foil to remove the short. A hair dryer can be also helpful to dry out the space between the foils. Please check the fotos and link too.
The camera will not power on by battery insertion when short is over. To protect buttons against repeted defects I used an adhesive tape to close the openings on the top of the buttons.
Canon Powershot A495 Wont power on using the ON OFF button page 2 General...9475eddd-e98e-40e1-9ff5-48f2b88aa22a.jpgimg_3172a-qpgfxpscyuxnmpq5faoemdbh-2-2.jpgimg_3180a-qpgfxpscyuxnmpq5faoemdbh-2-3.jpg
Nov 08, 2011 | Canon PowerShot A495 Digital Camera
PowerShot S410 problem. Camera powers on and lens extends and closes as normal. Screen shows Memory Card Unavailable if I don't have the memory card in the camera, if memory card is inserted in the camera...
Take a look inside your camera's CF card slot. I suspect that you may have a bent pin in there. If so, don't fret. Although professional repair would be more costly than the value of the camera, there is a very good chance that you can repair this yourself. Please see this link.
Jun 02, 2010 | Canon PowerShot S410 / IXUS 430 Digital...
Flickering image on LCD lens of my Canon S410
By the sounds of it you have a bad chip on your camera system board. If the image records okay and displays okay after the image is recorded. Other than having your camera repaired you may have to use your camera as is.
Jul 03, 2009 | Canon PowerShot S410 / IXUS 430 Digital...
Can't take pictures
If the lens is buzzing and followed by an "E18" or "lens error" message then the lens will need to be replaced. If no message appears you may just have flat batteries or even a single bad battery can cause this. Try getting some good quality disposable batteries specifically for digital cameras. If all is well with the new ones, invest in a new set of rechargeables.
Mar 24, 2009 | Canon PowerShot A95 Digital Camera
Digital Camera: Canon PowerShot S410. Display screen is blank, although can see through eye hole. Pictures come out blank as well! Lens zoom-in/out works fine.
Its CCD imager problem in your Canon S410 camera. Canon will repair it Free Of Cost. See Canon Advisory details for this scheme.
Sep 10, 2008 | Cameras
Canon Powershot S410: cannot turn it on
personally, I would ring Canon and ask for some idea of what might be the problem, and go from there. I assume it is out of guarantee, otherwise I would certainly have it back to them under guarantee. However, it can cost more than a new one to get repaired in some cases if out of guarantee. It could be as simple as needing some contacts cleaning of grease in the battery housing - try cleaning this first is one of the most obvious.
Aug 31, 2008 | Canon PowerShot S410 / IXUS 430 Digital...
My canon A520 lens cover don't open
lens opens about 25% . Will not close back.
Mar 15, 2008 | Canon PowerShot A520 Digital Camera
Canon powershot S230 Camera will not take picture now
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
Oct 28, 2007 | Canon PowerShot S230 / IXUS 179 Digital...
Lines appear
normally that problem occurs when the obturator is allways opened, to be fixed needs to exchange the lens
Jan 22, 2007 | Canon PowerShot S410 / IXUS 430 Digital...
Canon PowerShot S410 / IXUS 430 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
