Colors do not align on oneside of the screen.
  • 8,617 Answers
Please respond to this same post with your model number and I will assist you with the problem.
Posted on Aug 20, 2008
My RCA P52937SG projection tv. Picture distorted. I beleive it has to do with the green circuit / projector. Everything needs to be aligned to green. Green projector is on, but, in alignment screen I get...
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board must have replace the 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Mar 28, 2011 | RCA R52WH73 Projection Television
There is a blue shadow (especially around on screen graphics, lettering etc.) when in HD mode. I attempted to align the colors through the color convergence but the blue alignment did not work. I also...
No.This tv have a convergence problems,it dead.The tv have R,G,B colors lines mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board,must be repaired by repacling 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board,to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Feb 14, 2011 | Mitsubishi WS-65807 65" Rear Projection...
Car clipped curb now pulls to oneside
Possible that the chassis is damaged on the side that hit the curb, the front suspension has gone out of alignment. Get the alignment checked, replace balance rods, bushes or lower arm.
Sep 15, 2010 | 2002 Ford Escort
On one side of the screen the red projection doesn't line up with the others. It is about 1" off at teh edge of the screen and lessens to where they align about 11"-12" towards the center of the screen. ...
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis any alignment,have colors shadows or picture look like 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved tv convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 08, 2010 | Hitachi 60SDX88B 60" Rear Projection...
Alignment of the bulbs to converge
These sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
  • Halos around objects
  • Red/Orange looking
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 16, 2010 | Philips 46PP9302 46" Rear Projection...
Colors out of alignment
you moved this set huh? alignment is out, magnets slid out of place on align coils the a convergance alignment preformed (sometimes u get lucky and the coils can be put back perfect and then no alignment needed)
Nov 22, 2009 | Televison & Video
Turned on TV this morning and the colors were out of alignment. TV works just looks funny. Tried the magic focus and got most of the screen lined up....except the upper left hand corner where the colors...
There is a convergence output kit for this set. There are probably resistors in the convergence circuit that are starting to loose there values. If you are going to have the set worked on have them install the whole kit which includes the convergence outputs and resistors. Thanks
Oct 27, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Red green lines across my screen on 51 inch tv hdtv
If you cannot align those crosses, then the convergence section is damaged. should be repaired by a qualified technician, its a big job.
Jul 20, 2009 | Philips 51PW9363 51" Rear Projection...
Alignment of colors wavy on screen
are the lines still straight if so you may want to look for bad solder joints bad caps and resolder or rebuild converg. board
start looking at replasing stk's
Jun 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Warped Picture, Separated colors
Each color (red,green & blue) has an amplifier IC (STK-).
When there is a convergence issue,the first step is change both
IC's for reliability. Then check for open fuses devices,usually
pico fuses.Then re-check convergence alignment.......T.
Feb 07, 2007 | Philips 60PP9352 60" Rear Projection...
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
