Question about RCA DRC8030N
RCA DRC8030N I have this unit. the unit seems to work. Just not with remote. I bought new remote. still does not work what could be the problem
  • 2 more comments
  • tlaka4us Aug 23, 2008
    my rca drc8030n worked fine until about a month after the worrenty was up
    and also the remote stop working with the unit
    had the remote check out and it was ok
    the unit work ok but with out the remote you cant uses the library and the program it .
    realy would like to get it working again
    once in a blue moon the remote will work but not for long
    ive even tryed unversale remote
    and the same resalts
    once in a blue moon you mite be able to work the manu
    im just not ready to give up on it yet
    would like to here any ideas on anything that mite get it working other than hitting it with a hammer
    thanks again
    when i email support at the time
    they said it could possable be the remote sencer in the unit
    but they also said sence the dismantaling of rca you cant get the part no longer
  • dhmd Dec 04, 2008
    My hard drive stopped working and will not reformat or reboot. The disc tray will also not open. I bought a replacement hard drive and tried swapping it out with the existing, however, only the "hello" text appears along with the RCA background on the tv. I do not get a menu screen and the unit still does not work. Any suggestions? Thanks.
  • kmscarb Dec 31, 2008
    Remote will only work every blue moon.
    However buttons on dvr always work but of course that doesnt allow full use of dvr.
    Pressed open and play button. Unit would show format for about 5 secs then shut completely down.
    Unit not working any better.
  • bgblunt Feb 26, 2009
    I lost my original remote control. I have purchased a new RCA Universal Remote (RCR461). I need codes to setup with the DVR
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 106 Answers
Hi. I recenlty fixed a unit with the same problem and I had to replace the motherboard. I could not get the remote to do a darn thing and the front pannel buttons would not do a thing either. Before going to the extreme, and if you still have functionality via the front pannel buttons, try to reset/format the unit. Keep in mind that this will erase everything on the hard drive. While in the main menu and with no DVD disk inside, press and hold the play and open buttons for about 7 seconds until you get the FORMAT message on the LCD. If this does nothing to leviate your problem, then replacing parts will be needed. I do have plenty of mother boards and hard drives left and would not mind selling them. Thanks.
Posted on Sep 22, 2008
  • Gerson War
    Gerson War Oct 28, 2010
    I still have plenty of power boards and main boards for this unit
Need parts for a DRC8030n
PLEASE CONTACT RCA EXCHANGE UNIT FOR ALL THE OTHER PARTS.
Nov 01, 2009 | RCA DRC8030N
RCA DRC8030n Owner's Manual
Hey jacquesnoir,,
I can email you a copy of the manual..
bigsteve1962@excite.com
PLEASE put "RCA DRC8030N" in the subject line otherwise I will delete the message and you won't get the manual... I get quite a bit of junk at this address so be patient..
Steve
Mar 27, 2009 | RCA DRC8030N
I want to find a replacement for DRC8030N
you can replace the DVD-RW yourself with any computer DVD/DVD-rw drive.  You will need to modify the way it sits in the unit as the screw holes will be different and some drilling will most likely be needed to make new screw holes.  Finding an original replacement DVD-RW for this unit will be hard because the first problem that this unit has is a constant HELLO message due to a faulty DVD-RW, so they are in high demand.
Jan 13, 2009 | RCA DRC8030N
RCA DRC8030N No output
Connect the unit as you normally would using the composite cables. Once you turn the unit on and the RCA logo flashes and then the video *poof*, dissappears, press the Video Out button on the remote control so that the PS OFF (progressive output for S-Video) is shown on the LCD, this should get the video back to normal.
Nov 09, 2008 | RCA DRC8030N
Drc8030n Motherboard
Thank you so much for sending me those parts, and an extra thanks for the extras. Which happens to be what I needed to fix my problem. You won't believe it... I got your well-packaged parts today. I soon replaced the Motherboard, no change, still the same HELLO... I was so deceived... Then, I decided to replace the Power Supply, just in case... IT WORKED!... (thanks for sending me a free power supply)... Looking at my power supply, I can see that on the printed circuit under those 3 diodes, near the transformer, is an area that seems to have overheated. I will test it and give you the results eventually, as well as the results and solution if I can fix the DVD burner. I'll use the extra fan you so generously gave me to cool the power supply, seems like it won't hurt. Though I have to place it right, or it'll make the problem worse... Seems like anything wrong with this DVR and all it'll do is display HELLO... I've heard of a bad DVD Burner, a bad Motherboard and now a bad Power Supply that causes the HELLO... Thank you so very much GSAN, you did it... I recommend you to everyone out there for your fairness, kindness and devotion. We should call you Mr. FixYa!...
Nov 01, 2008 | RCA DRC8030N
Programing my drc8030n remote to the tv
Try looking! Here, for example:
http://remotefinder.rca.com/default.aspx?site=rca
or http://www.thompsontv.com/rcarc.html
Sep 30, 2008 | RCA DRC8030N
Remote does not work
Here is a trick i use to see if remotes are working. most people these days have camera phones or some kind of digital camera that have a live picture feed mode before they snap an image. Grab your camera of choice and point the remote at the camera while your viewing this live feed. press any button on the remote in question and you should be able to "see" the infra red led light blinking. if you dont see any blinking then the remote is the problem. try different buttons if you dont see anything at first.
Aug 21, 2008 | RCA DRC8030N
RCA DRC8030N Problem
This is due to the DVD-RW drive that is in the unit. This is the first to fail and RCA seems to have gone with the lowest bidder on this model. The DVD-RW drive will need to be replaced. If you used the DVR to watch and burn DVDs then you will need to replace it with any computer DVD-RW but you may need to re-drill some holes to have the replacement drive fit exactly aligned with the DVD door. If you only want to use this DVR for the internal hard drive recording and TV viewing, then any CD or DVD computer drive will do, just simply connect the replacement drive and leave it in the case (you wont have access to the DVD or CD drive under this option). If you do replace the drive, make sure you match up the jumper on the back so that it will be in the same position as in the original DVD drive ( the Master setting). I hope I did not scare you with all this information, but unfortunately, the dreaded HELLO issue with the DRC8030N has no easy fix.
Jul 09, 2008 | RCA DRC8030N
Blue screen answer
Blue screen. Most likely the progressive scan is ON. you need to press the "Video Out" small round button on the remote to turn off the progressive scan.
Apr 22, 2008 | RCA DRC8030N
RCA DRC8030N Logo
451 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
